LCD backlight replace with LED Strip Light ?
+ More Options
Posts
  • Sevenqi
    • Jul 2011
    • 292
    I saw some good LED Strips from ebay, they all mention very bright, working voltage is 12 or 24, wondering if someone used it to replace the LCD TV backlight.
    If it works, then it's a great idea to repair/replace the LCD TV has backlight/Inverter problem, and can bypass the inverter, most importantly, it's more energy saving!.
  • bigdozer
    • Jan 2011
    • 46
    Re: LCD backlight replace with LED Strip Light ?
    https://www.badcaps.net/forum/showth...hlight=memorex
    Hope that works. Mine is still working. I put it in the shed. Sometimes if the inverter is bad and its on the same board the power supply wont function. My ccfls were bad.
    • roy.zhero
      Sharp LC50LE752E no picture and backlight, indicator light is lit
      by roy.zhero
      I acquired a free 50” TV. IT is a Sharp LC50LE752E. It does not show a picture and has no backlight, although the indicator light turns blue meaning it has turned on.
      When power is plugged in, the indicator light will turn on blue, the backlight stays off and nothing is visible, even with a flashlight. When pressing the touch buttons on the tv nothing happens. When pressing buttons on the remote control the indicator light will blink indicating the IRsignal was received, but nothing happens.
      When I hold the force-on-combination it will turn on. It then shows a perfect...
      09-20-2020, 01:57 PM
    • cashkennedy
      Onn onc18tv001 with one bad led
      by cashkennedy
      I've had this ONN ONC18TV001 for about 5 years. My wife left it on 24/7 as a night light so not too surprised it broke where the screen was still displaying the picture just there was no Backlight. The power/mainboard had voltage for the back lights but when you turn it on it starts high over 100v then within less then a second would go down to 30 something volts if I remeber correct. I figured I should check for a bad LED since that's certainly a common failure on these. I did find one LED that I doesn't light up using the diode setting on my multimeter. There is one other thread about this TV...
      08-25-2024, 11:42 PM
    • learnmore
      Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
      by learnmore
      Hello Community!
      CASE DETAILS
      Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
      13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
      Tried inserting firmware on USB and left it in for a few hours, but no change
      03-03-2024, 09:49 AM
    • lostone
      Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
      by lostone
      Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
      First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
      When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
      05-19-2024, 11:40 AM
    • unimatrix93
      Which resistor should I remove/replace to decrease current to backlight leds?
      by unimatrix93
      Dear community, I want to increase the lifespan of my backlight led in my TV by decreasing the current.
      However I need some help identifying the resistor I need to replace to achieve this.
      Thank you!
      11-29-2024, 05:05 AM
