Visio VX32L-HDTV10A - no picture
  • ahickman
    • Jan 2012
    • 233
    Along with several other flatscreens I received from the dump last week, I procured a nice VX32L-HDTV10A which had no picture at power up. A couple of quick searches on this site and Google indicated that the U33 voltage regulator on the main board was suspect. Ordered a replacement from Digikey (P/N 497-1229-1-ND) and replaced it. Viola! Set works nicely.
    Removing the chip was very difficult as it had epoxy betwen it and the circuit board. Had to carefully clip the legs and desolder them separately. Then had to gingerly tap a razor blade under the chip to dislodge it. Also found that a chisel tip was far superior to desoldering than a pointed tip.
    Thanks to this forum, I have yet another LCD to be used as a bargaining tool or gift!
    Re: Visio VX32L-HDTV10A - no picture
    Glad to hear you fixed it. However, there is a far easier way to remove a regulator:
    - Glob solder over the three bottom pins with the soldering iron. Cover them up well.
    - Heat up the glob for 15-30 seconds with the iron.
    - Using the soldering iron apply light pressure in one direction to the regulator. It will quickly move.
    - Use solder wick to clean up the pads.
    • ahickman
      • Jan 2012
      • 233
      I have heard of this method, but get so intimidated when there are so many teeny, tiny little SMD pieces so close to the pads. Not that a razor blade with pressure applied to it is any safer
        It is worrying. However, remember that surface mount parts rely on surface tension to hold them on during wave solder processes. It's much the same thing. They are designed to resist it without moving. If you directly push or heat them though, you could move them.
        • retiredcaps
          • Apr 2010
          • 9271
          I wonder if Vizio got a bad batch or they under engineered the part? Or maybe that should have used a bigger physical package and the regulator is dying due to heat?
          --- begin sig file ---
          --- end sig file ---
            I've pulled a few 1117's. I suspect it is due to the low cost of these devices (poor quality) and cost-based engineering, running them near maximums.
              If the 1117 series made by US based companies are better than the Chinese no name companies. There are so many Chinese semiconductor companies that I never heard off.
              • Acorlin
                • Aug 2010
                • 11
                I have an unrelated question on this same model Visio. Can a main board from a VX37LHDTV10A numbered Vizio 0171-2272-2174 3637-0052-0395 be used in a Visio 32" set? The 32" board is a 0171-2272-2174 3632-0202-0150 .The 32" set had a bad U33 but now that I have good voltage it still will not turn on. The Visio logo on the front does turn white. I have a good 37" board and just want to know if that can be used. Thanks--
                  If the panel is the same manufacturer i.e. both are LG display, both are Samsung... then yes.
                  • Acorlin
                    • Aug 2010
                    • 11
                    Tom--
                    thanks for the answer. On the 32" set I have checked all the DC-DC converters and the outputs are to spec yet the set will still not turn on. the Visio logo turns white and I am able to turn it on and off with the side button. On Ebay someone is selling a kit of 4 parts that are supposed to "cure" this problem. What 4 parts (other than the DC -DC converter chips) do you think they are? I have checked most of the caps and they seem fine.
                      How is the voltage on U7? Its input if from U33's output.
                      • Acorlin
                        • Aug 2010
                        • 11
                        All of the 1117's now have voltages that are within spec including U7. What is puzzling to me is that I am not having the usual trouble I read about in the forum. My set will turn off and on. It does have the usual problem where there is no sound and the back lights do light up. The Visio logo does turn White.
                        I appreciate you taking the time to help me out.
                        Alan
                        AA6DW
                        • Acorlin
                          • Aug 2010
                          • 11
                          I should have been more clear in answering your question. U33 was bad causing two other 1117's to malfunction. U7 being one of them. I replaced U33 and all the voltages went to spec. The output of U7 is now 1.25V. No change in operation after the replacement of U33.
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            Have you checked if the backlights work on this set? Have you connected a source and checked for sound? When you say no picture, is it a dark screen or a blue "no signal" screen.
                            • Acorlin
                              • Aug 2010
                              • 11
                              I have not checked for sound. The back lights do go on and off as they should when I push the side on-off button.
                              • Acorlin
                                • Aug 2010
                                • 11
                                It has a dark screen not blue.
                                  "I should have been more clear in answering your question. U33 was bad causing two other 1117's to malfunction. U7 being one of them. I replaced U33 and all the voltages went to spec. The output of U7 is now 1.25V. No change in operation after the replacement of U33." Thanks for the clarification, that is usually happen, I usually ending up repalcing the the U7 also.
                                  Can we see the pictures of all the boards? We need to chek the BL_ON (Inv_on) signal next.
                                  • Acorlin
                                    • Aug 2010
                                    • 11
                                    I will post some photos tonight. The back lights are turning on and off. If the BL_ON (Inv_on) signal was bad would they still turn on?
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      Have you checked the fuse on the T-Con board?
                                      • Acorlin
                                        • Aug 2010
                                        • 11
                                        I have not checked T-Con board at all. Will check tonight.
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • CyberPhoenix
                                          Issue with picture quality of Sony bravia TV
                                          by CyberPhoenix
                                          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                          01-22-2024, 02:08 AM
