KDF42WE655 G1 board replaced but...
+ More Options
Posts
  • flash0151
    • Aug 2012
    I have a sony wega KDF42WE655 it had the 6 blink problem I looked up the service manual and it indicated i needed to change he G1 board which I ordered and replaced. After replacing the non-refundable $175 board my tv it still the same and I am stuck with a broken TV and a board I can not return. Can someone please give me some guidance.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: KDF42WE655 G1 board replaced but...
    Does it still blink 6 times? Check that you have replaced all connectors in fact unplug clean and reconnect ALL removable connectors.
    Please post the link to the service manual to save us looking for it.
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...1&d=1290283049
    https://www.badcaps.net/forum/attach...7&d=1280167246
    It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
      Very few boards are non refundable, who did you order with? Seller could have sold you a faulty one - quite common!
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • ermals
        Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
        by ermals
        Hi all!
        I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
        1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
        2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
        3. I've checked voltages...
        08-01-2022, 10:35 AM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • cheeky2
        Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
        by cheeky2
        For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
        See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
        01-08-2024, 05:56 AM
