philip 42PF9630A/37s noise bars
  • awyatt2
    • Feb 2012
    • 407
    • america
    got a philips with noise bars 3/4 up the screen from bottom anyone had this before? pics will follow camera batterys are charging now. model of tv is 42PF9630A/37. present on all inputs and even the menu.
    Re: philip 42PF9630A/37s noise bars
    Bad Y buffers.
    • awyatt2
      • Feb 2012
      • 407
      • america
      thanks tom, searching for the boards now. uses a samsung panel at least.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        this thread is very helpfull
        http://www.avsforum.com/t/917869/pro...f9630a-37-help
        • tony359
          by tony359
          11-28-2023, 05:18 AM
        • MegaZAC
          Onkyo TX-SR805 noise in one channel
          by MegaZAC
          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
          There's some logic behind it. As soon as I select an input I get only left...
          04-23-2025, 10:09 PM
        • courtcircuit
          Philips HTS8000 home cinema noise problem
          by courtcircuit
          Hello
          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
          Removed each of tyhe boards
          02-08-2025, 08:22 AM
        • Akira81
          LG 55LF652V-ZA flashing led bars despite their replacement
          by Akira81
          I have this 55" LG 55LF652V-ZA smart TV which suddenly started flashing intermittently every 2 seconds with the backlight.
          If I aimed the light bulb of my cell phone I could see the underlying image even in those fractions of time when the LEDs were off and the audio instead came out continuously.
          Armed with a lot of space and patience, I decided to open the TV, immediately noticing that a LED had flamed out and also burned a portion of that reflective white panel behind the transparent LED diffusers.
          04-14-2023, 11:50 AM
        • karatzdi
          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
          by karatzdi
          I know some might say... just buy another one. Sell it as parts..!
          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
          Spent some time downloading the Service...
          06-11-2024, 08:38 AM
