Cap with marking 474
  • knoxrebel
    • Oct 2009
    • 168
    I am working on a power board for a plasma tv and there is a faulty component with the markings 474 on the top of the rectangular plastic case. Think it may be a polypro cap, but im not sure.
    Any ideas on what type or how to read its capacitance?
    Sorry cant get a pic at this time.
  • knoxrebel
    • Oct 2009
    • 168
    Re: Cap with marking 474
    nvm, marking on the side of the cap.
      .47 uF
      • Kemer
        Led status indicator light transfer plastic
        by Kemer
        Hello, the LED status indicators on my Lenovo Z580 are not working. Actually the motherboard LEDs are working but the light doesn''t coming to the front view. The plastic part is which you can see in photo must transfer the light to the frontview but just half of the plastic is illuminating.
        There are three status indicators on the front (power, battery, caps lock), and none of them are illuminated.
        The plastic piece doesn't appear to be broken.
        1. What are your suggestions for resolving this issue?
        2. Is the plastic piece made of special ma...
        08-19-2025, 07:02 PM
      • Junkrepair
        Calculating ESR from tan delta -- tan delta's dependence on capacitance
        by Junkrepair
        I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
        I found this nice little description of the conversion:
        Calculating capacitor ESR from Tan(delta)
        https://forum.digikey.com/t/calculat...-from-tan/2633
        It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
        06-12-2023, 02:45 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • dutchgaucho
        Please help to identify component with marking eHFFH
        by dutchgaucho
        Dear BadCaps colleagues,
        I'm working on a HP Omen 16-WF0894ND. Won't turn on. Battery is charging and 3 and 5V rails are present.
        However, I located PU1801 that's only outputting 0.37v as soon as the power button is pressed. Weird voltage imo, although there's no short after the coil. Chip aint getting hot either. Since no diagram is available, I can't really determine what this rail is for, but I assume it might be a PCH PWR rail. Please help me to identify:
        Chip marking eHFFH
        Board model: LA-M783P
        Please also see pictures attached.
        08-28-2025, 02:41 AM
      • Barttech Computers
        hi all need help with IC marking is XA2LD Sot-23-5
        by Barttech Computers
        I'm trying to identify a small SOT-package IC marked "XA2LD" located near the 5V_FS rail on a logic board. The silkscreen shows it as U26/U25, and it's adjacent to components labeled R415, C232, L28, etc.
        Here’s what I know so far:
        • The IC marking is XA2LD (possibly custom or abbreviated).
        • It’s likely involved in power switching or regulation (possibly a load switch or LDO).
        • The package appears to be SOT-23-5 or similar.
        07-27-2025, 09:27 PM
