OLEVIA 37" No Picture
  • wvpanhandler
    • Nov 2012
    • usa
    Hi I am Wayne from Bunker Hill, WV, also a SnowBird
    in Ocala, Fl. TV quite so I started self study for fixing it.
    HERE GOES:
    Read up on a fix for the start board. Changed out two
    capacitors that were visually bad. 680bf @ 35 volts.
    On reassembly failed to get picture. Called TV Technician
    and he couldn't the problem at first. The board would
    start with 24 volts when reset with solid blue on front.
    When on button pushed it would go to blinking blue light.
    It would lose voltage right away.
    When touching white ribbon with 4 fine lines that didn't
    quite make good contact the little blue light on the blinked
    As it turned out the sequence is push on button, it goes out
    the little light should come on the start board. Sorry about
    my terminlogy. The Ribbon cable was mean one to put back
    caused the damage on the fine tin foil lines, ribbon is only
    1/4" wide.
  • drpj23
    • May 2012
    • 528
    Re: OLEVIA 37" No Picture
    No offense, but your sentence structure is making this difficult to understand.
    The first part: are you getting 24v when there is a solid blue light? Last Olevia I worked on, a solid blue was standby (which is odd in my opinion).
    You lost me at the ribbon part.
    Pictures (using manage attachments feature) might help better convey your issue and your findings.
    • XmouseX
      • Aug 2011
      • 158
      • US
      That is WV speak..lol. I have worked on this same model TV twice before. Have any pictures of the power supply board?
      • Tr0ll
        by Tr0ll
        Original T-con:
        First replacement T-con:
        10-07-2023, 07:48 PM
      • kca
        Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
        by kca
        Hello all ~
        I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
        This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
        No picture. No sound.
        I tested all the voltages coming out of the power supply...
        10-12-2023, 05:23 PM
      • TurboTundra
        PS5 EDM-033 Blue Light 2 Sec then Powers Off
        by TurboTundra
        Hi, I am waiting for my uart tool so I can grab an error code and narrow down where my issue is, but I decided to measure capacitors and fuses to insure everything was okay.
        The PS5 turns on with a blue light and a beep for 1-2 seconds then turns off. I noticed a grey capacitor measures no voltage on standby or input power. Does this indicate a problem with the capacitor or something down on the line? I’m getting 3.3v on input with the red cap next to the grey one, and 5.2v on input with the red cap further away from the grey cap.
        Thank you for any input...
        06-10-2025, 08:51 PM
      • icareservicezone
        Synology DS918+ blue light blink
        by icareservicezone
        Synology DS918+
        Model name : GDI41L2
        p/N: 08-06GDI4116
        Version: V1.6
        Problem : blue light blink...
        05-24-2025, 11:53 PM
      • cajoeg
        Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
        by cajoeg
        Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
        The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
        02-10-2025, 04:01 PM
