Possible purchase
  • lilmonk3
    • Apr 2012
    • 259
    Possible purchase
    I am stuck out of town with hubby all week and decide to shop the classifieds for some TVs.. I found an emerson with horizontal lines on bottom of screen and a samsung with vertical lines.. Whats your guys thoughts on these ..
    Re: Possible purchase
    Samsung is bad panel, don't touch it.
    I think the Emerson may be too, I can't be sure.
    • lilmonk3
      • Apr 2012
      • 259
      Ok
      • lilmonk3
        • Apr 2012
        • 259
        I asked about the emerson before and I think thats the same answer I got..
        • cadiman
          • Mar 2010
          • 397
          Vertical bar on plasma is burnt chip on the ribbon cable. All plasma tvs.
          I only had one tv where it was a circuit board.
          • freakaftr8
            • Oct 2012
            • 3743
            Agree with cadiman. 9 times outta 10 a vertical stipe/bar/line is unrepairable plasma panel failure.
            • Hobby 1
              • Mar 2010
              • 86
              No experience with Emerson, I stay away from them. Is the Samsung a plasma or LCD? If LCD and the price is low enough. I may risk it. Bad panel, yes, but I have fixed most that I have tried to. Just tonight, I fixed a Sharp 52 inch that had half the screen all messed up. One connection point was responsible for all of it. 15 minutes of trying spots on the panel. It will take hours to fix the plastic standoffs that cracked over the years. Still, not bad for $30.
              • kevinm34232
                • May 2012
                • 1884
                Where exactly did you find the problem and was this LCD or Plasma?
                • lilmonk3
                  • Apr 2012
                  • 259
                  I got the samsung, its an lcd. FREEEEEEEEEEE.... I figured when I got it back to the hotel and plugged it in that I would be able to flex the frame and she some changes, but I flexed the hell out of it and seen no changes.. The Emerson is also an LCD but I have not heard back from them.. I really dont need any of them, as I have 3 at home I need to get my a** back to working on but hubby and kid have kept me to busy to work on anything.
                  • lilmonk3
                    • Apr 2012
                    • 259
                    So I am guessing its not he tab bonds.. I wont be able to do anything else with it until I get home.. I did notice that there are 2 lines on the screen all the time and a 3rd one comes and goes..
                    • Hobby 1
                      • Mar 2010
                      • 86
                      It could still be tab bonds, not always possible to 'clear' them by flexing. May be at the circuit board end.
                      The Sharp that I worked on was model LC-52D65U. The tabs are on the bottom. The problem was a main connector on the left side. It was not holding the flat connector tight enough. The metal frame is 4 seprate pieces. Took only the bottom one off. Used a piece of dense 'heat sink rubber' between the connector and the metal frame to apply pressure. Will test for several days before closing it up. Still have to fix the cracked/broken plastic standoffs. It is a thin plastic frame model, not very strong...
                      • Stanley1843
                        by Stanley1843
                        06-29-2024, 11:54 AM
                      • jeyoung12
                        Samsung QN50Q60t lines on screen
                        by jeyoung12
                        Hi all
                        I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                        My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                        This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                        It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                        So....i don't know what end of the C ribbon to work with...
                        02-26-2024, 10:38 AM
                      • Rubenlily
                        Samsung QE50Q67TAU - horizontal lines
                        by Rubenlily
                        First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                        I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                        I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                        I'm no expert but I've done the tape...
                        08-16-2023, 01:12 PM
                      • ggil44
                        Sony XBR-65X750D Horizontal lines bottom of screen
                        by ggil44
                        Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                        05-30-2023, 07:51 PM
                      • x_orange90_x
                        Samsung UN46C8000XFXZA Horizontal lines
                        by x_orange90_x
                        I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                        I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                        07-15-2023, 05:06 AM
