LG 32LC2D-EC - NO SOUND (and other issues)
  • samix
    • Oct 2013
    • france
    #41
    Re: LG 32LC2D-EC - NO SOUND (and other issues)
    Hi Tmcw,
    could you please post a picture or give the name of the capacitors you have changed to solve the sound issue?
    Thanks ad regards.
    • tmcw
      • Oct 2010
      • 382
      • Ireland
      #42
      I never pinpointed exactly which capacitors were needed to fix the sound, all I know is that repairing the 6V line fixed it. As I remember, I ended up replacing all caps near the connectors, except the 2 big 3300uF caps. This fixed the sound, and analogue and digital tuner issues.
      As I remember, some of the caps that I didn't think were associated with the 6V line, when I changed them, the 6V was eventually repaired. In the absence of a schematics, for someone like me (amateur learner at best), it's not always easy to decipher the circuits.
      Best bet is to shotgun-replace all in that area (except the 2 big 3300uFs). There are only 6 (if your picture is fine, you don't need to change the 4 caps associated with the inverter), so get good replacements, set aside an hour or two, and replace them. I've attached an edited photo from the first post of the relevant caps, the ones with the red X on them.
      My set is still going strong about a year on. Good luck!
      • Liam.25
        • Feb 2011
        • 107
        • Uk
        #43
        I'm having the same issues as this
        I changed all 12 caps but didn't fix the faults
        Also I only have 3 LEDs lit on the main board
        Please read my topic
        https://www.badcaps.net/forum/showth...541#post384541
        • tmcw
          • Oct 2010
          • 382
          • Ireland
          #44
          What voltages are you getting on the 3 connectors, as per post #1?
          https://www.badcaps.net/forum/showpo...83&postcount=1
          • Liam.25
            • Feb 2011
            • 107
            • Uk
            #45
            P201:
            3.4V - 2V
            6V - 6.2V
            DIM -mv
            5V - 5.1V
            BRI - mv
            ERR - mV
            I(?) - 4.9V
            5V - 5.1V
            ON - 3.2V
            ACD - 5.1V
            P202:
            12V - 11.85V
            3.4V - 1.3V
            6V - 6.1
            19V - 19.15V
            19V - 19.15V
            P203:
            12V - 11.85V
            12V - 11.85V
            6V - 6.2v
            6V - 6.2v
            3.4V - 1.3v
            3.4V - 1.3v
            Looks like I have the 3.4v line is very low
            And dim and bri I don't knows what they are but they seem low compared to the original posts
            All the caps in this are new
            Thanks in advance
            • baddawg1991
              • Oct 2015
              • 7
              Originally posted by Liam.25
              P201:
              3.4V - 2V
              6V - 6.2V
              DIM -mv
              5V - 5.1V
              BRI - mv
              ERR - mV
              I(?) - 4.9V
              5V - 5.1V
              ON - 3.2V
              ACD - 5.1V
              P202:
              12V - 11.85V
              3.4V - 1.3V
              6V - 6.1
              19V - 19.15V
              19V - 19.15V
              P203:
              12V - 11.85V
              12V - 11.85V
              6V - 6.2v
              6V - 6.2v
              3.4V - 1.3v
              3.4V - 1.3v
              Thanks in advance
              Sorry to bring this back from the dead but your voltages are almost identical to mine with same problems. Did you ever figure out the issue at hand? What was the fix?
              • jjne
                Yamaha RX V675 sound issues
                by jjne
                I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
                From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
                At first I thought it was either a speaker relay or the DSP, but I don't think...
                06-24-2025, 07:01 AM
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
              • acedogblast
                Marantz SR5012 popping and other sound issues
                by acedogblast
                Hello I have a Marantz SR5012 7.1 AV receiver that is producing speaker pop and other sound issues. These sounds are coming out of all connected speakers regardless if they are configured to be used. The rca preouts are clean from these defects so I am assuming the problem has to be with the amplifier.
                These sound issues are random and unpredictable. There are times where the unit can go 10 minutes without any problems then suddenly the problems come back. It doesn't seem to matter if there is sound being played or not.
                I have disassembled the unit and was able to take out the...
                02-15-2023, 01:40 PM
              • LEECH666
                Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                by LEECH666
                Good day ladies and gentleman!
                I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                01-19-2024, 05:46 PM
              • i19
                Asus UX3402 / Q409Z - No sound, no TPM, Boot issues: Bios flash?
                by i19
                Hi
                I got an Asus UX3402 / Q409Z and after a BSOD I lost sound, tpm 2.0, and if it turns off it can take HOURS before I can boot again.
                Reading here and on reddit I figured its a BIOS issue, and that reflashing it may fix the problem.
                I want to use an CH341A (new model with 3.3v) to flash it.
                My problem is that I'm not sure if the SOIC8/SOP8 clips will attach to the chip and hold properly? (haven't opened my laptop yet, I'm basing this assumption on a picture from the same thread I attached).
                Any tips on how to connect to it? Maybe something...
                08-20-2024, 06:50 AM
