Sharp LC-52D64U-Negative picture
  • buuhaahaa
    • Aug 2012
    • 22
    • US
    Had this tv for about 3 years and it developed this "Negative Picture" like a photo negative. Sound on this set works fine, negative picture is on all inputs. Did a reset from diagnostic screen(Volume down+Input>Connect power etc.....) same result. Found a video on Youtube(2 years old, fix in comments- http://www.youtube.com/watch?v=UEfa-...eature=related ) featuring a Samsung LCD with the similar issue and took the tv apart found the said board to be insulated from touching any metal so the problem wasn't there. Found this thread( http://www.avsforum.com/t/1170984/so...d/forumId/166# ) with a Sony Bravia, similar issue and their end result was the T-Con board. Swapped the T-Con with another from Shop Jimmy, same problem. Found a few other threads saying it was the Main bd(would be my next move unless I can get some better advice here). Just looking for some useful help without having to spend an outrageous amount of money to fix this tv ~Aloha~
    Re: Sharp LC-52D64U-Negative picture
    Have you tried these steps? They apply for LC-32SD1E but may be similar enough:
    http://www.tgohome.com/ServiceManual...epair_tips.txt
    • buuhaahaa
      • Aug 2012
      • 22
      • US
      Yes I tried a bunch of Diagnosis tweaks but no beans :/
        I would have suggested T-con. The only board left that could cause this is the main board. Although are the power supply voltages good? What does the T-con run off?
        • buuhaahaa
          • Aug 2012
          • 22
          • US
          Just popped in a T-Con fresh from Shop Jimmy and no change in problem. The odds on it being bad too and producing the same issue is.........I'm no tech, so not sure.
            It's possible, though unlikely. The T-cons on shopjimmy are reclaimed from cracked screen TVs so could be faulty.
            • buuhaahaa
              • Aug 2012
              • 22
              • US
              Any other vendor worth trusting for a T-Con? "New other (see details)" runs around $50 US....USED $20-$30. Which route would you take for another T-Con
                ShopJimmy have a warranty, don't they? Ask if you can exchange it as you suspect it's faulty.
                • buuhaahaa
                  • Aug 2012
                  • 22
                  • US
                  Was just going to send it back, but yes I'll ask them later today(1:11am here)
                  • buuhaahaa
                    • Aug 2012
                    • 22
                    • US
                    sent them a message about an exchange, so I'll need to wait and see what their response is. But I hope someone can recall anyone else having the same type of picture problem I have and what the remedy was......hopefully not a bad panel.
                    • buuhaahaa
                      • Aug 2012
                      • 22
                      • US
                      Contacted ShopJimmy about their T-Con board(discoloration and cracks can be seen in their advertised pics, if you zoom in) and they gladly exchanged it for another. Hmmmmmmmmmmmm, same discolration on the new board but not as bad no cracks. Same negative image result. My guess that the T-Con board is not the issue. Has anyone seen or heard about the symptoms that my TV is having??? Suggestions on any test to try???
                      • drpj23
                        • May 2012
                        • 528
                        As tom66 said, it's either between the t-con or main. Since main processes video signal I would go for that.
                        • buuhaahaa
                          • Aug 2012
                          • 22
                          • US
                          Yep, and if that fails....I got a 52" box of spare parts
                          • buuhaahaa
                            • Aug 2012
                            • 22
                            • US
                            @tom66 or anyone who can help......
                            Replaced main board and symptoms changed. Connected the power and I get 2 clicks. TV doesn't fire up. Green OPC and Power lights flash together once then the green Power light flashes once by itself then repeats. Thanks.
                            • drpj23
                              • May 2012
                              • 528
                              Make sure everything is seated correctly. Does the new main board match the old one (i.e part number not just board number)
                              • buuhaahaa
                                • Aug 2012
                                • 22
                                • US
                                OK, I did a "force power on" Hold channel down+Hold volume up and then connect the power cord. TV fired up but negative image issue resumes. Any ideas?
                                • buuhaahaa
                                  • Aug 2012
                                  • 22
                                  • US
                                  New board is an exact match with the old one(only 2 types for this model). I put the old board back in and the TV fired up normally(with negetive image) Put the new board in again same clicking no power, did the force power on and the TV fired up with the negative images. Probably could get the TV to fire up with the new board if I clear the error codes in the diagnostic mode. But got the kids running around right now so it'll need to wait. Any Ideas?
                                  • drpj23
                                    • May 2012
                                    • 528
                                    This is a long shot, but LVDS cable. You could test continuity between each connector to see if the problem is "prevention of data" lol. Or altering thereof.
                                    Or could be those boards on the side of the panel.....but this is seeming more likely.
                                    • drpj23
                                      • May 2012
                                      • 528
                                      Actually, that may be hard to do, well there's a cable kit on ebay for $25
                                      Also, what T-CON is in it, the old or new?
                                      Oh and out of curiosity what happens when you turn monochrome on under the settings?
                                      • buuhaahaa
                                        • Aug 2012
                                        • 22
                                        • US
                                        T-Con #3(2nd one from ShopJimmy)is in there LOL. Monochrome doesn't do much but remove whatever color is left in the negative image
                                        • MikeRWK
                                          Sharp LC-32D40U Negative picture unless the contrast is almost 0
                                          by MikeRWK
                                          This only affects the picture but not the tv menus. Selecting any of the default picture settings gives a negative picture but turning the contrast down to 5 'fixes' it but then the tv is too dim which is hard to tell in the pictures.
                                          This tv has a main board, scaler board, and a tcon.
                                          I tore it down so I could probe the tcon which is nicely labelled. I've also included a pic of it.Here are the voltages I got:
                                          VGH 32V
                                          VGL -6V
                                          GAM1 14.6V
                                          GAM18 185mV
                                          VLS 14.67V
                                          3V 3.01V
                                          RESET 2.95V
                                          TCLK 0V
                                          SCC_VDD...
                                          01-30-2021, 05:21 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • BeeShadow
                                          Sharp lc-70le755u flickering picture/backlight
                                          by BeeShadow
                                          Hey everyone! I inherited a "free" Sharp lc-70le755u with a strange picture issue. To try to explain, the picture flickers before what I think is a power saving mode kicks in and reduces the back light. I took a short video and uploaded it here:
                                          https://imgur.com/NAou7aP
                                          I'm thinking it could be the TCon board, but possibly the panel. Thought it might be worth it to post here and see if anyone has a better idea before I try throwing parts at it. If its the panel (which I hope its not), then I won't bother trying to fix it.
                                          07-01-2021, 08:32 PM
                                        • Mgiffune
                                          by Mgiffune
                                          I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                                          I ordered a supposedly β€˜new' Tcon board this time, and
                                          06-09-2024, 10:28 AM
