Samsung LN32B460 turns on only after repeated attempts
  • Dardo
    • Aug 2012
    • 22
    My 2 year old Samsung LN32B460 recently started turning on only after multiple times pressing the power button.
    I press power and the standby light will blink off for about a second, then blink on and off quickly then stay lit. It will usually do this 2 or 3 times after each press of the power button. Eventually it will turn off for a second, on again and finally back off and the set will turn on. There are no problems once it is powered on.
    It is not one of the Samsungs know to have problems turning on due to bad caps, and there is no clicking sounds when turning on. I pulled the power supply out looking for bad caps, but found none that looked suspect.
    Any ideas what the problem might be, or what my next steps should be?
    Re: Samsung LN32B460 turns on only after repeated attempts
    Can you post good clear pictures using attachments, not posting in line?
    Bad caps can look normal but they can have high ESR, you will need ESR meter to test them.
    We will need to check the voltages when it does not work and when it is working to see what is going on.
    • Dardo
      • Aug 2012
      • 22
      Thanks for the reply Bud. Unfortunately I do not have an ESR meter, but I can replace the caps if they are the most likely problem. I do have a good multimeter to test voltages, if i know exactly where to test. I am attatching some images of the ps board and one of the main board.
      Thanks again
        I would try this next before trying to replace the caps. Use the hair dryer set to low and then blow it around the caps and see if the TV will turn on OK.
        • Dardo
          • Aug 2012
          • 22
          I tried the hair dryer with no visible difference. The problem only seems to be getting worse...it will only turn on every 10 or so attempts now. Any other suggestions what to try next?
            Try cleaning the power button - does the same thing happen with remote control?
            • Duncanbest
              • Jul 2012
              • 81
              • Taiwan
              If the switch board is OK, maybe one of PHOTOCOUPLERs on power board is NG.
              (The standy +5V PHOTOCOUPLER is good.)
              They are not seen in the pic. -->SMD type in other side.
              • Dardo
                • Aug 2012
                • 22
                Thanks for the replies. Now the standby light only blinks a few times after pressing power...it won't turn on after many attempts.
                Tom - I get the same response using the power button or the remote.
                Duncan - I have posted pics of the back of the PS and main boards. Can you point out which photocouplers and how to test or diagnose if they are the problem?
                • Duncanbest
                  • Jul 2012
                  • 81
                  • Taiwan
                  Power board (in the middle) mark PC801S PC802S PC803S are photocouplers.
                  You can download PC817 or PS2561AL-1 datasheet to verify .(or read the mark to find the correct photocoupler.)
                  How to test? -------- I really don't know.
                  I always replace with new component (try & error),seldom use meter to check.
                  • selldoor
                    Slow Learner
                    • 7870
                    To do a proper check you need an analogue meter however you can do a very basic test with a multimeter set on diode - NO power to the set - test across the secondary cold
                    side and report result.
                    I am wondering if it is just the startup cap failing. On the primary hot side one of the small caps should be 50v 10 47 or 68uf is usual - I would change that.
                    Schematic for this board is here
                    • Dardo
                      • Aug 2012
                      • 22
                      Sorry I'm a noob at repairing electronics. You mean test each pin on the connector leading to the main board I assume?
                      There are 3 50v 47uf caps and one 50v 22uf cap on the hot side, is the 22uf one the startup cap (CM808 on the schematic you provided)?
                        You power supply is almost the same as this:
                        https://www.badcaps.net/forum/showth...hlight=SAMSUNG
                        The startup cap is the ZM804 47uf 50V.
                        Loo at the voltage on the main DC filter cap CP 815, it should have 165~170VDC hwen TV is plugged in, then it should go up to about 400VDC when power switch is activate, look at pin1 of CNM802, you should have steady 3VDC or more when power switch is activated, so look for that when you first activate the power switch, if it is there and the TV still does not come on, the it will be the problem in the PFC not getting the power to kick it on.
                        • Dardo
                          • Aug 2012
                          • 22
                          Thanks Budm
                          I get readings on CP815 of 162VDC plugged in, 378VDC when the power button is activated.
                          On pin 1 of CNM802 I get 1.18VDC when the power button is activated.
                            378V, even if set doesn't power up fully?
