Sony KDL-46NX810 No Video
  • Gadjet
    • Aug 2012
    • 248
    Just got this one in, it's the first LED TV i've worked on.
    When you hit the power button, the light turns green and the Sony logo below the screen lights up, but the screen is still black. Tried hooking up a dvd player to see if it was just the video but as far as I can tell there is no audio either
    or ability to change the inputs. Let me know if I need to post pics of anything. Thanks.
  • drpj23
    • May 2012
    • 528
    Re: Sony KDL-46NX810 No Video
    Pics are very nice.
    Um I suppose check what voltages are going to the LED drivers and T-CON.
    And make sure other voltages are checking out too.
    Check the smd fuses on the main board and T-CON too.
    Is there still an image? (Shining a light at the screen)
    If you disconnect the LVDS cable from the T-CON does the backlight come on?
    Make sure connectors are snug (especially the ribbon to the panel from T-CON)
    • Gadjet
      • Aug 2012
      • 248
      Ok here are some pics or the main board and PSU, anyone know where I can find the service manual for this model? or how am I suppose to know what voltages I'm looking for? I know with plasma tv's the voltages are on a sticker on back of the lcd somewhere. I'll also post some of the TCon and Backlight.
      • drpj23
        • May 2012
        • 528
        The voltages should be on the board itself next to the connectors.
        If you do want the service manual, all it has is the codes and schematics. It does not have a troubleshooting guide. Training guides have that (well extensively as compared to SM's and in this case only).
        Here is a link to the manual (I made the link so it's safe), it's too big for this forum so I had to upload elsewhere otherwise you can't find it.
        http://www.mediafire.com/view/?gabzwqdu0r02rxx
        • Gadjet
          • Aug 2012
          • 248
          Thanks for the manual, I added a few more pics of what happens when I turn the tv on and off. used a flashlight can't see anything.
          • Mt.Man
            • 53
            When you loose video, does the TV shutdown? If it shuts down does the power LED blink? And if blinking how many blinks?
            • Gadjet
              • Aug 2012
              • 248
              Thanks for the reply, I'm not losing video I'm not getting any video at all when the power turns on nothing happens no blinking LEDs or anything. It's green as if everything is working okay.
              • drpj23
                • May 2012
                • 528
                Are the voltages checking out OK? and are there voltages present on the power supply even if the tv is in standby?
                • Gadjet
                  • Aug 2012
                  • 248
                  Voltages look right, all of the 12v ones came up 12.53v. and no the voltages don't show when it's in standby.
                  • drpj23
                    • May 2012
                    • 528
                    Ok, what are the voltages coming out of the power supply to the backlight?
                    How are the fuses on the T-CON and Main? (If you have a hard time finding them include high def pics and I'll help you because they are sometimes incognito against the other components)
                    • Gadjet
                      • Aug 2012
                      • 248
                      Sorry about the delay, yes I need help identifying the the fuses on the T-Con and Main Board. Pics of the Main are at the top and I'm including pics of the T-Con now.
                        Pictures are way out of focus, I can see two fuses on the T-CON board.
                        • Gadjet
                          • Aug 2012
                          • 248
                          I took a few more hope these are a little better. I checked the 2 budm circled, and the ones on the inverter.
                          • drpj23
                            • May 2012
                            • 528
                            I found some on one of the main board pics. (circled in red...there are 3)
                            Basically you are looking with a component prefix of "F" and accompanied by an amperage rating. Sony's arrows are sometimes ambiguous though.
                            Also there will be some on the other side of the main board.
                              Since you see some of the fuses now, next thing is to find out if they have any voltage on them with reference to the chassis ground.
                              • Gadjet
                                • Aug 2012
                                • 248
                                Ok so I replaced the BUHT main board and now the red led comes on for a few sec and I start getting this 2 flashing leds.
                                the green power led and the amber picture off/timer led
                                • drpj23
                                  • May 2012
                                  • 528
                                  Does that happen consecutively or with the power button?
                                  How many times do the two LEDs flash?
                                  And does the SONY logo still light up?
                                  • Gadjet
                                    • Aug 2012
                                    • 248
                                    Continuously as far as I can tell there are no breaks in between the flashing. and Yes the logo still lights up when you turn on the power then goes out once the Led start flashing.
                                    • drpj23
                                      • May 2012
                                      • 528
                                      All I can really say is get a T-CON and try that with old and new main......otherwise I have never seen that before.
                                      But to be sure, list the voltages off the power supply in respect to the legend.
                                      Example
                                      Pin 1 - 12v - 12.56v
                                      • Gadjet
                                        • Aug 2012
                                        • 248
                                        Ok update, I disconnected the ribbon that goes to the Tcon to the BUHT and hit the power just to see what would happen and the screen lit up and started changing colors so I figure it's some type of self-diagnostic test. Red led was still on then after about a min the screen shuts off and flashes 5 times.
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • iglitare
                                          by iglitare
                                          09-04-2025, 07:13 AM
                                        • rimwall
                                          Sony KD-65x7500D - double image - Tcon or Panel?
                                          by rimwall
                                          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                          11-18-2025, 02:09 AM
                                        • thelankanguy
                                          Sony KD-55X9000F TCON Issue
                                          by thelankanguy
                                          The TV shows a black screen with no image.
                                          TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                          Later both ribbons were disconnected and TCON voltages were tested.
                                          12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                          There is also a short to ground in this circled inductor.
                                          Is this a TCON issue or something else ?...
                                          12-13-2024, 12:27 AM
