LG Plasma 50PC1DR- Y-SUS Issues
  • cheebster
    • May 2008
    • 374
    #141
    Re: LG Plasma 50PC1DR- Y-SUS Issues
    i didnt swap any ipm on the zsus. it seems the ysus is more prone to failure ?
    do you have a clue can be causing that w9nk70z chip to blow ? they take away a resistor (smd) and the 2 bigger smd resistor. i've replaced the chip 2 times now from chips from a spare z-sus, but it blows everytime. batch code isnt the same but it seems that it's the good chip..
    it seems to be the 'ramp_up' circuit, and it blows right away on tv startup. the ramp_up pot is not working since the circuit is broken, and i have no control on it
    i wish i could understand why is that thing blowing !!
      Which chip is it that blows? Didn't you have the same problem with TV #2, and it was a bad IPM that killed it?
      • cheebster
        • May 2008
        • 374
        #143
        its the w9nk70z that blows, with the 2 10 ohms smd resistors and another resistor. see picture attached !
        well had many issues.. but all were somehow different
          Here's where a scope would be handy. I'll bet SUS_OUT is doing something it shouldn't. If SUS_OUT remains high for too long, then the 5 ohm resistance will be shorted to ground by that FET. High current ~40A will flow, frying the FET and resistors. Perhaps somehow the gate drive to the FET is faulty or perhaps the IPM is at fault.
          • cheebster
            • May 2008
            • 374
            #145
            um. the gate drive.. that's the circuit around the fet itself ?
              Yes. I think it gives it a ramp signal on the gate, which generates the RAMP_UP drive. If it's stuck high, maybe the FET is stuck ON, leading to failure.
              • cheebster
                • May 2008
                • 374
                #147
                so im probably missing something bad around that area on the board..
                  Possibly. You could do a comparative volt meter with your working boards. Check the gate pin of the mosfet.
                  • cheebster
                    • May 2008
                    • 374
                    #149
                    im having issues with some ipm i fighted with earlier. its got missing traces and its nearly impossible to do a proper job with the heatsink installed.
                    if im using thermal paste and cyanoacrylate on the black plastic tabs, would you think the ipm heatsink will stay there without falling down ?
                    crazy glue is pretty strong so on both sides.. maybe even adding a tab of sillicone on 4 sides after it's dried up, on the 4 sides of the heatsink between the heatsink and the pcb... sounds weirdo, or could be ok ?
                      I really have no idea, as I have never replaced an IPM, and plan to avoid it! If you are using any kind of glue, make sure it has good thermal conductivity. Most are very good insulators, making the heatsink less effective... and those IPMs run very hot.
                      • cheebster
                        • May 2008
                        • 374
                        #151
                        I've used m4 10mm screws from the top of the ipm (just drilled the plastic holes in ipm + heatsink a bit bigger) and screwed from the top. perfect !
                        just one thing im wondering, those ipm's run quite hot do they ? even to hot to touch.. should i add some (maybe 80mm) fans to those units ? is really the heat the cause of their failure ?
                        i was thinking of adding at least 1 fan on each side of the plasma on the ER IPM.. the one that runs hotter
                        still one y-sus to fix on that 3-plasma project found a few burnt resistors near the fet that always shorts.. maybe it was just those smd resistors that ive missed that got that thing shorted every time.
                          I think it's a combination of heat and early IPM design that leads to their failure. But I'm not at all sure. Adding a fan might help.
                          • cheebster
                            • May 2008
                            • 374
                            #153
                            Good morning. I was wondering, while looking for buffer chips, if there was any x-references for the lg buffer chips on 50pc3d buffer boards..
                            On the lg boards, they are SN755866. Looking around, i thought, i could use a cheap buffer board with similar chips and use the ic's, would be cheaper.
                            Here is what i've found, a vizio buffer for 9$ with many ic's. the chips look similar, but are the 2 ic models compatible ?
                            I wasnt able to find exactly what it was, but i can see FC or something on the chips.
                            Here is the board itself from the vizio :
                            http://www.ebay.com/itm/271069140173
                            And here is a better hq picture of it..
