*Possible Purchase Magnovox 32mf338/27 Turns on for a second
  • XtraTN
    • Mar 2012
    • 81
    • Usa
    Re: *Possible Purchase Magnovox 32mf338/27 Turns on for a second
    I just edited my last post in case you didnt catch it. the pin measured as follows (left to right)
    pin1: 6.26V
    pin2: 3.3V
    pin3: 2.05V
    • Mr Bill
      • Nov 2011
      • 648
      If the green led flashes a handful of times then turns on this is normal. The emerson LC320EM9 that i have (uses the same power supply) turns on exactly the way you describe.
      So you fixed a broken tv by resoldering a cold joint on the inverter transformer. Good Job!
      • XtraTN
        • Mar 2012
        • 81
        • Usa
        Hmm, I dunno it seems odd to me.
        Looking at the block diagram, theres a transistor Q650 that I think is supplying the 5.5V to the LDO. I measured the pins on the transistor and heres what I got.
        Pin1: 5.63V
        Pin2: 8.80V
        Pin3: 6.32V
        When the TV is on:
        Pin1: 5.80V
        Pin2: 35.9V
        Pin3: 6.32V
        Also, I'm getting a hissing sound on the board with the inverters. Sort of sounds like a gas leak and it happens as soon as the backlights go on.
        • Mr Bill
          • Nov 2011
          • 648
          Pin1: 5.63V
          Pin2: 8.80V
          Pin3: 6.32V
          On my tv I'm getting
          Pin1: 5.54v
          Pin2: 8.45v
          Pin3: 6.25v
          When the TV is on:
          Pin1: 5.80V
          Pin2: 35.9V
          Pin3: 6.32V
          Im getting:
          Pin1: 5.97v
          Pin2: 36.3v
          Pin3: 6.3v
          When i first turn on my emerson it has a loud buzz/hiss in the inverter area too but it goes away after about 20 seconds or so. Maybe run the tv with the back off and see how it does in a real world application.
          • XtraTN
            • Mar 2012
            • 81
            • Usa
            Hmm i guess its normal then. The only question now is how that burnt mark got there but oh well guess we'll never know . Got a 32" lcd tv for 50$!
            I spent over 5 hours disassembling and cleaning every single piece of the TV right down to the backlights. The thing was infested with literally hundreds of dead cockroaches... The most unsanitary thing I've ever seen =/. Eh at least I was able to get an easy fix of of it.
            • Mr Bill
              • Nov 2011
              • 648
              HaHa
              I wonder if one of those cockroaches caused the zap on the board. Atleast it was a an easy fix that didn't cost anything but your labor.
              • XtraTN
                • Mar 2012
                • 81
                • Usa
                #27
                I learn something new with every TV I work on. I'm not opening anymore TV's in my room unless I know its clean. :p Anyway thanks for all the help!
                • XtraTN
                  • Mar 2012
                  • 81
                  • Usa
                  #28
                  Ugh so theres a new problem....
                  Theres a vertical blue strip going along the right side of the TV...
                  Might be a bad panel then =/ but maybe not
                  It seem to be random as I switch off and on the TV. Somethings it would disappear while I leave the TV on for 5 minutes, and sometimes not.
                  I unplugged one of the CCFL to simulate the problem I had in the beginning where it would turn on for a second and go off. And everytime I did that, the blue strip would not appear when the TV when on and back off.
                  So I took off that board and started to reflow and resolder all the joints near the CCFL connectors. But now the blue strip is stuck there and won't even go away now no matter how much I turn on or off the TV or leave it on.
                  For now I'm going to disassemble the panel to the tabs connecting to the LCD and see if pressing on them causes the blue strip to react.
                  But any thoughts on this?
                  • mswillia1
                    • Feb 2009
                    #29
                    I have a Emerson LC320EM9B with Inverted ba8af0f01032. My set doesn't turn on, looks like the board has gotten hot. Do you have the manual for this set?
                    • Eel_dahc
                      • Apr 2017
                      • 18
                      I have this TV as well. $20 pawn shop as is. Sometimes it turns on fine. Sometimes I have to go through the process of pressing power, the light blinks then back to standby, 2 or 3 times before it finally comes on. With the back off and when it tries to turn on but fails, the middle inverter transformers make a buzzing sound. When it works it stays on, no problems. Just sorta turns on when it wants to.
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        #31
                        Probably bad ccfl
                        • Stephen
                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                          by Stephen
                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                          03-15-2024, 09:37 AM
                        • www
                          LG L192WS-BN backlight turns off after 1 second
                          by www
                          I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                          I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                          03-24-2024, 05:26 PM
                        • zklgfs
                          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                          by zklgfs
                          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                          08-11-2025, 02:14 PM
                        • andrhouseolly
                          Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                          by andrhouseolly
                          Hi.
                          I kindly ask you to help me solve the problem.
                          Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                          The board turns on, there is no image.
                          Read more. When the power supply is connected, the front panel indicators light up briefly.
                          When you press the power button, the button indicator lights up. The board works
                          there is no image, there is no matrix initialization, there is no image on HDMI.
                          When turned on, the fans do not spin, but when they warm up they start spinning.
                          When you turn off the button, the fans spin up to full speed for a short...
                          05-11-2024, 03:14 PM
                        • Egidio85
                          Samsung UE55F8000SZ Turns on and off immediately
                          by Egidio85
                          good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                          This defect happens continuously, hearing the classic click of the relay every time.
                          Power supply board BN44-00636B
                          disconnecting the mains and lamps from the power board always causes the same problem.
                          Is it normal that without anything connected this power supply turns on and off cyclically?
                          any suggestions on what to check?
                          thanks in advance
                          03-11-2025, 12:45 PM
