Sony KDL-46S4100 No Backlight Video or Audio
  • budro
    • Mar 2012
    • 17
    I have a Sony KDL-46S4100 that the backlight will not come on. Power light turns on steady no flashing. Even with a source plugged in you cannot get the input to switch to it to turn on the screen. If I disconnect connector CN303 I get the Blue, Red, Green test pattern. So I know the inverter board, panel and backlight work. I tried a different main or A board and had the same results they both have the exact numbers just different serial's at the bottom. Tested the fuse on the T-con board and getting power through it. Here are the voltages I am getting at the power supply connectors:
    Powered ON:
    CN301
    1-15.71v
    2-15.71v
    3-0v
    4-0v
    5-7.18v
    6-0.01v
    7-3.44v
    8-3.44v
    9-3.43v
    10-0.01v
    11-0.01v
    12-0.01v
    13-11.60v
    14-0.00v
    CN301 Powered Off:all are 0.00v except pins 2,7,8,9 these are 0.05v
    CN302 Powered on Powered off
    1-0.00v 1-0.00v
    2-0.00v 2-0.00v
    3-3.28v 3-3.29v
    4-3.28v 4-3.29v
    5-0.00v 5-0.00v
    6-0.00v 6-0.00v
    7-0.02v 7-3.28v
    CN303 powered on Powered off
    1-0.00v 1-3.25v
    2-0.17v 2-0.06v
    3-N/C 3-N/C
    4-1.69v 4-0.22v
    5-0.00v 5-0.00v
    I know pins 1 on CN303, 1 on CN302, & 7 on NC302 are all low voltage or 0volts which control the backlight circuits. My question is do these voltages come from the power supply or are they returned to the power supply board from the main or A board?
    Any help would be greatly appreciated. I have ordered a power supply but wanted some others opinions as well.
  • selldoor
    Slow Learner
    • 7870
    Re: Sony KDL-46S4100 No Backlight Video or Audio
    Hi - we can do little without pictures of your boards even with your good description I have no idea where C301 goes from/to. As the test screen works
    it suggests problem with the main board rather than the power supply.
    Welcome to the forum-
    We can help a lot more if you please post a good clear pictures of the whole chassis and wires, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...1&d=1290283049
    https://www.badcaps.net/forum/attach...7&d=1280167246
    • budro
      • Mar 2012
      • 17
      All 3 of the connectors I measured go to and from the powersupply and main board. CN301 is in the upper right corner of the power supply, CN302 and CN303 right under it. I have uploaded the pics of the chassis, main board (green one on the right with all the jacks) and power supply (yellowish orange board)
      • Rudy.ALvarez91586
        • Sep 2012
        • 22
        • California
        I unplugged my cn303 and i didnt' get a test screen so which is the inverter board i have the same problem on my tv
        • budro
          • Mar 2012
          • 17
          My problem was in fact a bad main board. I got another one and it worked flawlessly. If your backlight doesnt come on at all I would look at your voltages on the power supply first. As far as the inverter board it is the board at the far left of your tv looking at the back of it. Have you tried using a flashlight and seeing if you see any thing on the screen? If you dont see anything at all it may be more than just the inverter board.
            The long board on the far left is not really inverter board, SONY called it Balancer board because the inverter board is part of the power supply board (it is inverter/power supply combo board) as you can see the high voltage transformer on the top left, the Balancer board receives the high voltage and distribute it to each lamps.
            • Rudy.ALvarez91586
              • Sep 2012
              • 22
              • California
              okay well i did the voltage readings I had all about the same readings as budro except for Pin 4 on cn303 read .002v instead of .22v when powered off
              • Rudy.ALvarez91586
                • Sep 2012
                • 22
                • California
                I also put a flashlight to it there is absolutely nothing on the screen that i can see as far as the serial number to the boards that i might need i get those off the barcode sticker on yellow board and the barcode sticker on the cover of the green board right
                • DiamondTech61
                  SONY BDV-E4100 powered off during update
                  by DiamondTech61
                  Hi guys I have a SONY BDV-E4100 blu ray player that was powered off during an update, I have read the sony guide and it says press function till it displays BD on the screen but its not changing, it only says TV on the internal display and no output to the TV screen at all. I also noticed that when eject is pressed the drive ejects but wont go back in, even when pushed. Can this be re flashed any way?
                  10-05-2022, 07:17 AM
                • Carlos#2003%
                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                  by Carlos#2003%
                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                  02-15-2024, 07:52 PM
                • dkneyle
                  Sony KDL-46HX850 Can't upgrade/update firmware
                  by dkneyle
                  Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                  Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                  09-25-2024, 10:44 PM
                  Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                  This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-06-2024, 05:27 AM
                  Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                  This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                  09-06-2024, 05:30 AM
