Dell W1700 LCD TV Inverter Board Module T501045.00
  • joehezzer
    • Jul 2012
    • 251
    • England
    hi all i am looking to find out where the fuses are on the display inverter board any pics would be cool cheers in-advance
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Dell W1700 LCD TV Inverter Board Module T501045.00
    Moved from general computer discussion.
    To the original poster: Please use complete sentences. It needs to be easily understandable (be it whatever English dialect you prefer).
    If I am piecing your post together right, you want to know the fuse locations and values on a Dell W1700's Inverter board. You would really like an annotated picture as well. Am I correct?
    sigpic
    (Insert witty quote here)
    • joehezzer
      • Jul 2012
      • 251
      • England
      Hi sorry it was very late over here in England, I was rushing myself lol, but yes what you have written is right. Thanks
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        If you provide a picture of it we will be able to mark where the fuses are?
        • joehezzer
          • Jul 2012
          • 251
          • England
          ok that would be good thanks. i will post a picture up asap thanks
          • joehezzer
            • Jul 2012
            • 251
            • England
            left side of the board
            right side of the board
            cheers in advance, sorry about picture quality. i don't have a very good camera
            • joehezzer
              • Jul 2012
              • 251
              • England
              are they the f1 and f2 fuses near the main plastic molex connector ?
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                If we could actually see them they probably are.- You're not telling me you can identify them in your pictures if you didnt know where they were!
                If you can I am going blind.
                • joehezzer
                  • Jul 2012
                  • 251
                  • England
                  found them, i have just marked them up
                  • joehezzer
                    • Jul 2012
                    • 251
                    • England
                    i have just temporally soldered some 2.5 am fuse wire to the board, magic the screen works
                    • joehezzer
                      • Jul 2012
                      • 251
                      • England
                      yes my camera is pretty rubbish, i think i may have to sort that soon so i can post better pictures
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        Good - I am pleased it works - suggest you dont use it again until you
                        replace the fuses with proper replacements. Oddly enough I dont think we
                        did anything - you did it all yourself - well done.
                        • joehezzer
                          • Jul 2012
                          • 251
                          • England
                          now i know its just the fuses i can order them now, thanks for replying though. i can put it on the shelf now until i get the new fuses cheers
                          • joehezzer
                            • Jul 2012
                            • 251
                            • England
                            i don't seem to be able to adjust the picture quality at all. it seem very green and has no detail on it at all
                            • jsog
                              • Feb 2011
                              • 220
                              Get some light on it and the camera will be able to autofocus better. If you can set the camera to manual focus, that will help too.
                              • SparkieJim
                                • Jun 2013
                                My name is James Graham it is a pleasure to be here. Thank you
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                • m1ch43lzm
                                  by m1ch43lzm
                                  05-12-2025, 08:37 PM
                                • master3112
                                  by master3112
                                  07-29-2025, 01:55 PM
                                • Garret Matt.
                                  DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
                                  by Garret Matt.
                                  I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
                                  Thank you in advance for any assistance you can render.
                                  Inductor In question. Buzzes like...
                                  06-20-2025, 01:21 PM
                                • howardc64
                                  by howardc64
                                  07-24-2025, 05:17 PM
