Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Bush IDLCD32TV16HD Dead
  • gilly1984
    • Jun 2012
    • 751
    Just bought this off ebay, going to collect it at around 6ish, It has a IPOS 150 power supply.
    Seen a few posts with this power supply, read them but it seems these are quite troublesome.
    Picking it up tonight so will get some pics up.
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
    Re: Bush IDLCD32TV16HD Dead
    If it's a MEGMEET IPOS, probably some bloated CapXon on there...
    • gilly1984
      • Jun 2012
      • 751
      Have to look tomorrow now, my lift was a little late so arranged to collect tomorrow.
      Hopefully its a nice easy fix as you say Tom.
      • gilly1984
        • Jun 2012
        • 751
        Ok, i have the tv now.
        I have standby light, press the power button and the tv attempts to come on, hear the speakers hiss a little, but in a nice way.
        No backlights come on, checked in a dark room.
        All voltages are ok on the power board, i get the same readings as other posts on here.
        Now, where do i start? And is it possible to test the cfls without killing myself?
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          No backlights at all, not even a flash = inverter failure. Check the power rail going into the inverter (should be 24v on a set this size) and the mosfets on the inverter.
          A working TV? How boring!
          • gilly1984
            • Jun 2012
            • 751
            inverter is built onto the psu. I think I read that the inverter on the is supplied 240v
              Those two 4.7u 450V caps near the transformers are a -very- common failure.
              • gilly1984
                • Jun 2012
                • 751
                Well, i USED to get a standby light,,,
                I changed a 50v 22uf cap under the heatsink and now it wont work at all. It used to buzz a bit but now its silent?
                I have put the original cap back in and still same problem.
                What have i done to it? Is this a single layer board?
                There is 330v across the big cap.
                • gilly1984
                  • Jun 2012
                  • 751
                  No matter where i probe, using chassis as ground i get either 140vdc or -140vdc?
                    Primary is isolated, use -ve on primary cap as ground for primary.
                    • gilly1984
                      • Jun 2012
                      • 751
                      All the voltages i used to have are gone, 5v 12v and 20v.
                      How can i have messed it up by changing one cap?
                      Cn you show me on pic what you mean tom, when you have time that is.
                      And a red led used to flash on the psu to say there was a fault but thats gone too.
                        -ve = negative (shorthand)
                        So when probing anything on the mains primary side, do not use chassis ground, use primary ground (the negative lead on the big cap.)
                        Re problem checked for lifted pads cut tracks etc?
                        Your main problem is likely inverter as unique suggested.
                        • gilly1984
                          • Jun 2012
                          • 751
                          if I put 84v through a 474 smd resistor should there be any voltage on the other side ? I may have broke it during the cap change.
                            you don't put voltag through anything, voltage is always across something.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              We never ask people to measure the AC voltage of the inverter transformers in the ccfl section. They can easily spike up to > 1000V AC during initial strike/ignition which will kill your multimeter in possibly spectacular fashion.
                              You can test ccfls "indirectly". The 2 seconds to black guide has an entire section on testing ccfls safely.
                              --- begin sig file ---
                              --- end sig file ---
                              • gilly1984
                                • Jun 2012
                                • 751
                                I wasnt going to put any voltage across it pal, just trying to figure out if i damaged the smd resistor, i have replaced it and still the same problem so i know its ok.
                                Just strange that i now have no power on the pins i did have power on before i replaced the 50v 22uf cap?
                                Thanks RC, i will have a look at that thread when i figure out what i have done wrong to lose all my voltages.
                                  You must have broke a connection somehow, check everything really carefully.
                                  • gilly1984
                                    • Jun 2012
                                    • 751
                                    Is this reading normal from the inverter tranny.
                                      You cannot measure the HV with a DMM. You have probably damaged the meter, but in the very least, measurement is not generally possible.
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        One retiredcaps' bonus point for a picture of your multimeter.
                                        You want to measure the resistance between the secondary pins. A diode test will report readings as voltage.
                                        • PsiDOC
                                          BUSH 42" LED TV. BLED42FHDAE Completely dead. Diagnosed and solution awaiting parts..
                                          by PsiDOC
                                          HI all. Just a note for anyone that has one of these TVs.
                                          Make: Bush (China)
                                          Model: BLED42FHDAE.
                                          Symptoms: Half screen went dark, then tv wend dead. No power lights. Fuse checked ok.
                                          First thing checked was standby 5v: Present @ 5.1v.
                                          PS_ON signal from main board: Present @ 4.5v.
                                          I suspected the power supply to be in a foldback / crowbar condition after the screen going out, so I disconnected the power to LED Backlight board (Part ER643). Now standby light is on and TV responds to remote power on - light goes green.
                                          Disconnected the LEDs from the...
                                          10-30-2021, 05:22 AM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • Learn2rage
                                          Acer Nitro 16 AN16-42-R4A9 No power, completely dead.
                                          by Learn2rage
                                          I've hade this computer roughly a year. Last months it started behaving irregularly. Powering off mid stride when on Battery, requiring power to be plugged in to boot even though Battery shows full when booted again, refused charging and power on at some point which I managed to get past by holding the power button pressed long among other things. I've never dropped it, and no liquids. As far as im concerned its in very good condition.
                                          A few days ago, i powered it off, and 30 minutes later it was simply dead. No reaction on diodes on Brick Charger or usb Charger. Tried holding power...
                                          Yesterday, 09:07 AM
                                        • xzomboex19x
                                          Dell latitude 5590- Dead, No Power draw, lights or anything.
                                          by xzomboex19x
                                          I have a Dell latitude 5590 of unknown history. exterior looks mint/ barely worn but it is completely dead. I am a complete novice in board repair but do have a background in small appliance repairs so not a complete noob, but close. I have done the usual things i know of o try and revive d dead laptop for example opened up the laptop, disconnected the battery, RTC battery and while unplugged form the charger shorted out the battery pins in the RTC BATT connector. and this has not changed anything.
                                          I took out and re seated the RAM modules and no difference.
                                          I took out my multimeter...
                                          01-16-2026, 08:10 AM
                                        • hiltsu
                                          MacBook Air M1 (A2337 / 820-02016) dead - no power, DFU restore fails after iBSS send, good voltages - NAND dead?
                                          by hiltsu
                                          Hi everyone, first post here – long-time reader though. I have a dead MacBook Air M1 (2020) that won't charge or power on.
                                          Device info:
                                          MacBook Air (M1, 2020)
                                          Model j313ap (A2337, logic board 820-02016)
                                          Symptom:
                                          No charging, no power on at all.
                                          Restore attempts:
                                          Apple Configurator finds the MacBook in DFU mode, as Linux with lsusb: Bus 001 Device 021: ID 05ac:1227 Apple, Inc. Mobile Device (DFU Mode).
                                          It looks like the MacBookAir is in firmware boot loop. I have tried to restore 14.x version and 26.2 (latest) version firmware,...
                                          01-14-2026, 05:01 AM
