Vizio VW42L -No Power/Fuse keeps blowing
+ More Options
Posts
  • vote4pedro
    • Jul 2012
    • 33
    • US
    Re: Vizio VW42L -No Power/Fuse keeps blowing
    I get 0.5 ohms (200 ohm scale) when I test were pin 1 & 4 would be on the green board itself.
    when I test pin 1 & 4 on the bridge itself in ohms (2K ohm scale) I get like .993k ohms, wait a few minutes test it again and I get a higher reading on pin 1 & 4.
    thanks,
      The shorted circuit is on the board, more likely to be shorted out MOSFET's
        Per your picture, in the middle of the board you can see one 3-pin device on the heat sink, and two more? under the heat sink that cannot be seen in the picture.
        Just label the pin as 1, 2, and 3. Take the Ohm (200 Ohm range) reading of the pin combinations.
        1 & 2
        1 & 3
        2 & 3
        Report what you read, the p/n on the devices will help also.
        • vote4pedro
          • Jul 2012
          • 33
          • US
          bud
          Let me make sure I understand.
          Are you refering to this device I have circled in the attached pic? You say there is two more of these devices under the heat sink?
          Do I do these tests with the MOSFET still attached to the board?
          Thanks,
            Yes, and there are one or two more on that same heatsink since I can see the mounting screws.
            You can test them in place, best are top remove them.
            • vote4pedro
              • Jul 2012
              • 33
              • US
              #26
              OK, I finally got the reading and I posted some pics.
              I went out and borrowed me a good fluke meter to make sure I was getting good accurate reading, the reading for Q801, Q601, Q602, & D803 was done with them attached to the board.
              Q801
              Pin 1-2 = 0.4 ohms
              Pin 1-3 = 13.2 ohms
              Pin 2-3 = 13.2 ohms
              Q601
              Pin 1-2 = 9.7 ohms
              Pin 1-3 = 0.3 ohms
              Pin 2-3 = 9.7 ohms
              Q602
              Pin 1-2 = 1.7 ohms
              Pin 1-3 = 0.4 ohms
              Pin 2-3 = 1.7 ohms
              I tested D803 and got 577 ohms
              I re-tested the bridge since I had it already off the board with the fluke meter and on pins 1 & 4 I got (506 K ohms)
                All of those readings make the FETs look like they are blown.
                • vote4pedro
                  • Jul 2012
                  • 33
                  • US
                  #28
                  In your experience is this common for all the FET's to go bad at one time like this?
                  • vote4pedro
                    • Jul 2012
                    • 33
                    • US
                    #29
                    Do you know of a good online place to order these MOSFET?
                    Thanks for all your help, I will post the results....
                    • killian6pk
                      • Apr 2010
                      • 502
                      List the numbers off of each FET and someone will help you find the correct ones to order. You can also try www.digikey.com and imput the first row of numbers into their search field and sometimes you will get lucky and the correct component will be highlighted. If you are unlucky then the part number is obsolete and we will have to find the DataSheet for your part and then find a comparable part to order. If you try DigiKey make sure that you get the same package type as what yours are. There are many different package types for components in the same family.
                      Have you ever stopped to think and then forget to start thinking again?
                      As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
                        Sometimes if one blows, it can wound the others. Usually the first failure has a very low resistance, and the secondary failures have higher resistance. In your case I'd guess Q602 went first and took out Q601 and Q801.
                        However, please remove Q601, Q602 and Q801 and test out of circuit to confirm if they are failed.
                        • vote4pedro
                          • Jul 2012
                          • 33
                          • US
                          #32
                          I have removed Q801, Q601, & Q602 from the board. Here is what I got.
                          Q801
                          Pin 1-2 = 0.1 ohms
                          Pin 1-3 = 13.0 ohms
                          Pin 2-3 = 13.0 ohms
                          Q601
                          Pin 1-2 = 10.1 ohms
                          Pin 1-3 = 0.1 ohms
                          Pin 2-3 = 10.1 ohms
                          Q602
                          Pin 1-2 = 1.4 ohms
                          Pin 1-3 = 0.1 ohms
                          Pin 2-3 = 1.4 ohms
                          Does it appear that there still bad?
                          Thanks,
                            Yes, all are shorted. Is there still a short across the + and - of the bridge?
                            What are the part #'s on those FETs?
                            • vote4pedro
                              • Jul 2012
                              • 33
                              • US
                              #34
                              When I read the bridge in Ohms with it out of the board, i get (502.5 K ohms) across the (+) and (-) pins. Is the bridge bad also?
                              Here are all the part numbers:
                              Bridge
                              D25XB 60 BA475
                              Q801
                              all I see on this is two circles with an (2) and (E) in those circles
                              Q601
                              P11NK50ZFP
                              GK1EA V6
                              CHN 724
                              Q602
                              P11NK50ZFP
                              GK2EN V6
                              CHN 723
                              Thanks again for helping
                              • vote4pedro
                                • Jul 2012
                                • 33
                                • US
                                #35
                                I was wondering if you had a chance to view the reading on the bridge to see if it was bad also.
                                I have listed all the part numbers also, does those numbers look correct?
                                  Sorry... didn't notice this thread had an new post.
                                  502.5k is good - no short. If TV has a separate standby section it should work without those fets.
                                  • vote4pedro
                                    • Jul 2012
                                    • 33
                                    • US
                                    #37
                                    Do you know roughly how much these 3 FET's would cost?
                                    I'm not sure if the TV has a separate standby section. Is there a way to check? If it does would it be safe to run it with out the FET's in place?
                                    Thanks,
                                      I'd guess under $15, probably under $10. In a 42" LCD, they wouldn't use expensive FETs.
                                      Almost every TV >=32" has a separate standby section. On second thoughts the TV could try and do a self-test of the main power supply so it might give a false positive. Best to wait until the FETs are fitted...
                                      • vote4pedro
                                        • Jul 2012
                                        • 33
                                        • US
                                        #39
                                        Does those part numbers seem to look correct for the FET's?
                                        For Q801 - all i could find on it was an (2) and (E) both had a circle around them.
                                        Thanks,
                                          Hmm. That would possibly be a proprietary or custom part. Your best bet is to choose one that is way overrated for the job, like thus:
                                          http://www.digikey.com/product-detai...63-5-ND/654637
                                          This should handle a 42" LCD TV load easily.
                                          • Dannyx
                                            UC3842 Power Adapter Blowing Fuse
                                            by Dannyx
                                            Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
                                            Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
                                            12-05-2023, 12:06 PM
                                          • Tips
                                            Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
                                            by Tips
                                            Looking for some assistance please.
                                            Trying to repair a PD27AOQ samsung power board.
                                            Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
                                            Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
                                            Testing it the fuse blows immediately power is turned on.
                                            diodes dm852 and dm853 test as shorted when in the board but fine when removed.
                                            any assistance, guidance would be appreciated.
                                            04-11-2024, 11:24 AM
                                          • RogerH58
                                            Samsung 46" TV LE46B530 blowing fuse
                                            by RogerH58
                                            I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
                                            I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
                                            I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
                                            06-10-2023, 10:27 AM
                                          • bscottjohnston
                                            Vizio M55-E0 won't power on - fuse intact
                                            by bscottjohnston
                                            Vizio PSLL241206M inside an M55-E0.
                                            Here's an odd one. Why in the world do I have 76 VAC on the fuse when I have measured 115 VAC on the input power cord? Does this point to something known or simply another SMPS problem I need to run down?...
                                            02-20-2024, 12:18 PM
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
