Dead Sammy - LE26B450C4W
  • AlbertRoss
    • Jul 2012
    • 181
    • United Kingdom
    Re: Dead Sammy - LE26B450C4W
    Must have checked this PSU a dozen times and yet I've just found some bad zener diodes. Similar problem as member Mootink had with his. His bad diodes were ZD804, DM852 and ZM804 and mine are ZM801 (IN4740AS) and ZM804 (IN4746A)
    Managed to find the IN4746A on e-Bay but, unable to find the IN4740AS anywhere!
    Just wondering where other members source there parts from?
    • selldoor
      Slow Learner
      • 7870
      Think you are searching for alpha I Nxxxxx whereas I think it is Numeric 1 Nxxxxx
      • AlbertRoss
        • Jul 2012
        • 181
        • United Kingdom
        Think I know what you mean? I could use the IN4746A and same to replace the IN4740AS?
          No, IN4746A -> 1N4746A
          etc.
          • selldoor
            Slow Learner
            • 7870
            NO - I mean you are searching on ebay for IN4746A
            .......................... and it should be perhaps 1N4746A
            There are others I think would do - if you look at the datasheet then you will see the difference between the 4746 and 4740 and you can then search for a 18v 1w zener or whatever.
            These might do 10v 1w http://cpc.farnell.com/nxp/bzv85-c10...t=zener+10v+1w
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              If you can't decide on what replacement to get, I suggest getting any type of 18v 1W zener.
              Muh-soggy-knee
              • vinceroger69
                • Mar 2012
                • 6714
                #27
                so your looking for the IN4740AS you have managed to find the IN4746A already yourself? if so i have searched and it seems the IN4740AS maybee obsoleet so maybe you can use the IN4740A thats on uk ebay http://www.ebay.co.uk/itm/VISHAY-SEM...item3a70f0a9e2
                a little pricely for 1 though
                • AlbertRoss
                  • Jul 2012
                  • 181
                  • United Kingdom
                  #28
                  Sammy has come back to life with the help of a zener diode - 1N4740AS 10V 1.3W (ZM801) Has a different looking case to the original but works. Photos not to clear, even on macro setting but, as you can see, I now have a steady 5.16V on STBY-5.3 pin 02#
                  Amazes me how one cheap diode can take out a t.v!
                  Thanks for the time and help guys!
                    Very cool! Looks like a nice TV too.
                    • AlbertRoss
                      • Jul 2012
                      • 181
                      • United Kingdom
                      #30
                      The guy I bought it from said it's not been taken apart etc,. but when I got it there was a screw missing from the rear cover so I was expecting the worse, therefore, supprised to see it had a good picture when I got powered up.
                      Mind you, I bought it off e-Bay so, I suppose you have to take a chance?
                      • AlbertRoss
                        • Jul 2012
                        • 181
                        • United Kingdom
                        #31
                        Sammy has come back to life with the help of a zener diode - 1N4740AS 10V 1.3W (ZM801) Has a different looking case to the original but works. Photos not to clear, even on macro setting but, as you can see, I now have a steady 5.06V on STBY-5.3 pin 02#
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          Nice Fluke automotive multimeter. One retiredcaps' bonus point and good job on the repair.
                          --- begin sig file ---
                          --- end sig file ---
                          • double_DD
                            How can I be sure that my EC chip is dead?
                            by double_DD
                            As the title suggests, how can I be sure that my EC chip is really dead?
                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                            03-12-2025, 07:47 AM
                          • disorder
                            ps5 edm-033 dead after hdmi/usb ports destroyed
                            by disorder
                            hello guys,
                            i need help to repair a edm-033 ps2
                            history : as always hdmi port and usb ports destroyed after unplugged
                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                            so i changed it
                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                            i don't see any projection of liquid metal on pcb.
                            01-14-2025, 12:48 PM
                          • zunasthegreat
                            Chieftec GPS-450-AA with dead 20N60C3
                            by zunasthegreat
                            Hello everyone hope all doing well!
                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                            09-01-2024, 07:12 PM
                          • Beton
                            Finding a dead short component
                            by Beton
                            Hi guys!
                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                            I have a bench PSU and if I try to inject voltage the voltage...
                            12-10-2021, 01:05 PM
                          • FiguringITout
                            MSI Raider GE75 - Not posting, probable dead CPU
                            by FiguringITout
                            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                            07-25-2024, 07:27 AM
