Sylvania 6842pe won't turn on
  • gayler
    • Aug 2012
    • 23
    • Kearny
    Hi everyone! First post here. I'm from Lakin Kansas. I have a sylvania 42'' monitor that won't turn on. I've identified two bulging 1500uf 200v caps in the power supply. and have them on order. Is there anything I need to look at whiie waiting for thes parts? Thanks everyone!
  • selldoor
    Slow Learner
    • 7870
    Re: Sylvania 6842pe won't turn on
    If it was your set how did it start to break down. Wont turn on?? means lots of different things to different people. If the caps are still on the board give us a description of what happens from the time you plug in - pressing the on button- up untill it reaches a stable fault stage. Say what the panel does and what any led lights do. Try in a darkened room
    to see any flashes. Does the sound work are there any other noises clicks hisses etc.
    Try and get some good pictures as follows
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...1&d=1290283049
    https://www.badcaps.net/forum/attach...7&d=1280167246
    It will be useful if you can say a bit about yourself - skills tools etc.
    We can then suggest a few tests while you wait.
    • gayler
      • Aug 2012
      • 23
      • Kearny
      The guy I got it from said he was watching it and there was a flash across the screen and it went off. Now when you push the power button you here a click and the power light comes on for a second and then back to standby. Never any picture or sound. I do have some electronics experiance as I' built a lighting controler for christmas displays. I've also built a 5F1 tube guitar amp. I have several multimeters including a fluke, bluepoint and craftsman. I have soldering irons and guns ranging from 25watt to 300 watt.
      • selldoor
        Slow Learner
        • 7870
        Ok if you can post pics of the fronts of any boards and one of the overall
        layout that will do for now - back may be required later.
        What is the board part number of the power supply? - may have a second
        small mains filter board as well.
        • gayler
          • Aug 2012
          • 23
          • Kearny
          I'll try to get pics later tonight. It does have a smaller filter board before the other connected to the power cord connection
          • gayler
            • Aug 2012
            • 23
            • Kearny
            Sorry, no pics yet. I did put in the two caps I ordered and they did not fix the problem, although when I hit the power button now it takes longer till I hear a click and it goes back to standby.
            • gayler
              • Aug 2012
              • 23
              • Kearny
              Alright I've got some pictures. Could someone walh me through how to upload? Thanks!
              • Mr Bill
                • Nov 2011
                • 648
                Use manage attachments (paper clip). The pics have to be 2000 x 2000 or smaller. Try to get them as close to 2000 x 2000. I use windows paint to shrink/crop pictures.
                • gayler
                  • Aug 2012
                  • 23
                  • Kearny
                  Ok, Hows this
                  • Mr Bill
                    • Nov 2011
                    • 648
                    What have you done so far? I see you said 2 caps were replaced. Have you checked the fuse on the power supply?
                    • gayler
                      • Aug 2012
                      • 23
                      • Kearny
                      Yes all fuses are good. I realy don't know where to go from here.
                      • Mr Bill
                        • Nov 2011
                        • 648
                        What is the make and series of the 2 caps that you did replace? Are the original samwha caps?
                        • gayler
                          • Aug 2012
                          • 23
                          • Kearny
                          The ones I replaced are nichicon GN{M} 1500uf 200v.
                          • selldoor
                            Slow Learner
                            • 7870
                            Ok - start at the beginning- Power comes in to small filter board Pic 7 - Meter on 400VAC what voltage do you get (CARE HIGH VOLTAGE)
                            where it leaves this board (opposite end to the fuse)
                            Power then goes to the small brown board above it.
                            Can you get a good clear picture of that (Good lighting is the key to clear pictures) Need to be able to read the values on the sockets.
                            Need a better picture of pic 2 -in two halves if needs be
                            Want to be able to read what it says near the sockets the yellow wires go to
                            • gayler
                              • Aug 2012
                              • 23
                              • Kearny
                              I believe I had 119vac there. I'll try to get better pictures tonight. Thanks!
                              • selldoor
                                Slow Learner
                                • 7870
                                Another test is (switched off 5 mins) unplug the cables to the Ysus board top right in pic1 then try and switch on.
                                Note what happens if different.
                                Then switch off (5 Mins) plug Ysus back in and unplug Xsus board on left side pic 1, switch on -note what happens. Switch off 5 mins unplug both boards and switch on - report what happens.
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  Possibly the bad caps caused the psu to overwork, and then blow a mosfet or diode.
                                  EDIT: VERY strange that the two nichicons went bad, they are usually a good brand!
                                  Muh-soggy-knee
                                  • gayler
                                    • Aug 2012
                                    • 23
                                    • Kearny
                                    They were bulged pritty bad. They wobbled like weebles if you stood them on the ends.
                                    • mr.sky
                                      • Sep 2011
                                      • 54
                                      Originally posted by gayler
                                      Ok, Hows this
                                      In the first picture, it looks like 2 capacitors are on backwards, especiall
                                      between the two heatsinks, what do you guys think.
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        No, they are in the right way; what looks like the marker for the negative is actually just a bunch of silicone glue.
                                        Muh-soggy-knee
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                        • robante15
                                          Acer Aspire 4520 won't turn on after reboot
                                          by robante15
                                          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                          If I remove the...
                                          04-06-2024, 06:50 PM
                                        • masoksian
                                          Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                          by masoksian
                                          I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                          The system does not turn on, there is no post.
                                          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                          The problem continues in the same way.
                                          I tried to turn on the Fn key, nothing came to the screen....
                                          02-15-2025, 12:08 PM
                                        • dqtech
                                          lenovo x240 nm-a091 wont turn on
                                          by dqtech
                                          i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                                          board number VIUX1 NM-A091 REV:1.0...
                                          02-07-2024, 01:57 AM
