SAMSUNG LN46A550 P3FXZA - Weird Contrast & Discoloration issue
  • Bxscig
    • Nov 2012
    • 3
    I have a SAMSUNG LN46A550P3FXZA that just started with this weird issue of like extra snow like distortion. I am not sure if it the main board, cable, LCD or what not.
    Does anyone know what it may be from these pictures? It happens across all inputs. When I took it apart to get part numbers, I powered it on with the back off for the heck of it and it worked for about 2 hours and was still good. I shut it off, put he back on and then the issue was there as soon as I turned it on. Sometimes it takes about 5 to 10 mins for the issue to appear when the TV is started but sometimes it is instant.
    Here are some pictures
    http://www.nyblacktl.com/samsung/IMG_2010_resize.jpg
    http://www.nyblacktl.com/samsung/IMG_2012_resize.jpg
    http://www.nyblacktl.com/samsung/IMG_2013_resize.jpg
    http://www.nyblacktl.com/samsung/IMG_2014_resize.jpg
    http://www.nyblacktl.com/samsung/IMG_2015_resize.jpg
    http://www.nyblacktl.com/samsung/IMG_2045_resize.jpg
    I have been having a hard time trying to find another main board to see if that is the issue as it was with another Samsung TV I have - LNT-4665F... 2 for 2 have issues within 2 years... just my luck. Any help would be appreciated.
  • Bxscig
    • Nov 2012
    • 3
    Re: SAMSUNG LN46A550 P3FXZA - Weird Contrast & Discoloration issue
    I don't have the pictures of the parts where the white/bright parts just look WAY TOO bright.
      Try this.
      TV power off (in standby.)
      On remote: Info Menu Mute Power (TV should power on with service menu)
      -OR-
      If this does not work, turn it off again, then try on the remote Mute 1 8 2 Power... some models use that code instead.
      When in the service menu, select "Reset" or "Factory Reset".
      • Bxscig
        • Nov 2012
        • 3
        Originally posted by tom66
        Try this.
        -OR-
        Thanks I will give that a shot. Does that just reset the video settings back to default?
        The discoloration as well as the location of it changes... sometimes its blue, sometimes its reddish or its the white but I will give it a shot.
        Hope to report back soon!
          Yes, it resets everything. The TV will power on again as if it is new from the retail box. So if you have any important calibration or particular picture settings, back those up.
          One thing I forgot to mention was that you must press the buttons in sequence, not all together at once.
          I have seen this before on a Sharp LCD TV, but it only affected green. Just needed a reset.
          It could also be incorrect panel config -- especially if it occurred suddenly -- or T-con motion-processor fault. (The 100/120 Hz frame doubler this TV uses has lots of overheating problems causing odd artefacts.)
          I have the LE40A656, very similar TV, I have fixed two of them. The T-con board failed on one (green lines -- but fixed in location), bad capacitors on the other. I kept the second one, but I found the motion enhancement to be very annoying, so quickly turned it off.
          • randtek
            • Oct 2011
            • 280
            • US
            I would try cleaning the connectors of the LVDS cable. They can cause some weird symptoms. I do this by disconnecting the connectors, cleaning the contacts by burnishing with a pencil eraser, then cleaning with an electronic contact cleaner such as "Blue Shower". I have fixed a lot of picture issues with this technique.
            • tw2005
              • Oct 2011
              • 6458
              There's some data in these, may or may not assist.
              PDF was simply was too big.
              looks like there's service menu (what TOM has mentioned)
              Plus a HIDDEN Service menu. Looks like there's some onboard test patterns there as well.
              How to enter the hidden factory mode.
              a. into the factory mode
              b. key input : 0 + 2 + 1 + 4 + exit
              c. select option byte menu -> in menu -> out menu
              (... hidden menu appear...)
              ** hidden menu : Video/Scaler, Enhancement, SOUND, Dynamic Contrast, LNA+
              - FBE3(image enhance IC) generate internal pattern
              Samsung_LN32A550P3F_LN37A550P3F_LN40A550P3F_LN46A550P3F_LN52A550P3F_ch_GPR3X_4X_5X
                Wait a minute... there's a hidden menu inside the hidden menu?
                • tw2005
                  • Oct 2011
                  • 6458
                  Or is it a hidden menu, in a hidden menu which is hidden? LOL
                  • hijodalgo
                    • Jan 2011
                    • 35
                    that's T-Con board problem..
                      Whilst it does look like a T-con board problem, it was a config problem on the Sharp LCD I fixed.
