Re: Sanyo dp42848. No picture no sound?has anyone found the problem
I want to use two 12v lamps connected in series and then connect them to the 24v output to really verify if you have the voltage or not for sure. Something does not make sense at this point.
Is it possible the transformer has an open winding?
It would be the first time I've seen one...
Only if the center tap pin is open tne you will have no output, but I already have him check the resistance on all 3 pins, I myself never have to replace this kind of transformer in all my repair.
What is the rail wire?i unplugged the wire on the power supply upper left at top of power supply,the power supply Board read 24v so I probed that pin. No volts the wire that goes to that pin is white and goes to the invertor, tried on the slave invertor same thing,the other wires show lower voltage like 4.75. But no 24 volts with the tv on plugged in?so if I'm doing it right IS THE POWER SUPPLY TO BLAME?ok will wait up tonight for your reply, thanks
"i unplugged the wire on the power supply upper left at top of power supplythe power supply Board read 24v so I probed that pin. No volts the wire that goes to that pin is white and goes to the invertor,"
Hmm, I am trying to understand the statement above. I read it as no 24v with the inverter baord not connected.
I know, the thread is getting long, the circuit is so simple, transformer, rectifiers, filter caps- that is? the 12v is generated by the same transformer and it is putting out 12v OK. We are missing something simple here.
Look I don't know anymore than anyone here,but something like a fuse or something has blown?when I plug that tv in and I probe the wires on the power supply there is no 24 volts! Something is shutting down the 24v side of the power board?should I reinstall the board?
You need a 24V, 8-10A power supply... if you have one, then provide 24V and connect INV-ON to 5VDC and DIM to 5VDC.
I see Rick Williams answer on almost every part of Just Answer to be "it's the capacitors." Even to LCDs with blurring screens etc. It's complete nonsense. But he gets paid for it!!
I still like you to get the lamps for testing the power supply, like I had explained earlier, the T1 supply the 12v and 24V from the SAME transformer and same drive circuit, there is only one shutdown circuit in the primary side of the transformer, if it shuts down, the 12v will be off also.
Did you look to see how much the replacement board is?
The connector CN4 to the MASTER, and next to it that goes to the Slave on the power supply board where it is labeled with 24v, do not have anything plug into that connector.
