Asus UX3402 / Q409Z - No sound, no TPM, Boot issues: Bios flash?
  • i19
    • Aug 2024
    Hi
    I got an Asus UX3402 / Q409Z and after a BSOD I lost sound, tpm 2.0, and if it turns off it can take HOURS before I can boot again.
    Reading here and on reddit I figured its a BIOS issue, and that reflashing it may fix the problem.
    I want to use an CH341A (new model with 3.3v) to flash it.
    My problem is that I'm not sure if the SOIC8/SOP8 clips will attach to the chip and hold properly? (haven't opened my laptop yet, I'm basing this assumption on a picture from the same thread I attached).
    Any tips on how to connect to it? Maybe something like these or these? My soldering skills are bad
  • uiugor
    • Jun 2015
    • Brazil
    I had the same problem with the Q409Z. No sound and taking a long time to turn on after an automatic Windows update.
    The method to resolve this is to rewrite the bios, use the file below that I will be making available, Clear ME, FastBoot.
    Try soldering the bios IC like this. REMEMBERING that you will need to ground the center of it.​
    • i19
      • Aug 2024
      It's been a while and I didn't have the time to do this yet.
      I got a bios dump using AfuWin64, and attached it here. I hope this is enough to create a clean BIOS to fix my issues (No sound, no TPM, Boot issues). I also hope that due to not having TPM I could maybe flash it either through Windows or Linux? Maybe I'm too wishful.
      Anyway, with a clean BIOS file, I can go to a shop to burn it to the chip, but I couldn't find one to do the cleaning part. If a full dump from a reader is needed, I will look harder for a way to get that.
      I also don't know my BIOS password so if that can be cleaned as well. My local authorized Asus repair center (that said I must replace my motherboard for a new laptop price...) changed it
      Model: Asus Q409Z
      S/N: N2N0LP00C481069 (it says 12M on the row above that on the tiny sticker)
      Thank you!
      • Ihandyrepair
        4 red flash led 65X950G boot Sony and android logo but then black
        by Ihandyrepair
        HI guys
        I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
        here is the issue
        I have Sony and android logo. but then 4 led red flash lights front of the tv
        I have 3.3v ref. 12v reg then T con 12v when I press the power on button
        but then I get black screen and 4 red flash light at the front LED
        but I get 3 led flash on the LED driver board.
        I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
        so I tried...
        07-11-2024, 01:45 AM
      • maleksa
        Yamaha MOX8 boot freeze and distorted sound
        by maleksa
        My Yamaha MOX8 synthesizer recently developed two issues.
        Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
        Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
        11-07-2024, 03:28 AM
      • corrize
        Nikon D800 camera - flash don’t work and capacitor don’t charge
        by corrize
        Hello, I'm stuck in troubleshooting…
        The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
        In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
        When I press the flash button, it's detected by the system, flash icon appear on LDC display....
        10-01-2022, 10:02 AM
      • triplefour
        TCL 75S421 has sound but no backlight not even a flash
        by triplefour
        TCL 75S421
        PSU BOARD: 40-L402H8-PWD1CG
        it shows not even a flash of backlight when powering up.
        but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
        testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
        unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
        i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
        with mb connected, PSON...
        11-17-2023, 09:54 PM
      • hinisa
        Xiaomi router freezes at boot after re-capping
        by hinisa
        I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
        When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
        After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
        Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
        07-08-2023, 05:58 AM
