Samsung LN37A450C1D screen "dimming" issue
  • Plocmstart
    • Jul 2012
    • 5
    • US
    I haven't been able to narrow down the source of this issue yet, and it's somewhat hard to describe but I'll do my best.
    The TV powers up and works fine for a couple minutes. Then the screen appears to get dimmer. It is NOT the backlight. I've taken the TV apart and viewed the backlight from behind the screen where there are a couple holes that are illuminated and it does not get dimmer. So I've ruled out the inverter and bulbs.
    When I look closer at the screen I see when it's normally working all the pixels appear to be lit. When it gets dimmer it appears that only every other column of pixels appears to be lit, and at times it even appears that they are shifting which ones are on and which ones are off by one column, as if the image were vertically interlaced.
    The update rate also appears to decrease significantly. Sports shows can get blurry in high speed motion when the issue is present.
    If I have the menu up prior to the issue happening and then it starts going bad and I close the menu I get somewhat of a ghosting effect, where the "off" columns don't appear to have turned completely off.
    I'll try to get a picture if at all possible, though getting a macro shot of individual columns might be hard.
    So far I have disassembled the TV down to the panel and probed the voltages where I would expect there to be 3.3V, 12V, 24V, etc. and everything appears to be good when it's both working and not.
    So I'm left guessing if it's the T-CON board, maybe the main board not transmitting a good LVDS signal, or maybe even a bad power supply I haven't found yet. I haven't gone as far as borrowing the 1GHz scope from work yet, but it may come to it. The service manual I have only has a schematic for the main board, and it's the typical "if this doesn't work replace board X" type manual.
    The TV is still watchable, but definitely dimmer and less high-def in its current form. I'd like to return it to its proper state though if possible. Any help is appreciated.
  • senndogg
    • Dec 2011
    • 383
    • Albania
    Re: Samsung LN37A450C1D screen "dimming" issue
    who has manufactured the panel? Chungwa, Chi-mei, Samsung?
    • JimmysTGP
      • May 2012
      • 45
      • US
      Clean and reseat all your Ribbon cables. The LVDS cable and the cables going out of T-con to panel, but definitly sounds like a T-con possible panel issue, I don't think its your PS or your main. Also post up some Pics of this problem
      • Plocmstart
        • Jul 2012
        • 5
        • US
        It's a CMO panel. I've completely disassembled and reassembled the TV down to the panel, so I've tried removing and reseating all connectors multiple times now. The PCB connected directly to the LCD was bowed a bit, so I relieved the strain on that board during reassembly but it didn't seem to make a difference.
        I managed to get a photo of some of the pixels in focus. It actually looks like every row is interleaved, and possibly multiple rows are repeated unless the pixels are rectangular.
        Thanks for the help!
          I've seen these panels - never liked the look of them, motion is awful and you can see the dot-crawl on fast movement. My guess would be T-con as it is more global. Panel issues are less rare when they cover the whole panel.
          • Plocmstart
            • Jul 2012
            • 5
            • US
            Thanks tom66. Yes motion is horrible and if I move my head in any way while watching it I can also see the pixel blur even worse. I'll try picking up a new T-con and report on if that fixes it. Thanks!
              And Samsung sells their products at massive premiums! Rip-off!
              • wizard13
                Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                by wizard13
                I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                I have checked the forum and the available documentation but could not find a solution specific to my issue.
                • Brand & Model: Dynabook Satellite Pro C50D-B-100
                • Part Number (P/N): PYU13E-00C00PFR
                • Serial Number (S/N): 22028896H
                • System Configuration (SC): A1PYU13E1127
                • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                • Power Input: DC 19V –
                02-28-2025, 02:43 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • cloudy
                HELP - Contrast/brightness issue with subtitles on screen
                by cloudy
                Hi everybody
                Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
                Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
                Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
                It occours both on ubuntu and windows...
                01-01-2023, 05:12 PM
              • ScHAmPi
                Samsung UE48JU7000 screen issue after backlight replacement
                by ScHAmPi
                Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
                I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
                07-15-2024, 05:41 AM
              • smic717394
                by smic717394
                07-25-2024, 10:16 AM
