Samsung LN-46A530 issues with HDMI
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this TV(finally) and with HDMI input the video looks like has a T-con issue, it's screeching loudly and restarts by itself. HDMI #3 input seemed dead and the other two were doing the same green lines and screeching sound.
    With basic component input it's working great.
    I have upgraded the firmware. After the upgrade it played nicely with all three HDMI inputs for about 15 minutes and the again the same story.
    Since the firmware upgrade fixed it for a short while, I'm thinking that is a software issue. Maybe a factory reset would fix this issue?
  • JimmysTGP
    • May 2012
    • 45
    • US
    Re: Samsung LN-46A530 issues with HDMI
    I remember these LCDs Running very HOT, and it seem like everytime it was the hard to find T-con giving problems. But definitly does not sound like your issue. First thought was upgrade, but if that didn't fix it then it would be your main board intermittly giving you this problem. You can try the system reset first. Keep us informed.
    • tibimakai
      • Jan 2012
      • 3680
      I'm thinking that it has issues with the digital signal. The analog it seems OK.
      The only solution is to replace the mainboard?
      • tibimakai
        • Jan 2012
        • 3680
        It must be a weird issue, because when I plug in the HDMI cable it starts the issue and it's causing the TV to turn on and off by itself and I have to unplug the power cord to make it stop. It seems that it goes in some kind of protection mode. But from digital signal?!
        • tibimakai
          • Jan 2012
          • 3680
          Factory reset didn't help.
          Any other suggestions?
          I will replace all the capacitors in the PS, just to be sure, they are all Sanwas.
          Previous owner stated that Samsung technician replaced the capacitors, but I'm thinking that it's been a while since that service and who knows, maybe they could be bad the second time.
          • Mt.Man
            • 53
            Have you tried another HDMI cable? Sounds like you will need a main board.
            • tibimakai
              • Jan 2012
              • 3680
              Yes, I have tried and it's the same.
              So, nothing else can be done?
              • tibimakai
                • Jan 2012
                • 3680
                Component, PC inputs work also.
                I have noticed that Samsung guys replaced the caps(didn't clean up after themselves), but I have also noticed that the main chip which has a metal cover with heatsink it wasn't soldered all the way in, one end it was in the air. Maybe the heatsink wasn't seating with the whole surface on the chip and got fried partially?
                I can't seem to find this mainboard.
                • JimmysTGP
                  • May 2012
                  • 45
                  • US
                  I'll need the rest of your model code and the version of the set it should be on the side.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Do you need the board number or the TV model number?
                    I have the board number handy, but I don't have the TV with me right now(iI think that it's a LN46A530P1FXZA, at least on Samsung's support site this is the only one showing up).
                    Model: Pearl
                    BN41-00975B(2008.01.13)
                    This info is on the label:
                    BN97-01985P
                    110462359: 320
                    T001
                    TOP BN 41-00975B
                    L41 A 04-21 0179
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      Bad capacitors can cause lots of strange problems, including squealing inductors!
                      Muh-soggy-knee
                      • DakotaKid
                        • Nov 2010
                        • 165
                        If you don't have the board he needs I think I might have one. I will check my stock and wait to hear back.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I have replaced all the PS capacitors with no change.
                          The TV's model number is the one that I have previously mentioned.
                          Here are two pictures with the TV, using HDMI signal(component is fine) it has a loud uncontrollable nosy coming from the speakers also:
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            What kind of capacitors did you use as a replacement? I think there might be some bad ones on the mainboard though. Either that, or the PSU is unstable for some reason.
                            Muh-soggy-knee
                            • tibimakai
                              • Jan 2012
                              • 3680
                              I have used Panasonic FM/FC capacitors.
                              I was suspecting the power supply myself too, that was one reason to replace them.
                              But then, how come with other inputs it's working right.
                              There is a metal cover with a heatsink on top, I guess it's the main processor is underneath. I have found it with one side really raised, read not soldered properly. I'm thinking what if the technician who did the Samsung lawsuit repair, did it intentionally? This causing an overheating processor and it damaged it.
                              • RON_CET
                                • 217
                                Following some of this post appears to me that your issues are coming from damages at the HDMI input area (attached schematic) or from internaly of the MT5382P micro my opinion would be the MT5382P which either way results in main board change
                                Ron Driver,BSEE,CET,ISCET,NESDA
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  I need a mainboard and it's hard to find.
                                  Here is one on Ebay but the last letter it's not P, it's U. Do you think that it matters?
                                  http://www.ebay.com/itm/SAMSUNG-LN46...item3cc7bbeb0c
                                  Here are my board's numbers again:
                                  Model: Pearl
                                  BN97-01985P
                                  110462359: 320
                                  T001
                                  TOP BN 41-00975B
                                  L41 A 04-21 0179
                                  • DakotaKid
                                    • Nov 2010
                                    • 165
                                    After looking at your board the one I have probably wouldn't work for you. Mine is from LN46A650 which has the 3rd HDMI port, digital audio out and LAN port.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      Thank you anyway for looking.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        I have just remembered to compare the LN-52A550 board(which I have) with the 46 and to my amazement it's almost the same.
                                        Actually it's working already with it, but the major difference is that on the 52 the side connections are on the mainboard and on the 46 are remote mounted.
                                        Now this one presents a challenge because there is a LVDS type connector that has to be transplanted from one board to another.
                                        Other two connections that have to be transplanted are the USB and a mini headphone PC style connector which are easy to do.
                                        • BretCraytor
                                          Samsung LN52A550 with HDMI issues
                                          by BretCraytor
                                          This Samsung TV, does fine with no input connected, but when I place my fire stick in the HDMI, it works briefly then starts making a screaching noise and the screen messes up with vertical lines. sometimes when this happens, it will start power cycling, going thru POST, and still screach and have scrambled picture.
                                          I replaced a bad cap on SMPS board, but the best I can tell, the Power board is with right voltages. Can someone lead me to where I need to look next? main board? Surely seems like it may be the input selector or something, but I don't know what chips that might be...
                                          01-30-2023, 07:57 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
                                        • grimacelord
                                          Samsung UN50MU6070FXZA - HDMI Ports Not Working
                                          by grimacelord
                                          Hello. Samsung UN50MU6070FXZA here with both HDMI ports non-working. I have already verified multiple sources and multiple cables to ensure it isn't something simple like that as well as resets and software updates.
                                          I took the mainboard out and gave it a look. Nothing looks bad or burned. All of the HDMI pins are nice, none are broken at their pads either.
                                          Following the traces, it looks like both HDMI ports trace back to the main CPU which does seem to get hotter than I think it should despite it's (rather poor) heatsink.
                                          Since the HDMI controller appears...
                                          11-03-2021, 03:10 PM
                                        • Servicem4
                                          Pioneer lx 701 hdmi issues
                                          by Servicem4
                                          My receiver pioneer LX 701 doesn't work anymore correctly The history:
                                          6 month ago hdmi picture output didnt work anymore but music input through hdmi still worked.
                                          Since some weeks even this doesn't work. Right Before this occured i heard a plopping noise from the receiver one evening.
                                          The rest of the receiver works, I used spdif for sound input.
                                          I now opened the receiver and hoped to find a blown fuse but all look good.
                                          Any tips how to progress? Between 2 PCB there is something which looks like a blown cap....
                                          Image 20250527-204839 hosted in ImgBB
                                          05-27-2025, 01:13 PM
