Sylvania LC320SLX No Power-Dead
  • kevinm34232
    • May 2012
    • 1884
    Re: Sylvania LC320SLX No Power-Dead
    The only diode I saw in circuit as reading same both ways was D637, I lifted one leg and get .0L and 0.183
    • Mr Bill
      • Nov 2011
      • 648
      Originally posted by kevinm34232
      My meter doesnt seem to do well checking diodes in circuit get a lot of readings both ways.
      But not sure if this is correct but I started checking cathode side of diodes to ground, and 2 diodes (D632 and D643) have a reading of 0.00.
      What are the readings of those 2 diodes in circuit with your meter in "diode test mode"?
      • kevinm34232
        • May 2012
        • 1884
        0.480 and .0L. I just was wondering if that indicated a short on that circuit or if they were connected. Does D637 seem OK from above?
        • Mr Bill
          • Nov 2011
          • 648
          I've had a few even lower than .183 in curcuit but would be much higher out of circuit. I was hoping you would find something like in the picture. I can't comment on the 000 reading from the cathode end to ground but Bud M, Ron_cnet or others may be able to elaborate.
            With the Diode out put the meter in Ohm mode and check the resistance between Ground and the pad on the board where the Cathode (the banded side) of the Diode is attached to, then reverse the probe and take the reading at the same point again.
            Best way to check the transistor and Diode is to test them out side the circuits.
            • kevinm34232
              • May 2012
              • 1884
              I did this and have a 0.00 reading so this must be part of the problem. Do D632 and D643 have some component in common?
              If I try to follow the schematic and what the 2 circuits have in common, what components can cause a short to ground?
                At which test point are you testing (the diode number Dxxx) so I can look up the sch?
                • kevinm34232
                  • May 2012
                  • 1884
                  On page 40 Im using pin 15 of T601 for ground to the cathode pad of those diodes, is that what you're asking? Im trying to check other components now to see if I can find something shorted but it's a little overwhelming.
                  Another note, if I use pin 15 of T601 for ground and check for resistance I have 0.00 to the other 9 pins of transformer on secondary side
                    "if I use pin 15 of T601 for ground and check for resistance I have 0.00 to the other 9 pins of transformer on secondary side" That reading is correct since DC resistance of the winding is very low Ohm.
                    "On page 40 Im using pin 15 of T601 for ground to the cathode pad of those diodes" So which one of the Diode Cathode is reading 0 Ohm, please note that D632 Cathode is connected to Pin 13 of the transformer winding (this Diode is used for Neagative power supply) so the Cathode side will read 0 Ohm.
                    • kevinm34232
                      • May 2012
                      • 1884
                      D632 and D643 are reading 0.00. So if D643 cathode should also read 0 ohms back to drawing block.
                        D632 Cathode pad will read 0 Ohm which is what I expected as I explain on how it is used.
                        Same for D643 because the Cathode is connected to the winding of the transformer, which mean you will read 0 Ohm, that is the correct reading.
                        What do you read at the Cathode of the Diode as circled in red (no need to remove them for now)?
                        • kevinm34232
                          • May 2012
                          • 1884
                          Of all the ones you had circled, D631 reads .0L immediatelly, the rest count up slowly until they read .0L which seems to be a pattern with my meter.
                          Basic question is since the 33v was missing is there a systematic approach for finding what may be loading that circuit like Ron said? Do I check all components in the schematic that I see connect with that D638 diode??
                            Try lifting one leg of D639 ZENER, put D638 all other Diodes back in place and see if 33V is back up.
                            • Protonus
                              Thread Killer
                              • Aug 2015
                              • 5
                              @kevinm34232 - did you ever fix this TV?
                              • madan1
                                Modding HPF filter
                                by madan1
                                Hi everyone.
                                Recently scored a dead amp from a mackie srm1801 subwoofer and after fixing it, now I'm thinking about a home cinema/party subwoofer project.
                                Most likely I will use a 15" JBL woofer, which I already have and a diy box.
                                After reading the mackie user manual, I noticed that it has a 40hz HPF (labeled as "36Hz BUTTERWORTH HPF" in the SM) to protect the speaker from low frequencies. Indeed this seems to be good idea for the intended usage - professional music subwoofer, but bad for movies, where one would expect to "feel" the SUBwoofer....
                                09-24-2025, 02:06 PM
                              • Francesc V.
                                Christmas lights - Something I am doing wrong
                                by Francesc V.
                                Hi:
                                i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
                                I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
                                If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
                                Could...
                                03-11-2023, 07:38 AM
                              • bialag
                                Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                                by bialag
                                I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                                Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                                03-25-2025, 05:56 PM
                              • gabrielA7
                                IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
                                by gabrielA7
                                Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
                                I saw that the room LED lights up only when the screen is connected, so quiet.
                                We have all the power supplies, even processor, 1.8V
                                One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
                                I suspect that there may be some leak in the processor.
                                Anyway, when I press the power, it...
                                10-29-2024, 06:48 AM
                              • evilkitty
                                When your mom is complaining about her new cheap lights
                                by evilkitty
                                My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                07-23-2024, 01:27 PM
