Jvc jlc32bc3000
  • Nam3o
    • 44
    #41
    Re: Jvc jlc32bc3000
    no change
      Re: Jvc jlc32bc3000
      OK, so I suspect this device is faulty. (See attached.)
      Can you get the part # on it? It is probably a PNP transistor but it could be a P-channel MOSFET.
      • Nam3o
        • 44
        #43
        Re: Jvc jlc32bc3000
        Kia
        431a
        117
          Re: Jvc jlc32bc3000
          Oh, it's not either of those. I think I understand it. It's a voltage reference. It's regulating the 18V down to 12V, which is an odd way of doing things -- I'm not sure why they would do it that way. I need to trace out the circuit to understand why it's not working. I will be back.
            Re: Jvc jlc32bc3000
            OK, here is the voltage regulator part (see attached.) But I can't trace it fully yet as I don't know where R222 connects.
            I remember seeing this circuit in a Samsung TV too. I think it is to reduce the standby power, by using a single transformer.
            I need you to check which component this lead is part of (see attached.) I have a strong suspicion it is ground.
            • Nam3o
              • 44
              #46
              Re: Jvc jlc32bc3000
              it connects to r285 then to q283.
              • Nam3o
                • 44
                #47
                Re: Jvc jlc32bc3000
                this what I found
                  Re: Jvc jlc32bc3000
                  How difficult is it to make some tests on the power supply's rear side? I am thinking that the control signal is not reaching the TL431 or the TL431 is shorted out. I would need to know the voltage across R223.
                  • Nam3o
                    • 44
                    #49
                    Re: Jvc jlc32bc3000
                    R223 0v
                      Re: Jvc jlc32bc3000
                      OK, in which case, I am thinking it is a problem elsewhere on the PSU. (Probably in that large component area near the power connector.) It's not getting a signal from that part.
                      Is there a part # on it? I'd love to debug it more but it's proving a bit beyond me. If it's only about $20-30, it could be worth it.
                      • Nam3o
                        • 44
                        #51
                        Re: Jvc jlc32bc3000
                        I think this will help
                          Re: Jvc jlc32bc3000
                          Sorry, what?
                          • Nam3o
                            • 44
                            #53
                            Re: Jvc jlc32bc3000
                            Originally posted by tom66
                            Sorry, what?
                            No? did I fail to understand?
                              Re: Jvc jlc32bc3000
                              I was looking for the part number of the board, but I found it.
                              http://www.shopjimmy.com/vizio-0500-...t-inverter.htm
                              Never mind, it is very expensive! There is another thing you can do. If you don't mind the TV using a bit more power in standby, then the 12V can be forced on.
                              • Nam3o
                                • 44
                                #55
                                Re: Jvc jlc32bc3000
                                sounds good to me.
                                  Re: Jvc jlc32bc3000
                                  OK, see the attachment.
                                  You need to cut the jumper link on the top between the two pads.
                                  Then solder a 100 ohm resistor between the 18 ohm and the bottom most pad on the jumper link (nearest the KIA431.) 100 ohms is flexible. Anything up to a few 470 ohm down to 47 ohm should work. It's just to prevent damage in case of failure (the resistor should be the only casualty in the worst case.)
                                  Very important: BEFORE you connect the main board double check the 12V output is giving 12V and not 18V! It should now be 12V all the time.
                                  • Nam3o
                                    • 44
                                    #57
                                    Re: Jvc jlc32bc3000
                                    that did restore the 12v pins but it still wont turn on.
                                      Re: Jvc jlc32bc3000
                                      OK, that is very odd. I am confused, it should work. Was the TV hit by a surge? Any idea how it failed? Any different symptoms with 12V now?
                                      • Nam3o
                                        • 44
                                        #59
                                        Re: Jvc jlc32bc3000
                                        no surge. the TV just slowly stopped coming on reliably. 12v seems ok
                                          Re: Jvc jlc32bc3000
                                          Does the TV do anything differently at all? Like, if it had no power LED before, does it have one? Can you turn it off once it is turned on?
                                          You say it stopped turning on reliably -- does this mean it would turn on once in a while, but not always? Did it get slowly worse over time?
                                          • flat-earther
                                            ASUS X54H laptop thinks it's always charging even with charger unplugged
                                            by flat-earther
                                            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                            Windows also shows ''Plugged in'' when charger is not connected.
                                            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                            If I let battery run out and say it has 3% Windows will...
                                            06-24-2025, 09:32 AM
                                          • malogro
                                            Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                                            by malogro
                                            Hello all,
                                            I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                                            Intro:
                                            This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                                            Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                                            04-14-2023, 04:44 PM
                                          • jose6326
                                            Samsung s32d850t powers off
                                            by jose6326
                                            Powers on as normal shows an image then powers off after 10 seconds
                                            I have to unplug it from the wall and replug to get it to turn back on but then shuts off
                                            No blown caps
                                            I searched for this model but nothing comes up...
                                            11-29-2024, 11:21 PM
                                          • Topcat
                                            Dell XPS 8950 Power Issue
                                            by Topcat
                                            A few months out of warranty and it's dead as a fart. XPS 8950 with a 12th Gen I5, 32gb DDR5 RAM and a GTX1650 GPU.....
                                            Symptoms it's giving are really making a coin toss between bad motherboard and bad PSU....I'm leaning toward motherboard, but there are some strange irregularities with this piece of shit system.
                                            Basic test:
                                            Upon connecting power cord, system powers on by itself (no button push) for a second then powers down...and then powers back on again, I hear a relay trip inside the PSU, and then powers down again and that's it. It won't do anything else....
                                            01-02-2024, 05:51 PM
                                          • simwalsh
                                            Philips 47PFL4606 Powers on, works normal then powers off after a minute
                                            by simwalsh
                                            I am new to this forum and have searched for some answers with problems similar to mine.
                                            Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
                                            It sounds like a power supply issue?
                                            I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
                                            12-04-2023, 04:03 AM
