Samsung LN32B460 turns on only after repeated attempts
    Re: Samsung LN32B460 turns on only after repeated attempts
    Inductor, 4.7uH.
    • Dardo
      • Aug 2012
      • 22
      I'm still trying to pinpoint the problem and I managed to get service manual for this tv. I do have a question about the troubleshooting manual, it states voltages as A, B, or DDR (e.g. A5V, B12V, DDR1.9V). I'm assuming A is for standby-mode and B for power on, but I'm not sure about DDR. Can someone give me a clue? I've included the applicable pages from the manual.
      Thanks.
        DDR is for the memory bias voltage, it is difficult to explain but it should only be there during normal operation. Are all the outputs of the PSU within good tolerance, or are they too high?
        • Dardo
          • Aug 2012
          • 22
          The PSU outputs are within good tolerance. Following the troubleshooting guide, the voltages on the main board are within tolerance with the exception of BD104, which should be 12V, but tests at 13.07V. That is the only reading that is too high.
            09-07-2024, 05:50 AM
          • Egidio85
            Samsung UE55F8000SZ Turns on and off immediately
            by Egidio85
            good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
            This defect happens continuously, hearing the classic click of the relay every time.
            Power supply board BN44-00636B
            disconnecting the mains and lamps from the power board always causes the same problem.
            Is it normal that without anything connected this power supply turns on and off cyclically?
            any suggestions on what to check?
            thanks in advance
            03-11-2025, 12:45 PM
            09-06-2024, 11:40 PM
            09-06-2024, 08:40 PM
