bush lcd32tvoo22hd
+ More Options
Posts
  • Seandubh
    • Aug 2012
    • Ireland
    bush lcd32tvoo22hd
    This tv keeps reverting to standby when I try to switch it on. Is this a serious/expensive problem, should I buy a new tv?
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: bush lcd32tvoo22hd
    hi it maybe best to post this in this part of the forum section here you will get more response.
    Troubleshooting TVs and Video Sources
    • Krankshaft
      • Jan 2007
      • 2328
      Thread moved.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Thanks Krankshaft
        Sean
        Welcome to the forum - havent given us much to go on - could be one small start up cap (easy) or could be firmware IC (Almost impossible) A new board would fix it. Also we no nothing about you.
        We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
        Examples of what is needed
        https://www.badcaps.net/forum/attach...1&d=1290283049
        https://www.badcaps.net/forum/attach...7&d=1280167246
        It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
        • FlailingEngineer
          Help with Bush Tv (Vestel 17mb95m Mainboard)
          by FlailingEngineer
          Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
          Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
          05-31-2023, 06:52 AM
        • tyler123456
          Need help identifying an IC chip on a Bush DAB radio (BD-1801)
          by tyler123456
          Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
          I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
          I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
          Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
          Anyone...
          08-16-2024, 12:51 PM
        • Johnny.p
          Bush WI-1810 Internet Radio
          by Johnny.p
          I recently bought an internet radio Bush WI-1810, it came with a power supply that when plugged in promptly damaged the radio. I discovered too late that the radio was 6v and the supplied adaptor was 12v. The radio still powers on but the wifi is not working. I have attached a few pictures- Image 2 showing the board with damaged component top right labelled U8. There are several other similar components like U9 (image 3) that I'm wondering could be a replacement.
          U9 has a code on it S5EJI- I have searched several smd code sites and the nearest I can find is for a mark of S5E -listing shows...
          11-25-2023, 04:18 AM
        • razzer05
          Bush LE50GY15M - Firmware needed, Please!
          by razzer05
          I did a silly thing and tried to update the tv (Bush LE50GY15M) with a "allupgrade_6308rtbm.bin" off the internet with the same board name "T.MS6308.U701" and it now no longer works.
          I have researched quite a bit since Fridays messup, I've gathered a bit of information and tried multiple "allupgrade_6308rtbm.bin" files off the internet to try and fix it.
          The information I've come up with:
          A possible clone of "SEIKI SE50UO01UK" with a Bush Logo
          The board is as mentioned: "T.MS6308.U701"...
          09-23-2020, 03:43 PM
        • stav242
          BUSH DLED43IHDHDRS 17MB130S Firmware needed
          by stav242
          i have a BUSH DLED43IHDHDRS.
          the MB - 17MB130S is not booting - it did once then wont boot again.
          Suspect its the corrupt firmware issue.
          Where can i find the correct firmware for this model ?
          11-02-2022, 03:39 AM
