Panasonic P42X20E 4 red blinks
  • V3dran
    • Aug 2012
    • 28
    • Bosnia
    Hello, 2 week ago my panasonic P42X20E stopped working giving 4 red blinks.
    The board that certainly must be replaced is the SS (the tv service near me tried to fix it but is not possible), but maybe also the SN.
    When I turn on the TV I get as I said 4 red blinks, the led on the SN is not on.
    Is there a way to test if I must also change the SN board before the SS replacement?
    Here are some pics of the boards.
    Thanks for the help
  • V3dran
    • Aug 2012
    • 28
    • Bosnia
    Re: Panasonic P42X20E 4 red blinks
    Ok, I got the tv back and tried to isolate the SS board (removing the conncector SS23), still 4 blinks
    If I isolate the SN board I get 6 blinks (7 removing also SN20).
    Am I correct or the TV must work if the SS board is isolated and everything else is theorically ok? It's a 13 gen panel
    In my case the SN board should be fried for sure (no green led on it)?
      Do you have a DMM?
      • V3dran
        • Aug 2012
        • 28
        • Bosnia
        Hi tom, yes I do, can you please tell me what I have to check?
          Check the voltage on the brown and white wires going to the SC/SN board.
          • V3dran
            • Aug 2012
            • 28
            • Bosnia
            Ok, I'll check it tomorrow since is late and also I have to replace the battery of the MM since is gone.
            I'll post the results tomorrow
            • V3dran
              • Aug 2012
              • 28
              • Bosnia
              Ok, I setted the DMM on DCV 200, removed the connector SN2 and probed, it shows 200 when I turn on the TV, then goes down.
              The same with the SS11 connector on the SS board
              • V3dran
                • Aug 2012
                • 28
                • Bosnia
                Before the TV "clicks" :
                P11 pin1 200V then goes down
                P11 pin4 14.9V then 0
                P2 pin1 200V then goes down
                I also noted some black parts on the connectors P11 SS11 and P2, SN2 is ok
                If the boards are connected I get 0 on any pin if I'm not wrong
                  So you are saying the 200V ("Vs") drops when the SN is plugged in? In which case, the fault is on the SN.
                  • V3dran
                    • Aug 2012
                    • 28
                    • Bosnia
                    Everything is connected as should be:
                    P11 pin1 0
                    P11 pin4 15V
                    P2 pin1 0
                    P2 (Vsub to SN) disconnected:
                    P11 pin1 0
                    P11 pin4 15V
                    P2 pin1 0
                    P11 (Vsub to SS) disconnected:
                    P11 pin1 0
                    P11 pin4 15V
                    P2 pin1 0.5V
                    Both P2 and P11 disconnected:
                    P11 pin1 200V
                    P11 pin4 15V
                    P2 pin1 200V
                      This points to either both boards being bad or one board interacting with the other. Can you disconnect the brown flex connector on the right hand board (SS) and repeat the test with and without power going to it. It could be a bad panel.
                      • V3dran
                        • Aug 2012
                        • 28
                        • Bosnia
                        I removed the connector SS23 on SS witch goes on the C2 board:
                        P11 pin1 0
                        P11 pin4 15V
                        P2 pin1 0
                        Then I tried to remove all the connections on the SS (SS11, SS23 and SS3):
                        P11 pin1 0
                        P11 pin4 15V
                        P2 pin1 0.5V
                        Don't tell me that it is the panel
                        I hope that only SS and SN are bad
                          I'm talking about both of these connectors on the SS.
                          Disconnect both and SS power.
                          • V3dran
                            • Aug 2012
                            • 28
                            • Bosnia
                            Removed both flex and the power on SS still 0V on both Vs connectors
                              Measured at PSU or SN?
                              • V3dran
                                • Aug 2012
                                • 28
                                • Bosnia
                                Every time at PSU
                                  OK, it could be a power supply problem. I'm trying to think of a good way to test it. Can you get old of a 60W or 100W incandescent light bulb rated for 230/240V operation? Touch it across the Vs terminals, and if it goes dim (try to test Vs voltage while doing this) then the PSU is at fault. It's a bit new to me. Some Panasonic plasmas don't power up when boards are unplugged too, which makes troubleshooting difficult.
                                  • V3dran
                                    • Aug 2012
                                    • 28
                                    • Bosnia
                                    Yup I have a light bulb 100W 230V
                                    But I don't understand how to test it.
                                    Should I connect the active and the neurtal terminal of the light bulb with two wires on the connector on the PSU?
                                    Anyway what is sure is that if I remove both powers (SN and SS) I get 200V on both connectors, if anyone power is connected I get 0V on both connectors...
                                    • V3dran
                                      • Aug 2012
                                      • 28
                                      • Bosnia
                                      I found this manual
                                      As I understand the command 10 PANEL MAIN ON on the slide 27 is not applied
                                        Yes, see if the bulb lights up. It will be a little dimmer than at 230V AC but should be lit brightly. If possible, test the Vs voltage at the same time. It seems either both boards have faults (unlikely in my opinion), or the PSU is incapable or some how it won't work if just one is unplugged (some kind of lock out.)
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                          by sam_sam_sam
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • canadaboy25
                                          Panasonic TC-P54VT25 No image. A or D board?
                                          by canadaboy25
                                          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                          The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                          01-17-2021, 01:06 AM
                                        • Biruslapio
                                          Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
                                          by Biruslapio
                                          Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
                                          It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
                                          It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
                                          02-16-2021, 09:44 PM
