Procedure to install new A Main Board in Sony
+ More Options
Posts
  • horn1991
    • Jul 2012
    • 12
    I've gone through quite a few posts and whatnot. Have decided to try and replace the A (Main) board on a Sony KDL-46S4100.
    What I'd like to know... is there a correct "procedure" when installing a new main board? An order of some sort? Do you have to reassemble the TV all the way, or can you just plug in the board and try it out?
    I've plugged in all the connectors and it powers up, but no picture, menu, nothing.
    If I unplug CN303 with is BL-ON, the backlight comes on, and it cycles through a full screen of just Green, then Blue, then Red, and then a horizontal striped screen with 1/4 of the screen each color, plus a gray stripe at the bottom.
    Anyone have any advice?
    Thanks,
    Dave
    Re: Procedure to install new A Main Board in Sony
    Do you have the service manual for your TV? It sounds like your TV is stuck in test mode. Was the main board completely identical to your old one?
    • horn1991
      • Jul 2012
      • 12
      I have a training manual...not sure if it is the same.
      I will check your link to service manuals. There is a description in the back of my manual under "service mode item descriptions"...this is sort of what my TV is doing
      Aging Mode:
      This item can be activate to alleviate any LCD image retention
      issues. When turned ON the TV will continously cycle through display
      red, green, blue, and white rasters.
      Not sure how to turn this off, or change it.
      thanks for your reply.
      Dave
      • horn1991
        • Jul 2012
        • 12
        just checked your link...no sony training manual
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Plug in a signal input. A lot of "test mode" symptoms are fixed with a signal input going to the set. Otherwise, a cable could be loose, or the EEPROM on the main board could be corrupted, or not identical to your original one. Try swapping them around.
          A working TV? How boring!
          • horn1991
            • Jul 2012
            • 12
            I don't know...I just can't figure out why it goes into "test Mode" when I DISCONNECT CN 303.
            Not sure what an EEPROM is, so I don't know that I could switch it out.
            Plugged in OTA and an HDMI input...no luck
              Did a little poking around, do you have this manual yet?
              Try page 21.
              http://www.tgohome.com/ServiceManual...&Search=Submit
              • horn1991
                • Jul 2012
                • 12
                Thanks for the manual link.
                That reset procedure did not work for me.
                • horn1991
                  • Jul 2012
                  • 12
                  Let me pose this question...
                  The training manual tells me that there should be 12V on pin 13, and 3.3V on pin 7. When I use my multimeter to measure these voltages, I get 11.68 or something...same with the other.
                  Should I read EXACTLY 12V and 3.3V? Or just in the neighborhood? Don't know if my meter is just off a little, or maybe the Power board is not functioning properly?
                  Thanks.
                    I would say approximately. For the 12V it should be within 5% (11.4 to 12.6V) and the 3.3V would be 3% or 5%.
                    And, I know many Sony TVs are not happy with different main boards. Was the main board replacement exactly to-the-digit the same as your old one?
                    • horn1991
                      • Jul 2012
                      • 12
                      old one: SO40FHD 07452-3, 48.71H01.031, 5571H01411G8370806BJ03F
                      new one : SO40FHD 07452-3, 48.71H01.031, 5571H01411G82204124J03C
                      not sure how exactly to the digit it is supposed to be.
                        That's pretty close. I'm not sure but maybe your replacement is a dud too. They are pulls from TVs which have been dropped or broken. You can usually get a refund or exchange with the supplier. Other than that, I'm lost.
                        • capkid
                          • Oct 2010
                          • 1339
                          Has anyone found a solution to this issue? I also have the alternating green, red, blue screen issue with the main board I just installed.
                          LG Plasma Mal-Discharge Correction Service
                          • capkid
                            • Oct 2010
                            • 1339
                            Ok, I found these links online after searching for days:
                            http://rapidlibrary.com/files/sony-k...yfr9i89on.html
                            Anyone try this?
                            • capkid
                              • Oct 2010
                              • 1339
                              Ok, I took a chance and installed the firmware; I now have a picture The one issue I'm seeing is that the Bravia splash screen doesn't appear at startup, so I'm not sure if there's a setting that needs to be changed. No biggie, I guess.
                                Don't fix what's not broken. I've always found splash screens annoying... why are you busy showing the splash screen when I could be watching TV now?? I appreciate some TVs use that time to decompress/load the firmware, but I'd say that's a minority.
                                • capkid
                                  • Oct 2010
                                  • 1339
                                  Yeah, I decided not to make any "improvements" and just go with it as-is; it's just the perfectionist in me that would want to make a tweak. It's working great right now.
                                  • truep
                                    • Aug 2010
                                    • 373
                                    hey, Im in flower mound too! Sony's are very fussy with tcons and main boards. You need to get an exact replacement. Use the number on the bar-code sticker.
                                    • capkid
                                      • Oct 2010
                                      • 1339
                                      I found out that some Sony main board versions are interchangeable; it depends on the serial number and sometimes the panel version. There are two available substitutes for my model and serial number. I couldn't find the original anywhere at a reasonable price, so I installed one of the substitutes. So far, all the inputs are working fine.
                                      • capkid
                                        • Oct 2010
                                        • 1339
                                        I'm installing the back cover on the Sony. The previous owner only had four screws installed when I picked up the TV, and he had the rest of the screws in a plastic bag. Does anyone know where the flat washers and flat brackets in the last pic attach? I was thinking they might be part of the wall mount support, but I'm not sure. The service manual doesn't appear to mention them.
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • JDC
                                          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                          by JDC
                                          ONN 100012588
                                          Issue: No Power, Then Rebooting After Main Board Change
                                          Short answer: replace main board and power board
                                          Technical answer: replace main board and Q306 & Q307 on power board.
                                          Long answer:
                                          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                          07-15-2022, 07:39 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
