Vizio 42" Plasma - P42HDTV10A - Turns on but can't change input
  • Ritalin
    • Sep 2010
    • 194
    So I picked up a dead Vizio, changed out the caps on the power supply and got it working, but now i can't change any of the inputs/menu/channels either from the remote or the side controls.
    Thoughts as to which board is bad?
    *Pictures to come*
    Re: Vizio 42" Plasma - P42HDTV10A - Turns on but can't change input
    Re-seated the connector to the button board? Or, it could be a stuck button on the button board causing the TV to ignore remote control input.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Does it switch on and off from the remote?
      • Ritalin
        • Sep 2010
        • 194
        No it does not...
        Leaning towards replacing the logic board.
          I would try the switch board first, just in case, it is usually cheaper too.
          • Ritalin
            • Sep 2010
            • 194
            Tuner board?
              No, the board with the buttons on it. Is it separate?
              • Ritalin
                • Sep 2010
                • 194
                No, they are separate. I'm going to try and detaching it and seeing if the remote works then to see if it's that board that's bad.
                • SS454
                  vizio e650i-a2 backlight flashes then turns off
                  by SS454
                  vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                  panel: au optronics T650HVN05.4
                  72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                  link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                  Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                  https://www.shopjimmy.com/vizio-56-0...-power-supply/
                  Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                  08-20-2020, 03:57 PM
                • ugamazing
                  820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                  by ugamazing
                  So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                  1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                  2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                  04-10-2024, 08:06 AM
                • Super360
                  Vizio E701i-A3 Vizio logo flashing then turns off
                  by Super360
                  Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                  07-25-2024, 07:06 PM
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • Stephen
                  MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                  by Stephen
                  MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                  03-15-2024, 09:37 AM
