RCA L32WD22, Power Supply Squeal, Re-Capped
  • kb0nly
    • Oct 2012
    • 12
    I have a 32" RCA TV thats driving me nuts, which is how i found this forum as some searching led me to a few threads here but i didn't really see an answer to my issue.
    Its model # L32WD22
    Suddenly it started making a loud noise, a high pitched crackling squeal. With my experience i figured time to recap it. I went online and ordered up a batch of caps from Digi-Key, since they are local to me here in MN i use them all the time.
    I re-capped the power supply, noise went away and the tv turned back on, awesome! I gave the tv back to a friend of mine that owns it and they used it for about two weeks, then it started acting up again, the squeal was back and it would randomly shut off on its own.
    I pulled all the caps i replaced, i have a desoldering station and it takes me a few minutes tops to drop all the caps out. Tested all them with my capacitor checker and they were all within spec. Soldered them back in and the squeal is still there. After hitting the power button and unplugging and plugging the tv in for about ten minutes i finally got it to power up and come on. But there was still a squeal that slowly went away after a while, its working for now but doubt it will last.
    So here is what i am thinking, it has to be the 100uf 450v caps on the power supply? Its the only two i didn't change because i couldn't find them, and they tested within spec, 95-98uF on both of them. But as they are the only two i haven't changed, and they are crappy Elite brand caps, i still suspect them.
    Would you spend the money to replace them or is it possibly something else?
  • drpj23
    • May 2012
    • 528
    Re: RCA L32WD22, Power Supply Squeal, Re-Capped
    Well what kind of caps did you use to replace them? If they weren't suited for power supply application then it would make sense why they took a turn
    Two, caps can still be bad even if the capacitance checks out OK
    • kb0nly
      • Oct 2012
      • 12
      All Nichicon low ESR caps from Digi-Key... As i said its not my first time rebuilding stuff like this, just second guessing what the heck is going on here this tv is driving me nuts.
      • kb0nly
        • Oct 2012
        • 12
        Now it won't always turn on.. And when it does turn on it runs for a random amount of time and then goes blank, no video, no sound, but the green power light is still on.
        If you wait it will come back all on its own, might take a few minutes, might take ten, but it will come back eventually. Turning it off when it does this makes the problem worse cause then it takes twenty minutes to fight it back on.
          It sounds like my RCA L26WD, I ended up replacing the main board, never did figure out what went out on the main board, did not have the time, spent $50 on the board 3 years ago, still using it everyday in my kitchen.
          • kb0nly
            • Oct 2012
            • 12
            I hope its not the main board. If it is this will likely get stripped down and recycled and tossed, the cost of the board is more then the tv is worth.
            I will try replacing the 450v caps first for the heck of it, only cost is about $6 for those, if that doesn't fix it i will salvage what i can and toss the rest.
              I fixed my 26" 3 years ago since they were still expensive at that time, I would not do it today, 32" is real cheap today, so you may be right to sell them for parts instead.
