Lg 32lc2d no audio
  • Liam.25
    • Feb 2011
    • 107
    • Uk
    Lg 32lc2d no audio
    LCD TV: LG 32LC2D
    Original faults: no audio, intermittent side buttons, tuner will not search
    I have changed all caps after reading this forum:
    https://www.badcaps.net/forum/showthread.php?t=21321
    Please watch my video
    click for YouTube video of the faults
  • samson7point1@yahoo.com
    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
    by samson7point1@yahoo.com
    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
    The player processes the audio signal using two different reference frequencies. The "R"...
    04-30-2024, 11:22 AM
  • CDNBrewer
    Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
    by CDNBrewer
    Hello Everyone,
    I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
    Symptoms:
    • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
    • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
    • I swapped the Left and Right surround
    08-05-2025, 09:29 PM
  • i_am_patch
    Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
    by i_am_patch
    Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
    04-30-2024, 08:20 PM
  • silver60618
    Macbook M3 A2991 Speaker Audio Amplifier IC
    by silver60618
    Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
    I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
    09-26-2025, 12:25 PM
  • MOSSEP
    Monitor Audio RSW12 - Green light but no audio
    by MOSSEP
    Hi
    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
    I have already tried replacing all of the...
    01-26-2025, 08:18 AM
