OLEVIA 37" No Picture
  • wvpanhandler
    • Nov 2012
    • usa
    Hi I am Wayne from Bunker Hill, WV, also a SnowBird
    in Ocala, Fl. TV quite so I started self study for fixing it.
    HERE GOES:
    Read up on a fix for the start board. Changed out two
    capacitors that were visually bad. 680bf @ 35 volts.
    On reassembly failed to get picture. Called TV Technician
    and he couldn't the problem at first. The board would
    start with 24 volts when reset with solid blue on front.
    When on button pushed it would go to blinking blue light.
    It would lose voltage right away.
    When touching white ribbon with 4 fine lines that didn't
    quite make good contact the little blue light on the blinked
    As it turned out the sequence is push on button, it goes out
    the little light should come on the start board. Sorry about
    my terminlogy. The Ribbon cable was mean one to put back
    caused the damage on the fine tin foil lines, ribbon is only
    1/4" wide.
  • drpj23
    • May 2012
    • 528
    Re: OLEVIA 37" No Picture
    No offense, but your sentence structure is making this difficult to understand.
    The first part: are you getting 24v when there is a solid blue light? Last Olevia I worked on, a solid blue was standby (which is odd in my opinion).
    You lost me at the ribbon part.
    Pictures (using manage attachments feature) might help better convey your issue and your findings.
    • XmouseX
      • Aug 2011
      • 158
      • US
      That is WV speak..lol. I have worked on this same model TV twice before. Have any pictures of the power supply board?
