Yamaha RX V675 sound issues
  • jjne
    • Mar 2013
    • 47
    I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
    From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
    At first I thought it was either a speaker relay or the DSP, but I don't think it's either. All sound is lost and the amplifier is losing sync at the same time which I think would rule out a failing relay (as I'd expect that to only affect one speaker) and the fact that bypassing the DSP doesn't seem to make a difference I think rules out that chip.
    It doesn't appear to be the optical cable or the source (TV) as the same cable plugged into a soundbar is fine, and once the Yamaha warms up it's also OK.
    So I'm thinking it's further up the chain in the amplifier - are there any known faults on the input stage on these? I think the next step is to connect this via analogue and see if that makes a difference.
  • jjne
    • Mar 2013
    • 47
    The analogue inputs are the same. Should be noted as well that if it's switched off and on, sometimes repeatedly, the problem does clear.
    • CapLeaker
      Leaking Member
      • 8352
      get yourself the SM and look at the block diagram. Open the unit up and check with an oscilloscope where you are losing the audio. Keep it simple and start with the analog side.
      Also check if all voltages are present and within spec. Don't forget to check the caps.
      • ngvuanh
        • Jul 2013
        • 46
        You may want to look at DAC chip, ic153.
        • AlexVG
          YAMAHA CLP-550 without of sound
          by AlexVG
          Hi.
          I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
          I have replaced all green marked elements, but it gave me nothing.
          The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
          But it is custom YAMAHA's chip, and I can't find any information about it.
          Maybe somebody came across with the same issue?
          Any information will be very useful. I will be very appreciated.
          Thank you....
          06-08-2025, 09:29 AM
        • hemant_2222
          Yamaha 2064 No sound but Test audio working
          by hemant_2222
          Hello Guys,
          Greetings!
          Hope you all are doing well.
          I am looking for suggestion on Yamaha 2064. The problem with this receiver is that it has no sound however when the test tones are activated it does outputs from all the speakers. It is working in two channel stereo mode but when you select other sound modes, it doesn't. The last time it had a problem, I had replaced the DAC
          PCM1681DBQR - IC263 and it worked fine.
          Other issue with it is one of the STK ICs is getting more heated then the other one but that can be looked at later.
          11-01-2025, 11:20 PM
        • acedogblast
          Marantz SR5012 popping and other sound issues
          by acedogblast
          Hello I have a Marantz SR5012 7.1 AV receiver that is producing speaker pop and other sound issues. These sounds are coming out of all connected speakers regardless if they are configured to be used. The rca preouts are clean from these defects so I am assuming the problem has to be with the amplifier.
          These sound issues are random and unpredictable. There are times where the unit can go 10 minutes without any problems then suddenly the problems come back. It doesn't seem to matter if there is sound being played or not.
          I have disassembled the unit and was able to take out the...
          02-15-2023, 01:40 PM
        • Rupsenkind
          Yamaha RX-A1030 working, no sound output
          by Rupsenkind
          Hi all, I've started this new thread in order to avoid further polution of thread "Yamaha RX-A3010 working, no sound output"
          Just to recap:
          No sound through Audio and AV analogue inputs, only sound when 2ch stereo or pure direct is activated (so no sound when I e.g. choose 7ch of Hall in Munich etc.). Hoever when I connect HDMI I've sound in all options (movie, music, eyc.) First suspicion was the DSP chip/PCB so I bought a scrap 1030 with a good functioning PCB (in this one a driver stage was defective (PRT DC: 67), after I swapped the PCB I've performed a factory...
          07-10-2022, 03:15 AM
        • daigs
          Yamaha P-115 turn on but No sound - Doesn't turn off
          by daigs
          I need to repair a P-115 yamaha digital piano with a strange behaviour.
          When I power on the piano from the dedicated on/off switch, the power led go to ON (red led), but the keyboard doesn't produce any sound, nor in the speakers nor in the headphones.
          When I try to power off (pressing the switch for at least 1 second), the keyboard doesn't power off, the red led remains ON. I need to unplug the adapter cable to switch off the keyboard.
          I checked the 12V voltage rail on the input PCB, after the power plug and it is OK.
          I checked also the...
          07-18-2023, 03:47 PM
