DVB recorder box crap
  • sienoki
    sienoki
    • Jan 2012
    • 314
    There seems 2 be tons of these crap boxes failing..whats causing them 2 fail?
    Any1 here worked on 1..looking at a neighbours 25008DTRADG which has fail displayed & nowt works on remote etc..done the unplug wait 5secs then hold power button at front for 5 secs while pugging it in..it show pls wait then FAIL is displayed..any 1 got any..thx
    Re: DVB recorder box crap
    HDD failure - is it spinning up, got a spare drive to test?
    • sienoki
      sienoki
      • Jan 2012
      • 314
      Hi tom..yeah ive a spare sata hdd..shall i just format it then stick it in the box?..could i use hdd regenerater to check & fix bad sectors..thx
        Worth a shot, as far as I know these things use a custom file system though; if you install a blank disk it may pop up with a message asking you to format.
        • sienoki
          sienoki
          • Jan 2012
          • 314
          Its a WD hdd installed..i thought these where good hdds..anyways i will see how it goes
            All HDDs fail eventually.
            • sienoki
              sienoki
              • Jan 2012
              • 314
              installed spare hdd & the lcd display lit up then pls wait then fail..with original hdd lcd not lit up so im gonna put hdd in my pc & check for & repair bad sectors & see how that goes
                Check all supply voltages. There should be 12V and 5V for HDD, and possibly other supplies e.g. 3.3V or 1.8V.
                • sienoki
                  sienoki
                  • Jan 2012
                  • 314
                  No bad sectors found..the hdd has 3 partitions 2 must be file systems & 232gb for storage..checked voltages & all seems to be good so stumped again..this will probably be heading for the
                  unless i could figure out how to recover them 2 file partions & copy them on another hdd..but how far do you go
                  • sienoki
                    sienoki
                    • Jan 2012
                    • 314
                    Was going over psu 16PW810S when checking the zenor diodes D22 has continuity both ways..thats wrong yeah?..the diode has a marking of 48 on it..could this be the culprit..thx
                    Tested fine after measuring again..nevermind put it away & get sum kip
                      Oh god it's a Vestel PVR! Their TVs are bad enough! Pull the zeners and test.
                      • sienoki
                        sienoki
                        • Jan 2012
                        • 314
                        Neighbour has now given me this as i cant get it working as yet..any of you guys recommend a good PVR thats gonna last..thx
                        • japlytic
                          • Oct 2005
                          • 2086
                          Some PVRs have poorly designed power supplies, of which can be fatal to connected hard drives if certain rails are not monitored and a critical rail goes out of tolerance - I saw that happen to a Thomson DTR6000AU unit.
                          • sienoki
                            sienoki
                            • Jan 2012
                            • 314
                            Ive figured out this set is a Vestel T845 Top Up TV..so from doing allot of research im gonna try a software upgrade with a usb r232..ordered 1 from ebay & ive got the bin file so fingers crossed it might be saved from the
                            • sienoki
                              sienoki
                              • Jan 2012
                              • 314
                              Usb rs232 flashing worked a treat so its saved from the
                                Great to hear. I had a Freesat HD box with the same issue but I just sold it on, should try flashing it next time.
                                • sienoki
                                  sienoki
                                  • Jan 2012
                                  • 314
                                  I joined digital spy forum & got all info needed there..tom would u have a gander at my neon tv when youve settled at uni..if get it fixed split it when sold?..or pay u 4 ur time..thx
                                    We'll have to see how much time I have available, possibly have to be over the weekend. I arrive 18th Sep, but teaching starts on the 24th. I'll only bring my scope and meter, not much else.
                                    • sienoki
                                      sienoki
                                      • Jan 2012
                                      • 314
                                      Thx..its sat there doing nowt so theres no rush fella..PM me when youve nowt doing
                                      • Sus256
                                        HISENSE 65E7KQ PRO - no boot
                                        by Sus256
                                        Hi all!
                                        HISENSE 65E7KQ PRO
                                        RSAG7.820.13512 - chassis
                                        MT9618BAATAB - cpu
                                        RSAG7.820.12059 - power
                                        HD650Y3U77 - panel
                                        KLM8G1GETF - emmc
                                        The TV does not turn on, the standby indicator is on. All voltages are present.
                                        Emms is dead. Not readable, not detected.
                                        Replaced emmc.
                                        But with another dump there is no launch
                                        Terminal log
                                        UART
                                        AC_ON
                                        RPMB key is not yet programmed
                                        HASH1_VERSION=0x00000000 64bit
                                        E-B
                                        FDE enabled
                                        layout pattern onebin by SAR7,0...
                                        06-01-2025, 02:11 AM
                                        DVR recorder Switching power supply Failure
                                        by sam_sam_sam
                                        When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
                                        Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
                                        This...
                                        05-27-2023, 03:03 AM
                                      • Sojke
                                        IT8585E Programming
                                        by Sojke
                                        How to program IT8585E on RT809F (H) programmer?
                                        It wont work on ITE_ADAPTER_V1.5 board (IT8580, IT8586, IT8587 work when soldered on board)
                                        Please help.
                                        I tried with cable for keyboard it does not work either (Laptop is G750JZ)
                                        005: The currently selected:IT8585_ISP @PEB-1, capacity: 1Mbits, 128Kbytes.
                                        006: http://www.ifix.net.cn/thread-47221-1-1.html
                                        007: >------------------------------------OK---------------------------------------<
                                        008: Wait for the chips enter into the ISP status, please wait...
                                        009: Wait...
                                        10-28-2021, 01:35 PM
                                      • dragometin
                                        Hitachi 40HYC42
                                        by dragometin
                                        TV Model: Hitachi 40HYC42
                                        Power Supply: 17IPS71
                                        MainBoard: 17MB95M
                                        Panel: VES400UNDS-2D-NO3
                                        When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                        I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                        Is there any variants on 17IPS71 power supply's?
                                        UART output pins 10 and 12 on scart connector:
                                        Code:
                                        12:24:04.595
                                        08-08-2024, 05:53 AM
                                      • Perry Babin
                                        Capacitors of the same make/series that consistently fail in one amplifier while they rarely fail in a different make amp
                                        by Perry Babin
                                        This is for car audio amplifiers but I doubt that matters. There are amplifiers that use the same make/series capacitor as a different manufacturer and they consistently fail in one brand. In the other they are OK. The amplifiers are from the same era. Is it possible that the heating profile used when flow-soldering the boards could be the reason for the failure? If not, any ideas on what the difference could be?
                                        04-03-2024, 10:40 AM
