Pioneer lx 701 hdmi issues
  • Servicem4
    • 11
    • Deutschland
    My receiver pioneer LX 701 doesn't work anymore correctly The history:
    6 month ago hdmi picture output didnt work anymore but music input through hdmi still worked.
    Since some weeks even this doesn't work. Right Before this occured i heard a plopping noise from the receiver one evening.
    The rest of the receiver works, I used spdif for sound input.
    I now opened the receiver and hoped to find a blown fuse but all look good.
    Any tips how to progress? Between 2 PCB there is something which looks like a blown cap. Difficult to photograph.
    To Check this out I need to remove the upper PCB - how do I do this?
    How can I disconnect the PCB (3) on the side which seems to connect upper and middle PCB using connectors marked 1 and 2. It's packed so tight I can't see the connector type 2 below. Don't want to break anything.
    Image 20250527-204839 hosted in ImgBB
  • RatherLoopy
    Pioneer VSX-44 receiver HDMI dropouts
    by RatherLoopy
    I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
    I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
    And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
    05-26-2023, 03:54 PM
  • CDNBrewer
    Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
    by CDNBrewer
    Hello Everyone,
    I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
    Symptoms:
    • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
    • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
    • I swapped the Left and Right surround
    08-05-2025, 09:29 PM
  • spleenharvester
    Whirlpool PACF212HP W portable air conditioner, upper fan only turns slowly.
    by spleenharvester
    I just acquired this portable aircon, history unknown. Its behaviour is quite strange:
    • When turned on and placed into cooling mode, the upper fan (cold air out) just spins slowly. The compressor and lower fan do not run.
    • If the device is then placed into heating mode and then back into cooling mode, the lower fan and compressor kick in and start cooling, but the upper fan still only spins slowly.
    • If the device is placed into fan-only mode, the upper fan does not respond to low/medium/high speed toggles - just keeps running slowly.
    • Display and buttons all behave normally aside from the
    06-27-2025, 07:49 PM
  • spleenharvester
    Toshiba 50UL2063DB randomly rebooting with HDMI-CEC and/or HDMI-ARC enabled
    by spleenharvester
    I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
    I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it?
    03-12-2025, 03:42 PM
  • suiramix
    Pioneer VSX-532 receiver HDMI light blinking
    by suiramix
    Hi there,
    Pioneer VSX-532 receiver almost new, HDMI red light blinking , performed reset (power + surround button for 5 seconds), remove speakers, the amplif power up but after few sec smoke came up from resistor R16FL. Should I go head and remove the final transistors or just Q4FR ?...
    05-23-2019, 07:45 AM
