bad lamp on lc-32sb21u
  • ricosavy
    • Jul 2012
    • 457
    • united states
    I have a sharp lcd tv that when i plug it in it starts flashing green power led.I read on post that says to go in service mode and look see if you have bad bulb.I tried to go into service mode but would not let me.So i did the capacitor remove and jumper trick and was able to get into screen that says k.I looked aty screen i see dark spot looks like lamp maybe out.just wanted make sure it was if you guys can take a look at pic tell me what u think.
  • ricosavy
    • Jul 2012
    • 457
    • united states
    Re: bad lamp on lc-32sb21u
    here is pic
    • ricosavy
      • Jul 2012
      • 457
      • united states
      Any one where I can buy backlight lamp
      • killian6pk
        • Apr 2010
        • 502
        www.ccflwarehouse.com
        www. lcdparts.net
        www. lcdmonitorrepair.net
        Have you ever stopped to think and then forget to start thinking again?
        As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
        • tibimakai
          • Jan 2012
          • 3680
          How you did that K?
            That looks like service mode to me - just restart TV.
            • ricosavy
              • Jul 2012
              • 457
              • united states
              i put tv in service mode because the green light would blink then shut off read that it might have bad ccfl .if u look at picture u can see black strip which makes me think it is bad bulb.the tv would not go into service mode so i took off c7558 and placed jumper and and restarted tv pushed - vol and input and bing service mode i read this one of threads here how to do this even had pic.
              • vestaviascott
                Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                by vestaviascott
                Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                Here's what happens:
                1) Power on
                2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                3) Blue status light flashes for appx 4 minutes...
                07-29-2020, 06:08 AM
              • AJ847.63e
                BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                by AJ847.63e
                Hi All.
                Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                09-18-2023, 06:42 PM
              • mikey5791
                Help on Samsung Syncmaster T220 dead ccfl lamp
                by mikey5791
                This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                10-18-2020, 03:17 AM
              • khelane
                test active pfc power with lamp test
                by khelane
                Hello
                I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                Is there a way...
                06-03-2025, 01:00 AM
              • Yanleb
                Sharp LC-60LE810UN Lamp Error
                by Yanleb
                I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
                I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
                Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
                I've tried all the key...
                08-24-2021, 11:48 PM