                            http://i.ebayimg.com/t/LG-6871QDH117A-YDRVTP-/00/s/MTA2NlgxNjAw/$T2eC16dHJGkE9no8iPiUBQQ2jRNbmg~~60_57.JPG
                            It seems to be FC or FE.. Anyone has a clue what they are and if it's the same ic by a different mfg ?
                            Thanks in advance !!
                              It's FE, I don't know if they are compatible but if the boards share the same part # they probably are.
                              • cheebster
                                • May 2008
                                • 374
                                #155
                                Okay. Grrrrr...
                                I have another issue with one ive fixed here, where it does horizontal lines across the display. ive swapped z-sus and it didn't change anything, voltages are all set according to panel, ive messed with vsetup, vsetdown and that other pot on the ysus but i can't get rid of those lines.
                                What can cause such lines and how can i fix this ? is it caused by the panel aging, is this something i could fix using the service menu ?
                                ive tried messing with vs and va as well, it didn't change anything.
                                  Buffers, possibly. Care to share a picture?
                                  • cheebster
                                    • May 2008
                                    • 374
                                    #157
                                    okay, after a few minutes the screen became all purpleish. here is what it looks like
                                    http://www.youtube.com/watch?v=zqggVr__vVI
                                    those are the lines..
                                    then it started going purple
                                    http://www.fusioninformatique.com/temp/purple.JPG
                                    • cheebster
                                      • May 2008
                                      • 374
                                      #158
                                      its not the buffers, i just swapped them from the good working set.. will continue swapping boards
                                      • cheebster
                                        • May 2008
                                        • 374
                                        #159
                                        not the ysus either...
                                        • cheebster
                                          • May 2008
                                          • 374
                                          #160
                                          here is what i get with 1 top buffer connected on a hdmi input with no signal (i know half of the screen is off, bottom buffer is missing)
                                          it's blue lines that moves a little bit.. pixels move around
                                          so far i've swapped the ysus, zsus, 2 buffer boards, power supply and it's still doing it
                                          at the bottom of the tv, there's some other buffers there ?
                                          • PlasMatt
                                            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                            by PlasMatt
                                            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                            09-20-2025, 06:50 PM
                                          • Burglicious
                                            Samsung PN59D6500 Plasma TV issues
                                            by Burglicious
                                            Hey all, i have a Samsung PN59D6500 that I rescued from the dumpster and I'm trying to fix it. So the issue I am having is that the TV isnt turning on at all. I have VS,VA,VSC,VE at all the appropriate voltages. I have 3.3V at the PS-On, and 5V also. Whats happening is when i press the power button on the remote the TV has has the relays click, some pixels flash on the screen and then it seems to turn off. It repeats this until the TV is unplugged. I know that the Mainboard has a problematic EEPROM but this seems kinda like a power regulation issue. Anyone have any ideas?
                                            12-09-2021, 09:03 PM
                                          • pixelcap
                                            Pioneer Kuro Pro 111FD 8 red blink error
                                            by pixelcap
                                            Pioneer Kuro Pro 111FD 8 blink red LED.
                                            I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
                                            So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
                                            based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
                                            10-06-2024, 11:26 PM
                                          • SoulFreeze
                                            Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                                            by SoulFreeze
                                            Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                                            After repairing the above issue, I realized the following remaining problem,
                                            Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                                            The computer recognizes headphones are connected and displays a popup in windows
                                            Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                                            06-21-2025, 09:53 AM
                                          • Phlox321
                                            Samsung plasma tv PS43D450A2 pixel issues
                                            by Phlox321
                                            Hi guys. I have a Samsung plasma Tv with a wierd prpblem.its a samsung plasma PS43D450A2. A little history : I got the tv free from someone as the thought the power supply was bad and was about to throw it away. I check it and found shorted x main board. I found the diodes and igbts were shorted. After a long search for components i aquired them and replaced them. The tv then worked fine for a few months and about 2 weeks ago it started showing random yellow and purple pixels only on about the right of the tv. Its clearly cisible on a white screen but not as noticeable when watching a movie. And...
                                            04-12-2020, 03:58 AM
