Samsung LNT4069FX-XAA. Customer said the cable guy told him the cable box that was hooked up to the TV was struck by lighting. The TV when plugged in clicks a little faster than one click a second and it seems to be coming from the yellow transformer at the top center of the first photo. You can not feel the click when you touch it or the surrounding components. Both fuses on the board are good, all caps tested good with ESR meter. I cannot test voltages because they bounce all over with the clicking. If I unplug the main board it stops, but if I plug the main board back in and disconnect cables from the main board it still clicks., Any ideas??? Will a transformer click?
Clicking Transformer??
Tags: None
Re: Clicking Transformer??
Your username is a good start... this is a very common symptom of a shorted diode. Can also be a bad startup cap, bad controller IC or excessive load on the output.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Yes, it does sound like it is the start-up-shutdown mode due to fault that Tom has indicated.Never stop learning
Would the fault be in the power supply or the main board? I know ho it w to test everything but the IC controller. Is there a way to test it by resistance between pins?Comment
--- begin sig file ---
--- end sig file ---Comment
You will have to test that...
With the power supply connected to the main board, check resistance between all voltage rails and ground. See if any of them appear shorted.
- If YES, note which voltage rail is shorted, and follow that voltage rail on the main board.
- In NO, then since the power supply doesn't click when disconnected from the main board, I would suspect bad start-up cap or bad output capacitor(s).Comment
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... -
by JDCONN 100012588
Issue: No Power, Then Rebooting After Main Board Change
Short answer: replace main board and power board
Technical answer: replace main board and Q306 & Q307 on power board.
Long answer:
TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge.... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by cheeky2I suppose the real question is whether the existing pinouts from ether a 17IPS71 psu are cross compatible with a 17IPS12 psu? If they are then the exchange of the main boards should have no issues providing the screen is compatible with both main boards. Obviously you can change the screen configurations easily enough (providing you have the correct files) for the main board. Why may you ask would I do this? Well a lot of the smart features are no longer working on a Hitachi 48HBT62U main board I wish to give it a new lease of life!
Obviously the same LVDS connector for the screen connection... - Loading...
