Medion digial TV tuner doesn't power on – Bulged capacitor in power supply
  • ntoskrnl
    • Sep 2012
    • 17
    • Finland
    I have a Medion digital TV tuner that has strange and varying issues powering up from standby. I opened it up and found out that a small 470uF electrolytic capacitor on the power supply board is clearly bulged.
    All the dozen or so secondary side capacitors on the power supply are G-Luxon, which is listed in the "Bad Cap Manufacturers" list. The primary capacitor is a Samxon, but I've heard that primary capacitors usually don't fail.
    If I were to replace all the secondary caps, is there something I need to consider, other than voltage, capacitance and physical size, when choosing replacement caps? Which caps would you suggest?
    I can take photos and give more details if necessary.
  • Peter9DO
    • Dec 2011
    • 277
    Re: Medion digial TV tuner doesn't power on – Bulged capacitor in power supply
    Nope all you want to look at is the physical size, capacitance and voltage. When I replace caps I only use Panasonic which I purchase from Mouser.com. Once you replace them it should fire right up, the problem you described with the power sounds like it's a cap issue. Then verified when you saw the popped cap. Good luck!
    • ntoskrnl
      • Sep 2012
      • 17
      • Finland
      Thanks! So I don't need to consider any ESR ratings or such?
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        We'd love to see some pictures
        • ntoskrnl
          • Sep 2012
          • 17
          • Finland
          Here are a couple of pics of the power supply board in question. The bulged capacitor is C13; other caps seem fine but might be dead anyway.
          • ntoskrnl
            • Sep 2012
            • 17
            • Finland
            I'm going to order some Panasonic FC, FM and FR caps tomorrow. Does this sound reasonable?
            The replacement caps are physically a bit larger, but the board seems to have room for them. The current caps don't completely fill the painted circles and the legs are bent.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              You should match the ESR too, I'm pretty sure Panasonic FC or FM will match, so go ahead and order them.
              A working TV? How boring!
                It looks like it's just a flyback; I thought ESR wasn't crucial as long as it was lower or the same? I'm an SMPS noob, but am considering taking a course on it in uni if the option comes up.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  I see a 8-pin chip on the primary, that's likely a 3842 or some derivative. ESR of the capacitor does play a role in the compensation of this type of circuit. It does not matter on self-oscillating supplies, in anything with a controller it will make a difference.
                    master hoarder
                    • May 2008
                    • 12175
                    It does not matter on self-oscillating supplies.
                    In my experience, it does.
                    I've seen the 2-transistor 5VSB circuit of 3 ATX PSUs now not regulate properly due to bad output capacitors.
                    I'm counting at least 5 diodes on the output of this power supply, so there may be up to 5 outputs. In any case, replace all of the capacitors on all of the output voltage rails.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      Bad capacitor = no capacitor, so it's obvious it will act up. Let me rephrase that: In self-oscillating supplies, the lower the ESR, the lower the ripple. Regardless of what caps it had in the first place. When a controller is involved, things aren't that simple and you have to match the specs of the originals as close as you can.
                        master hoarder
                        • May 2008
                        • 12175
                        Ah, I see what you meant now.
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                          03-31-2024, 02:12 PM
                        • triplefour
                          JVC LT-55UE76 has bulged cap on power supply, spilled electrolyte.
                          by triplefour
                          got this tv from a friend who got a new one and didnt want to bother repairing this one.
                          he said it sometimes would just flash color patterns.
                          and sometimes it would just work
                          i figured it had some intermittent mainboard issue.
                          i stored it at home for a while before looking at it
                          when i plugged it in for the first time, i heard some popping noises
                          and then a big cloud of white smoke came out of the back of the tv!
                          i noticed the smoke didnt actually smell like anything. not like when an IC blows.
                          i unplugged it and took the back off and discovered...
                          12-18-2022, 12:38 AM
                          07-01-2024, 06:34 AM
                        • shamsudeen
                          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                          by shamsudeen
                          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                          i know that in linear power supply the noise will be very low comparing to SMPS supply....
                          07-19-2025, 07:14 AM
