Hyundai HU-LCD1902F 19" TV - blue screen
  • matthmal
    • Nov 2012
    • 306
    • Malta
    I have a Hyundai HU-LCD1902F 19" TV which whenever I connect a source to this TV it will remain just a clear blue display.
    I have tried to look physically for bad caps but everything seems fine to me.
    Hope that someone can help me.
    Thanks.
    Re: Hyundai HU-LCD1902F 19" TV - blue screen
    Could be a voltage regulator problem. Test as indicated in this thread:
    https://www.badcaps.net/forum/showthread.php?p=274391
    • matthmal
      • Nov 2012
      • 306
      • Malta
      Voltage Regulator Test 1:
      Model:
      SE8117T25
      0518-LF
      Results:
      Pin 1 -> ranging 0.03
      Pin 2 -> ranging 0.03
      Pin 3-> ranging 0.03
      Voltage Regulator Test 2:
      Model:
      EH16A
      729J55
      Results:
      Pin 1 -> ranging 0.02
      Pin 2 -> ranging 0.02
      Pin 3-> ranging 0.02
        Hmm, no regulators are receiving power. Did you definitely use the DC20V range of your meter? Probe in Volt/Ohm and in COM? Is the COM probe (black) grounded to the metal frame? (back of LCD is good place.)
        • matthmal
          • Nov 2012
          • 306
          • Malta
          yes i;m sure about that as im also troubleshooting some monitors...
            Is the sound present?
            I suspect a problem with that large IC in the centre... which might be difficult to get a replacement for.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              I looked at that, the soldering looks a bit odd - you could try slight pressure on it to see if anything changes on screen perhaps try heating gently with a hairdrier and see if that changes anything.
              • matthmal
                • Nov 2012
                • 306
                • Malta
                ok so i did what you did and the problem persisted. I noticed that the large IC is lifted from one side as if someone removed it and tried to re-solder it again and did not put it back in the exact position.
                  That could definitely be a problem!
                  Has anyone worked on this unit beforehand?
                  • matthmal
                    • Nov 2012
                    • 306
                    • Malta
                    i don't think that removing it and re-installing it could solve the problem right? just to point out something, i noticed that if it stays on a blue screen for long while navigating with the source it automatically turns off
                      It might be shutting down because no signal has been detected.
                      If the chip truly has loose pins, it is unlikely to work.
                      • matthmal
                        • Nov 2012
                        • 306
                        • Malta
                        i dont know if someone has worked on it before because it wasn't mine. so do you suggest that i try to re-solder it?
                        • matthmal
                          • Nov 2012
                          • 306
                          • Malta
                          help me please guys
                            Sorry missed the post. The best bet would be to solder it, if you are capable, or source a new main board -- might not be worth it for a 19".
                            • matthmal
                              • Nov 2012
                              • 306
                              • Malta
                              ok will try to de-solder and solder it again tomorrow and let you know
                              • Ryan.man
                                by Ryan.man
                                02-04-2025, 12:23 PM
                              • gbbradshaw
                                Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
                                by gbbradshaw
                                Hi.
                                I have the Samsung TV Model: UE65TU7000KXXU VER:02/UTU7000 which has developed the following issue: blue screen while the sound it's still working. This happened after the screen developed some horizontal lines at first and then the next day suddenly turned into blue background. the screen was not damaged or anything. I can't access the menu. I have taken the tv to a local tech to have a look and he said that he thinks that it might be the pcb board as the back-lights are working and the sound aswell . I was hoping maybe you can guide me if I should buy the pcb board or not? Thanks
                                02-22-2023, 01:31 AM
                              • siuras676
                                Dell XPS Plus 9320 blue screen and rebooting
                                by siuras676
                                I have a Dell XPS 9320 in for repair, and the machine has a strange issue.
                                First, a bit of history: the laptop came in after liquid damage and was completely dead. I've repaired all the broken traces, replaced the damaged components, and it now powers on.
                                However, it's now showing a Windows blue screen related to hardware (as seen in the picture), along with another Dell error I've never seen before.
                                Has anyone encountered this issue on a Dell machine before and could point me in the right direction? I've checked the power rails around...
                                04-07-2025, 12:10 PM
                              • Abdulrhman Alabsi
                                Dell precision 7530 blue screen
                                by Abdulrhman Alabsi
                                I have problem in my laptop, When I try to enter to windows it showes me blue screen, I changed hard driver and ram but it did the samthing...please give me the solution of it
                                02-09-2025, 10:39 AM
                              • burntonnerings
                                Acer K272HUL blue power light but black screen, power supply is ok
                                by burntonnerings
                                Have had two Acer K272HUL monitors die with the same symptoms:
                                - Blue power light is illuminated while the monitor is plugged in
                                - Black screen (no splash screen, etc.)
                                - Power button doesn't do anything
                                Opened it up and checked for bad caps and components, evidence of burns, etc. - everything looks fine.
                                Power supply voltages are fine.
                                There are some signal lines on the power supply harness that goes from the power supply to the logic board, not sure what these should be at.
                                Anyone have any ideas?...
                                12-09-2023, 10:22 PM
