Samsung LN52B630 No picture
  • moegilla
    • Oct 2012
    • 29
    Hello all,
    I have the above mentioned 52 inch LCD TV. It powers on , the screen flashes, then no picture. Audio is fine. No obviously blown caps on power or main board. Any ideas?
    Thank you
  • infringer
    Badcaps Member
    • Sep 2009
    • 244
    • United Frickin States
    Re: Samsung LN52B630 No picture
    you have audio but no backlights do you have 24v at your power connections. The connectors should be connect tv to power with cover off laying on the floor do not touch anything else with your hands or anything metal. Stick the probes on the black on the ground and red on the +24 when tv is turned on see what voltage you have.
    Be extremely careful not to touch anything not only could you create a lot more troubleshooting but you could end up in the hospital or dead if you do not exercise the proper precautions.
    Wearing rubber gloves and electrical taping the probes so that only a 1/8th inch of the probe is exposed will surely help your odds of doing this safely.
    Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
      This is power supply-backlights inverter board combination, so it does not use 24VDC for typical separate backlghts inverter setup. The inverter section runs on 400VDC power supply.
      Since this power supply has PFC voltage booster circuits, please check the DC voltage on the two legs of the large DC filter cap (check on either one) 450VDC, when TV is plugged in but not turn on it should have about 165VDC on it, when the TV is turn on and the power board receives the PS_ON from the main board, the voltage on the cap should go up to about 400VDC.
      Can you get closed up pictures of the connectors on the board so I can see the labels on them.
      And as infringer indicated, be real careful since you will be working on the primary side.
      What is the part number on this board?
      • moegilla
        • Oct 2012
        • 29
        tested the DC filter caps....got 164VDC plugged in not on, and 389VDC plugged in and powered..not sure what you meant by "connectors" so here are a few more pictures of the power board
          OK, the PFC is working, so that means the main board is also probably working (as it is sending the right power on signal.) In a dark room, can you see a dim glow from the screen? (Alternatively, on some TVs you can see a white glow from the holes in the back of the LCD panel.)
            There are connectors with mutiple wires connect to them, ther are lable next to them that tell us what they are (right now they partial blocked). I am looking for BL_ON pin.
            It looks like the pin23 is for INVERTER ON/OFF PIN, check the voltage on that pin.
            • moegilla
              • Oct 2012
              • 29
              how does one go about testing voltage on the pins? Ive attached closer looks at the connectors
                It is the other connector on the top right of the picture in my post6, black probe on the chassis, and the read probe just poke into the socket of the connector, your probe will have to be skinny one.
                • moegilla
                  • Oct 2012
                  • 29
                  which side is odd which even?
                    As you can see from the picture, there is label 1 for the top row (odd number) and 2 on the bottom row (even) in picture of post 6.
                    In picture in your post 7, then it will be the bottom row for odd, top row for even.
                    • moegilla
                      • Oct 2012
                      • 29
                      figured it out....5.08VDC
                        So pin 23 is 5V, if that is the case, the inverter transformer driver circuit is not working. I only expect about 3.3v or so.
                        • moegilla
                          • Oct 2012
                          • 29
                          any advice on the next step?
                          • moegilla
                            • Oct 2012
                            • 29
                            im gonna replace the four 1000uf caps see what goes down ill let cha know
                              By the way, is the fuse in the middle of the board OK? This fuse supply the power to the inverter circuit.
                              • moegilla
                                • Oct 2012
                                • 29
                                I turned the multimeter to 200 OHM, placed the leads on both sides and I get all sorts of readings , mostly staying from 1-10 but randomly jumps back and forth up to 180 ish and back down....doesnt stay consistent
                                  It should read less than 1 Ohm. Board is not powered right?
                                  Touch your two probes together, it should show less than one Ohm (test probe's resistance). Otherwise, remove the fuse and test it again.
                                  The meter's batteries is OK?
                                  • moegilla
                                    • Oct 2012
                                    • 29
                                    So I replaced the 4 caps and replaced both ceramic fuses on the power board and still same issue...
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
                                    • ohren
                                      by ohren
                                      09-08-2023, 05:24 PM
                                    • C152Heavy
                                      by C152Heavy
                                      Summary for TL-DR readers:
                                      • VCC pin (18) of PFC...
                                      01-11-2023, 02:53 PM
                                    • ermals
                                      Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                                      by ermals
                                      Hi all!
                                      I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                                      1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                                      2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                                      3. I've checked voltages...
                                      08-01-2022, 10:35 AM