                      • T-Rex
                        • Feb 2014
                        • 14
                        Hi, I have what I think may be a similar problem but factory reset and reseating cables on tcon did not fix it. I will create a new thread with pictures.
                        • suzannetodd1
                          • Jun 2014
                          I saw a post on here that someone bought a repair kit for T-con (as I am having the same prob with my TV). My question is how easy is it to repair a T-con or do I need to take it to professional????
                            Have you ever done any surface mount soldering? In particular a 48 pin chip with leads 0.8mm apart?
                            If so you can do it - if not you should ask a professional.
                            • onrushmatt
                              • Jul 2015
                              • US
                              I have the same tv (Samsung LN46A550P3FXZA) and I am trying to figure out if my T-con board needs to be replaced, or just some caps.
                              I have light experience in working with circuit boards but feel confident in some basic soldering. I have attached a picture of the service menu, which I heard may be a way to fix the issue with the picture. My options are 'Option Byte' 'White Balance' 'B/B Movie' EPA Standard' 'Sound' 'Hotel Option' 'EDID' 'CHECKSUM' 'View Log' 'Front Data Viewer'. I assume the options between will be available once clicked into a menu.
                              I also attached a photo of the picture issue as well. I think it is the same as the OP's.
                              I would really appreciate any information or tips, and hope this old thread can bring me some answers.
                              Also threw in a photo of the model on the side of the console.
                                Bad GAMMA Voltage ref. IC, Look for AS15 IC on the T-CON board.
                                • Kallla
                                  • Jul 2015
                                  I have some similar (or not?) symptoms on my home TV a Samsung LN32B650T1FXZA ... attached a picture of how image look (image remain with high luminosity regardless of input source used).
                                  Any taught, help or information to speed-up debugging is highly appreciated !
                                    Look at the T-CON board to see if it has GAMMA IC AS15, or AS19, very likely to be your problem.
                                    • Fix4Fun
                                      • Mar 2020
                                      I had this exact model of TV: LN46A550P3FXZA with the exact same problem, weird colors on the screen: sometimes white where black should be and red spots pixels, pixelating, depending on the input used. It was the T-con board (not the motherboard despite the differences in the inputs). When I got a brand new T-con board (model #: V520H1-C06) from eBay for $32, and swapped out the old one, all my problems went away! I hope this helps someone else considering replacing their T-Con board!
                                      • SuperJames
                                        Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                        by SuperJames
                                        This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                        Specs
                                        i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                        Backstory
                                        I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                        10-23-2023, 04:09 PM
                                      • ugamazing
                                        820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                                        by ugamazing
                                        So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                                        1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                                        2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                                        04-10-2024, 08:06 AM
                                      • lukkihapsi
                                        Asus Vivobook X515JA Weird Boot Issue
                                        by lukkihapsi
                                        Asus Vivobook X515JA Laptop
                                        Issue :
                                        Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                                        Tried :
                                        Cleaned inside for dust, applied fresh thermal paste. No Change!
                                        Removed keyboard, Trackpad, fingerprint sensor. No Change!
                                        Removed Internal SSD. No Change!
                                        Updated BIOS to latest version. No Change!
                                        Removed battery and pressing power button for 1 minute. No Change!
                                        Weird Part :
                                        Upon turning laptop ON, screen lights up - stays black,
                                        I...
                                        07-07-2025, 12:07 PM
                                      • tommygun26
                                        Hp 6510b weird issue
                                        by tommygun26
                                        Good day people.Have hp6510b laptop with crazy issue.I can switch laptop on either under battery attached or witchout it connected to a OG charger.Have display working correctly.Can access bios menu.Memory test passed ok.Issue is i cant boot into any install media usb or Optical drive to setup Os.Quick boot menu F9 is working ok.Laptop wont boot into media just boots looping or randomly switches himself off dead just before media boot.One time managed to boot into freedos Hp bios update and flashed F16rev bios with success.That did not fixed issue.Couple times rarely like 1/40 laptop did boot...
                                        02-26-2023, 06:00 AM
                                      • Stephen
                                        A2141 Weird Issue But works
                                        by Stephen
                                        Got an A2141 MacBook Pro 16" computer turns on however the track pad clicks but the keyboard has no life, NO LIQUID DAMGE whatsoever. Trackpad does click but the OS loads but the trackpad won't move the cursor, the keyboard is unresponsive. I replaced the cable and the trackpad to see if that was the issue but it was not, I went to see if the CAPS LOCK would turn on but it does not. Any indication what this is? I went and tested the lid sensor but nothing else. Battery holds a charge, fans spin normally, and lcd is good. I can use external mouse and keyboard without issue....
                                        05-06-2025, 10:23 AM
