Magnavox 32md359b/f7 on then off
  • freakaftr8
    • Oct 2012
    • 3743
    Ok long story short. Picked up this magnavox (funai) lcd tv with built in DVD player. Turns on the. Off in 3 seconds. Researched issue down to the inverter. Checked all components on the inverter including chokes and transformers and fets diodes resistors etc. looked this issue up online and people just replace the inverter and cured the problem.
    Not me. It was 30 bucks so after checking ccfls I said screw it. I clipped the shutdown protection on the inverter. Powered up and works great.
    Hmmmm so what's this about?
  • BlkSmth
    • May 2010
    • 89
    Re: Magnavox 32md359b/f7 on then off
    So where do I clip mine? Thanks in advance!
    • eccerr0r
      inverter H tree driver imbalance in an AC inverter
      by eccerr0r
      My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
      11-16-2025, 12:34 PM
    • x_orange90_x
      Vizio E55-E1 bad backlights or bad inverter?
      by x_orange90_x
      I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
      I don't know how exactly to test the inverter itself. Is it...
      01-29-2025, 09:24 PM
    • Gentian
      APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
      by Gentian
      I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
      It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
      03-06-2023, 07:07 AM
    • tonybig10
      Magnavox MDR515H/F7 And Magnavox MDR537H/F7
      by tonybig10
      Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
      the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
      03-07-2025, 01:03 PM
    • valvashon
      Insignia NS-LCD19-09 (PS OK, Inverter problem?)
      by valvashon
      For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
      History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
      01-04-2024, 01:44 PM
