47 insignia lcd tv
  • ricosavy
    • Jul 2012
    • 457
    • united states
    47 insignia lcd tv
    wanted to see what you guys think if it is a good deal for 50 dollars and what could be wrong with it by picture .thanks
    Re: 47 insignia lcd tv
    That is a good deal, the main board, power supply board, the inverter board, and the stand total are worth more than $50.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Could be as simple as a bad voltage regulator on the mainboard. Worst case, one of the chips on the mainboard is fried.
      Muh-soggy-knee
      • ricosavy
        • Jul 2012
        • 457
        • united states
        thanks for feedback will buy it.will post pictures soon as i get it .
        • ricosavy
          • Jul 2012
          • 457
          • united states
          Well bought the tv unfornately I think I might have a bad panel one of the tcon ribbon gets hot and starts to burn ribbon strip.I tried another ribbon did the same thing it is the left side the rights seems to be fine.will post pic in few phone won't allow it
          • Mr Bill
            • Nov 2011
            • 648
            what panel is in it? Had a westinghouse 47" that had the "glowing black screen" and the panel was the fault.
            • cajoeg
              Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
              by cajoeg
              Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
              The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
              02-10-2025, 04:01 PM
            • zomi
              Manual cof bonding success rate ?/ feedback wanted
              by zomi
              Just wanted to get some feedback,
              whats peoples' success rate with cof bonding repairs.....
              09-23-2024, 12:45 PM
            • valvashon
              Insignia NS-LCD19-09 (third and final post, hopefully!)
              by valvashon
              I have been going round and round with this one for a couple of years. It's a 16x10 display that allows you to size your OTA picture correctly to 16x9 and that makes it kind of cool so I really want to keep it on my OTA monitoring wall. Accidentially let a screw roll under the powered power supply board and ended up replacing the MOSFET drivers for the inverters, then one of the Schottky rectifiers for one of the supplies, then the PS caps becuase I fired the parts cannon at it one day.
              Problem was no cold startup; it would only startup when you applied a heat gun to the board....
              10-22-2025, 12:33 PM
            • valvashon
              Insignia NS-LCD19-09 no standby LED; (new problem)
              by valvashon
              Having a new problem with the 19" Insignia that I modified with one of my automatic turn on circuits. That is now completely disconnected so that is not the issue. I was doing some modifications on that circuitry and managed to short something out on the underside of the power board.
              Actually found and bought the service manual (who knew it was even available?!) which brought me to the High Voltage Startup Circuit controller chip.
              Looking up that chip number- LD7575APS brought me to the attached datasheet. I have marked my voltage readings on the schematic sheet (open in new...
              08-30-2023, 10:41 AM
            • tbsmith
              Insignia NS-50F301NA24 No standby power, no +Va, Vm, +Vl etc.
              by tbsmith
              There is voltage on the bridge rectifier and main caps (163V). Fuses all check good. One of the smaller electrolytic caps (C9112 which is 50V, 100uF) looked bloated, it measured 60uF with one tester, and defective with another. I replaced it temporarily with same uF rating, higher voltage since I don't have the exact one. I also found that one of the switching mosfets (for lower voltage DC supply I think) was shorted. It is a 50R800CE which I didn't have, but had something with the same voltage and current rating and a similar Rds. None of these fixes helped. I'm out of ideas. Any suggestions...
              08-11-2025, 06:15 PM
