Westinghouse LD-4655VX - My First LED
  • braveally
    • Oct 2012
    • 8
    Re: Westinghouse LD-4655VX - My First LED
    Originally posted by kevinm34232
    Here's ribbon I used:
    http://www.ebay.com/itm/AWM-20798-WF...#ht_1109wt_920
    I had other problems, the locking tab in the lower left corner where the ribbon attached to the LED's broke, and I had to rig it so it would stay put.
    Also the original cable routed inside the panel and then back out the bottom. I chose to go directly from the main board to the corner on the backside.. Don't think it would have been long enough the other way..
    Thanks for the link. My lock is a bit flimsy too but it seems to be holding for now. Since my last post I got the cable working by doing my best to repair it. Pulled back the cover, got all the wires lined up again and used some spare electrical tape to hold its position. I tested it and all lights came on and then about 4 in the corner went out. If i touched the cable, the rest of the half went out too.
    So I took the plastic panel that sits atop it (the thin one with the several screws and the one the clamps hold it down) and used some pliers to break off any plastic that would make contact with the cable (sorry no pics this time). I also did not screw in anything in that section too tight. It's working now with just a very small dim spot, barely noticeable, in the bottom right corner.
    Success for now. Let's hope it holds.
    • braveally
      • Oct 2012
      • 8
      So far so good. I wish I could have gotten it to where all were on but a dim corner the size of an ipod is much better than half the screen. Happy to be able to watch TV in the day light now.
      • jhawker
        • Dec 2012
        • 4
        • united states
        #43
        I have the same issue with my ribbon cable. I have never repaired a tv just a couple computers in my day. Excuse the stupid question but my cable says AWM 20706 and someone suggested this:
        I assume the AWM numbers do not matter? I too messaged a couple ebay users selling parts to the LD-4655VX and found one who had already sold the cables and said I was the third person this month to ask about them. Before I drop another $20 into this tv I want to make sure that cable will do the trick. I already bought a replacement main board thinking that was my problem when it is in fact this stupid cable.
        • kevinm34232
          • May 2012
          • 1884
          Yes that ribbon will work. Did you disco one ribbon at a time at the main board to make sure the TV comes on normally and figure out which one it is??
          Im surprised to hear all these issues, the TV I got was obviously dropped on the corner and the ribbon was smashed there. Did anything happen to your TV or did it just fail??
          • jhawker
            • Dec 2012
            • 4
            • united states
            #45
            Yes I disconnected one at a time. TV comes on with left ribbon disconnected. Nothing happened to my tv it just failed. It was turning itself off randomly and wouldnt come on for hours. Finally it just stopped coming back on. After some research, I thought maybe the board had bad caps so I bought a new board (never soldered and didnt want to mess with trying to figure out which one). $80 mistake. Then after finding this thread, I noticed my cable was burnt and had plastic melted off. Sounds like this will do the trick. Thanks a lot
            • kevinm34232
              • May 2012
              • 1884
              Are you planning on routing it the same as the original? Im not sure if its long enough, I didn't feel like completely disassembling the panel.
              • jhawker
                • Dec 2012
                • 4
                • united states
                #47
                I had planned on it. How does it need to be ran?
                • kevinm34232
                  • May 2012
                  • 1884
                  I ran it directly from main board down to corner on backside, not through the slot. That was the longest ribbon I could find and it barely reached that way.. You have to pull off the black plastic edging that holds the panel in to get to the other connector. You'll see what I mean.. sorry I didn't take photos, I was winging it and did what I had to do..
                  • jhawker
                    • Dec 2012
                    • 4
                    • united states
                    #49
                    Ok Im with you. I have already taken the old ribbon out so the black edging in already off. I just hope it goes back together like it should. I took it all apart without taking pictures as I went. Probably a rookie mistake but I did put the screws in seperate bags as I got to different layers of the tv so that should help. I emailed Westinghouse to see if they offer replacement parts but Im not holding my breath.
                    • aj800
                      • usa
                      #50
                      I grabbed this tv from someone that was going to recycle it and sure enough got it working by removing one of the ribbons. It now powers up and works great other than the one side being a little dark.
                      Are the ebay listings above the only options for ribbon replacements?
                      Major props to all as I found this site when researching the issue. Thank you! It doesn't compare to my panny Plasma but it will work great in my garage!
                      • asdfasdfasdf
                        • 6
                        • united states
                        #51
                        I'm trying like a madman to get this exact model to work. One morning it decided it wouldn't turn on after working perfectly the night before. There are no bulging capacitors or obviously burned/scorched components. I disconnected one ribbon and then the other and it would not turn on either time. I am running out of patience with this thing. Suggestions?
                        I'm only disconnecting the ribbon at the board-end. It seems to go *into* the television where I can't access it (as many screws as I removed I still couldnt get to the other side).
                        • kevinm34232
                          • May 2012
                          • 1884
                          If disconnecting the ribbons doesnt work perhaps it's the external power supply, do you get any power lights or indication it's getting power? Mine didn't come with the power supply and I had to buy it on ebay for around $15-$20 if I remember correctly. Check for voltage on the power supply cord first. I think it was 19v.
                          • asdfasdfasdf
                            • 6
                            • united states
                            #53
                            kevin, there is no life to this television. The remote wont do anything. I tried the tv power button. I tried the factory reset technique. I tried different outlets. No buzzing, no smoke, no smell. No visible defects in the board. No bulges. No burns.
                            At this point im thinking it could be the power adapter that goes to the wall, but I don't have another 19v adapter to test it with.
                            not a fun way to spend a sunday tbh.
                            • kevinm34232
                              • May 2012
                              • 1884
                              Do you have a multimeter to test the voltage on it?
                              • asdfasdfasdf
                                • 6
                                • united states
                                #55
                                well what do you know the left ribbon removal trick did the job...but I think I was a bit too rough with the tv when I was moving it around...
                                http://i.imgur.com/qLLVUQT.jpg
                                I know I'm stretching it by farrrrrrr... but is there a possible fix for those lines on the right side?
                                  Nope, you cracked the panel, it's ruined.
                                  • asdfasdfasdf
                                    • 6
                                    • united states
                                    #57
                                    well.. today is a very dark day for me...
                                      You can probably sell the parts inside it.
                                      • asdfasdfasdf
                                        • 6
                                        • united states
                                        #59
                                        where could I sell the parts? ebay?
                                        All I could think that would sell is the board itself... maybe a few cables?
                                          Yeah, on eBay.
                                          This TV only has one main board and it's in very short supply -- you should be able to get $50 for it.
                                          • scubacamper
                                            Sharp Aquos LC-70C6400U Half Screen Dark
                                            by scubacamper
                                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                            05-03-2025, 12:19 PM
                                          • zesko
                                            xps 9520 ribbon cable
                                            by zesko
                                            I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
                                            There is 2 models, idk which one is needed on my laptop.
                                            0xkvng
                                            00vpr2
                                            Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
                                            Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
                                            thanks...
                                            10-23-2025, 05:03 PM
                                          • Shinju
                                            Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                                            by Shinju
                                            Hey All!
                                            Long time forum member here with a problematic laptop issue!
                                            I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                                            The laptop would not power on with the new battery installed without the power supply being plugged in.
                                            When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                                            TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                                            10-20-2021, 04:58 PM
                                          • torchzack
                                            Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                            by torchzack
                                            Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                            I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                            Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                            08-28-2023, 07:42 AM
                                          • karatzdi
                                            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                            by karatzdi
                                            I know some might say... just buy another one. Sell it as parts..!
                                            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                            Spent some time downloading the Service...
                                            06-11-2024, 08:38 AM
