LG 42" LCD TV 42LG50 - Will not boot, continuous rebooting, no display
  • KennyC
    • Sep 2012
    • 9
    This weekend my LG 42" LCD TV decided to go blank as I was watching it. It then began constant rebooting, accompanied by a "pop" from the speakers (not an electronic/circuitry pop, thank goodness!), and that now repeats for as long as you want while it's plugged in. There is no display. The only response you get from the TV is the power indicator will pulse like a normal startup, then the "pop," and then the repeat. I couldn't find anything quite like that using search, so here I am.
    I took a quick video of what it does:
    http://www.youtube.com/watch?v=KUCq00gsD8Y
    (again, the "pop" is from the speakers, NOT directly from the TV circuitry!)
    I haven't opened to TV up to investigate yet - about to do that now. But here are the specs:
    LG 42" LCD TV
    42LG50-UA
    42LG50-UA.BUSHLJM
    Manufactured June 2008
    I know it's not a whole lot to go on at the moment, but if anyone has any pointers or has seen something like this before, please let me know! Thanks!
  • KennyC
    • Sep 2012
    • 9
    Re: LG 42" LCD TV 42LG50 - Will not boot, continuous rebooting, no display
    Didn't find anything obvious inside - no bulging caps, no fried components. Forgot to check for blown fuses (oops) but I will. Any hints on where they're all located on this thing?
    The only thing I noticed was that there is a small green LED on the main board that does come on when the TV is plugged in. It flickers off and then back on as it reboots. I will say that it seems to reboot right when I believe the screen should be powering up.
    Attached are some pics of the internals.
    • tibimakai
      • Jan 2012
      • 3680
      I'm struggling with a 42LG70, mine it's shorted something in the power supply.
      There are two fuses, one it's in the center of the board and the other at the red connector.
      • t.j.
        • Apr 2010
        • 383
        • canada
        here link to service manuals! the might have something on it in the trouble shooting section~!
        just enter lg 42lg50 an it will pop up list of manuals for you!
        http://elektrotanya.com/?q=showresult
        • KennyC
          • Sep 2012
          • 9
          On a whim I decided to unhook the T-Con board from the main board. And...it powered up and stayed powered up! Not that I could see anything, but both the power indicator on the front and the LED on the main board indicate that it's booted "normally" (minus the screen, of course).
          Pic of the T-Con board is attached.
          So, probably a bad T-Con board? Anything I can do to confirm that, or do I just go ahead and replace it since it's a relatively cheap part?
          • Mr Bill
            • Nov 2011
            • 648
            Check the fuse on the tcon is about all i can recommend. I'm going to go look in my box of goodies and see if i have a tcon. It looks very familiar.
            • Mr Bill
              • Nov 2011
              • 648
              The ones i have aren't the same. You'll need to match the numbers on the white sticker on the left side. 35-D023305
              • KennyC
                • Sep 2012
                • 9
                Thanks for checking!
                Fuse is good. For anyone else reading, I found this thread which has a great reference on this exact T-Con board and how to find and check the fuse.
                One thing I did notice after I unhooked the T-Con board and started it up was that the backlight does blink once but doesn't stay on. Not sure if that's significant or not. I just hope it's that the TV is smart enough to realize that the panel isn't working and turns off the backlight and isn't an indication of a bigger problem!
                Anyway, I think I'll go ahead and order another T-Con board. It seems like a pretty good gamble at this point.
                • Mr Bill
                  • Nov 2011
                  • 648
                  I think the tcon has to tell the inverter to turn on via that small flat cable on the side of the tcon.
                    Do you have the LCD panel model number? I need to see the spec and find out if this T-CON has the ERROR signal out put pin or not. Did you check any DC voltage on both ends of the fuse on the T-CON yet?
                    • KennyC
                      • Sep 2012
                      • 9
                      Is the picture I posted above have the LCD panel number? If not, I can look again.
                      10V on both sides of the fuse. Of course the voltage drops to zero as it reboots/resets.
                        OK, it is Chi Mei model V420H1-L12 Revision C1. Let me see if I can find the spec sheet for it.
                        OK, I found the spec sheet, the T-CON board only receive signals from the main board, the T-CON does not any feedback pin that goes out to the main board to tell its condition if it is good or bad.
                        So the T-CON may have short circuits and load down the voltage on the main board, the main board may have current sensing circuits to see how much the T-CON board is pulling the current, if too much current being pulled, the main board tells the circuits to shutdown, that is my theory. You may have to download the TV service manual to verify.
                        See page 15 of the spec sheet for the pin out of the T-CON board.
                        On page 8, you have indicate that you are getting 10V at the T-CON fuse, the min VCC for T-CON is 10.8V, typical is 12V which I also expect, not 10V. That may be an indication of the problem, you need to leave the T-CON cable disconnect and check the VCC pin on the main board side to see if you still have 10V also, I expect to see 12V. pin 48~51 are the VCC +12V pins, just trace out those pins on the main board side connector.
                        • KennyC
                          • Sep 2012
                          • 9
                          Thanks! I'm getting 12.38V on those 4 pins.
                            "I'm getting 12.38V on those 4 pins" with T-CON board disconnected?
                            • KennyC
                              • Sep 2012
                              • 9
                              Yes, with T-Con disconnected.
                                So when the T-CON is connected, the voltage drops down to 10 V and also causes the voltage to swing up and down. It looks like you have bad T-CON board, you can try fixing it or replace it.
                                • KennyC
                                  • Sep 2012
                                  • 9
                                  I have a replacement on the way; should be here Thursday or Friday. I'll be sure to report back once I get it in. Thanks again, you've been helpful as always!
                                    Keeping my fingers crossed.
                                    • KennyC
                                      • Sep 2012
                                      • 9
                                      It's alive!!!
                                      New [to me] T-Con board installed and all is good! Super big thanks to everyone here. I wouldn't have even tried this if it wasn't for this forum.
                                        Nice to hear you fixed it.
                                        • privato89
                                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                          by privato89
                                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                          Let's begin:
                                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                          03-26-2024, 06:37 AM
                                        • hinisa
                                          Xiaomi router freezes at boot after re-capping
                                          by hinisa
                                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                          07-08-2023, 05:58 AM
                                        • Luke Anders
                                          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                          by Luke Anders
                                          A few details about the laptop itself:
                                          Name: Lenovo Legion 5
                                          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                          BIOS Version: GKCN60WW
                                          EC Version: GKEC65WW
                                          Serial Number: PF39AQ7Z
                                          Board Model: NM-D562 Rev 3.0
                                          RAM: 16GB Installed, DDR4 (brand new)
                                          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                          I bought this laptop recently from eBay as a faulty device....
                                          10-12-2024, 05:13 AM
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                        • torchzack
                                          Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                          by torchzack
                                          Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                          I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                          Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                          08-28-2023, 07:42 AM