                            • Dardo
                              • Aug 2012
                              • 22
                              Yes, it goes to 378V while the standby light flashes for a few seconds, then back to 162V. If plugged in when CNM802 is disconnected, the backlight comes on and it reads a constant 378V.
                                OK, what about the other supply voltages, like 13V?
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  ZM804 is a zener diode on the secondary side I think Budm means CM804
                                  • Dardo
                                    • Aug 2012
                                    • 22
                                    The 13V all get 13V when the power button is activated, the 5.3V get 5.1V.
                                    Standby gets a constant 5.1V
                                      You are right, I made the typo, it should be CM804. But since the backlights do come on and the boost voltage is OK, then something on the main board is telling it to turn off the PS_ON signal so the votgae goes back down to 162V if I read post 15 correctly, but I do need to find out if at the same time the PS_ON also goes down. I think the problem is in the main board. Does it stay on if the T-CON board is disconnected?
                                        I would suspect main board problems then. Everything on the PSU seems to be fine. One final check - INV ON/OFF does this go HIGH (>2V) on every power up or just the ones that succeed.
                                        • paul85
                                          Samsung un40h5003 turns on when plugging it in
                                          by paul85
                                          I have a weird one. My in laws gave me a un40h5003 Samsung LCD TV that turns itself on when you plug it in and neither the power button on the TV nor the remote do anything, but other buttons do.
                                          Simple issue I figured, so I opened up the back, and unplugged the power button on the TV from the cable. Retested and it still turns itself on automatically. I pulled the batteries out of the remote and even had the remote in another room and same thing.
                                          Any ideas why this would be happening? No obvious capacitor issues, no bulging, no issues on either power or main board...
                                          12-04-2022, 04:58 PM
                                        • EvansEssence
                                          Samsung UN55D6003SFXZA TV turns off after 20-30 seconds
                                          by EvansEssence
                                          Hey guys! I saved an older Samsung tv from the recycle bin to tinker with as a hobby. Looking for some help as to what else to check/replace.
                                          The issues it had at first was it would randomly reset its picture settings, this slowly devolved into it rebooting itself and the control board becoming unresponsive. Now it has finally gotten to the point where it no longer turns itself on when plugged in, but when I turn it on with the remote or power button it will boot to a blank input work for 15-20 seconds then turn itself off. I found if I pull up the menu it will actually freeze my...
                                          02-04-2023, 08:49 AM
                                        • PowerAmpFreak
                                          Samsung UE40C6005 turns off and on by itself
                                          by PowerAmpFreak
                                          I've got a Samsung UE40C6005 which turns itself on and off as it wants to. It's exactly as I use the remote or the touchstrip on the front.
                                          My question is if this could be related to a faulty touchstrip and is it possible to disable the touch but keep the remote reciever operating (placed on the same pcb which has Samsung P/N BN96-13047G
                                          It would be ok to skip the touch function and only use the remote. Anyone know the pinout of the ribbon cable ?...
                                          03-14-2022, 11:31 AM
                                        • thetonywarren
                                          Samsung un32j5205af turns on, but needs to have power disconnected to power back on
                                          by thetonywarren
                                          SAMSUNG UN32J5205AF
                                          Wierd issue. Set turns on, works as normal, then turn off, and when you try to turn back on, it wont. The backlight comes on, but doesnt boot up. You need to disconnect power supply from back, then reconnect it, and then the set works again. somewhat annoying issue.
                                          Where to start? I can provide any videos or pictures needed to troubleshoot.......
                                          11-15-2022, 09:23 AM
                                        • MarkH8729
                                          Samsung UN46D6050TFXZA turns itself off 30 seconds after start
                                          by MarkH8729
                                          The TV turns on fine. TV started turning off on its own about 30 seconds after I power it on a couple of days ago. Ran just fine about 5 hours before this started happening but had been off for those hours. Problem started the first time after that. I have turned it on from the remote and from the front panel and see no difference in behavior.
                                          I have been able to turn it on multiple times and change channels and volume. The picture is good. The set just doesn't want to stay on.
                                          Based on info I found online, I have tried a soft reset (unplugged the TV for as much as...
                                          06-26-2023, 06:50 PM
