Ilo, two biggies bad, should I use these?
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Yes my first LCD TV in all my time here. a ~40" Ilo TV, had two small caps replaced once, and now its two 400v 100uf are fried. These look legit, what you think?
    http://www.ebay.com/itm/100UF-400V-N...item1e6689c782
    these
    http://www.ebay.com/itm/Rubycon-capa...item337dbd82f6
    look suspicious
    maybeee these?
    http://www.mouser.com/ProductDetail/...cL%2FhHR3M8%3D
    maybe I should choose something from this list
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Ilo, two biggies bad, should I use these?
    Since you live in the USA and digikey has reasonable shipping costs (typically under $3 USD for first class shipping), I suggest avoiding anything on ebay. The Rubycon's are likely fake. The date code looks all wrong.
    --- begin sig file ---
    --- end sig file ---
    • Mr Bill
      • Nov 2011
      • 648
      I 100% agree. I tend to only use ebay if it's a last resort effort.
      Here is a digikey link for a Chemicon KXG for $2.84. It's Ripple is 765mA
      http://www.digikey.com/product-detai...1469-ND/755985
      Here is for a panasonic EE for $4.28. Its ripple is 2.6A but the length is a little longer than the one chemicon above (40mm)
      http://www.digikey.com/product-detai...670-ND/1245999
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        I found it at mouser for cheaper
        so happens I live in mansfield, TX, where mouser HQ is, its actually 5 mins from me. I know a guy who works there, he says you don't have to have a business license anymore to buys caps
        http://www.mouser.com/ProductDetail/...57H04F9g%3d%3d
        • retiredcaps
          • Apr 2010
          • 9271
          Well, then it is an easy choice.
          I only mention digikey because I know what is mailing costs are. I don't know them for mouser.
          • Mr Bill
            • Nov 2011
            • 648
            Mouser's shipping is $6.95 for up to 1 pound in the US (priority mail only). I typically use digikey since the shipping lead time is quicker and what i order almost always weighs less than 13 ounces so it can be mailed via first class mail. But i have ordered from mouser is what i need is out of stock elswhere. But if you live 5 minutes away, driving up there and getting them directly is the way to go.
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              I'm a bit weary of using UCC caps, and the panasonic EE linked above are 40x18, the current ones are 35.5x18, and the extra height puts the vent very close to a mosfet heatsink (the one that is most 'burned' is the one that is closest to this heatsink)
              I found a nichicon on mouser that is 580ma, 35.5x16, where the current cap (Capxon) is 550MA, its nichicon and its close enough, right?
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                ya know what, I was wrong the whole time, these are 450v!
                I picked up 400's nichicon 10,000hrs from mouser a few hours ago. I'll keep them, never know when I might need them
                of the 450's only one that had a 35mm length (all others had 40-50) was 2000 hrs and they're out of stock for two days. oh well, i'm not going anywhere
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  is the voltage on these caps right from the ac? would it be ok to use 400's in place of 450's?
                    Most likely using PFC so bus voltage could be 400V nominal... 400V caps might be too sensitive with regards to running very close to limits possibly exceeding them.
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5042
                      • US
                      ok so the caps I was going to order are waay too far out, so i'm going to have to get some 40mm length instead of 35, it fits, but puts the top of the cap awfully close to a reg heatsink, I might have to come up with some insulator to place between them. anyways, these were what I was hoping to get
                      http://www.mouser.com/ProductDetail/...uvOy%252bMt9w=
                      but I have a quetsion about the leakage, the current leakage on the capxon KM's are <= 0.01 and the leakage on these nichicons are 0.06
                      leakage is something i'm actually not sure about, I never paid much attention to that value, so i'm not sure and need some gurus opinion
                        No need to be concerned about leakage in this instance. Only if it is a startup cap or battery powered.
                        • ajdrenter
                          Picking caps for Antec SU-380
                          by ajdrenter
                          In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                          https://www.badcaps.net/forum/showthread.php?t=14159
                          It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                          05-13-2023, 10:40 AM
                        • staze
                          Old Boston Acoustics subwoofer repair, BJT alternatives
                          by staze
                          Working on an older Boston Acoustics HPS10SE, and while verifying voltages, I noticed one of the PSU BJTs is getting excessively hot and the voltage is dropping out on the 15V rail. Not sure that's actually an issue (I don't have everything plugged in, so maybe something is saturating on the positive end and dragging that rail down and the BJT overheating is cutting out).
                          But, figure I need to buy some NP capacitors from mouser anyway, so might as well replace these. They're a H669A and H649A. Pretty "meh". They test fine out of circuit, but I can't really put a load on...
                          06-11-2024, 09:57 AM
                        • rcanpolat
                          M1 MacBook Pro 2021 A2485 - No backlight display
                          by rcanpolat
                          I recently got my hands on an M1 MacBook Pro (2021, A2485) that I suspect suffered some liquid damage. I have a hot air station and the basic tools to work on the board, but I’m new to SMD repair and would love some guidance before diving in.
                          Here’s what I’ve observed so far:
                          • When I power it on, I hear the MacBook chime and, with a flashlight, I can see the Apple logo on the screen. However, it never completes the boot and eventually powers off. My plan is to try to get the display fully working first, then tackle the boot issue.
                          • I did some basic resistor
                          08-24-2025, 02:16 PM
                        • pc_okay
                          Crystal compatibility 32khz ASUS UX325 NB255_PCB_MB_V4
                          by pc_okay
                          Hello friends,
                          Its been a while, i wish you an happy new year 2025 !
                          I have this laptop doesn't start, power light up a second when pluging USB-C charger.
                          Laptop take 0.11A.
                          All signals and voltages before SLP_S4# are OK but no SLP_S4# , S3...
                          I get no oscilation on XTAL 32.768 KHZ
                          Battery is not charging but charging led is here.
                          PCH heat at 30° approximatively. (with no heatsink)
                          I think this crystal might be dead, i have only boardview giving me this: XTAL 32.768KHZ 12.5PF/20PPM.
                          It's a 2 pins Crystal.
                          01-13-2025, 09:26 AM
                        • nicktasios
                          Macintosh Quadra 840AV PSU
                          by nicktasios
                          I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                          12-22-2024, 05:07 AM
