Akai PDP4225M stuck on HDMI
  • electronicsurplus
    • Jun 2012
    • 210
    I have a Akai PDP4225M
    It is stuck in HDMI mode, controld do not respond nor does remote
    Any ideas?
    Jon
    This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
    Help keep these from the landfills
  • Mr Bill
    • Nov 2011
    • 648
    Re: Akai PDP4225M stuck on HDMI
    The only suggestion i can make is disconnect the keyboard and see if the remote will change the source. The keyboard may have some stuck contacts so the remote and keyboard are fighting each other cause the tv to lockout but i'm sure others may have some better ideas.
    • RON_CET
      • Jun 2012
      • 217
      only thing i can think of if MR Bill suggestion didn't work would be to try find if there's any firmware update to main board if not then only cure would be main board replacement
      also just remembered some those Akai units were same as Samsung Model SPL4225K or very close clone
      Ron Driver,BSEE,CET,ISCET,NESDA
      • tranquility
        Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
        by tranquility
        i want to repair an Onkyo TX-NR809 receiver.
        symptoms:
        on power on, display appears and i hear one click. enue functions is given.
        - no hdmi output
        - audio output not tested, but i think it is not there
        - usb sticks are not recognized
        if i read out the chips with display+standby button + tone+
        both dts show only ????
        chip is D830K013BZKB4
        things i have done:
        - reflow of the dts chip without taking off and reballing
        - changed the aluminium caps without the big one with 25v because i dont...
        08-25-2025, 01:04 AM
      • aliougm
        Marantz SR4003 AVR HDMI board issue, seeking for help
        by aliougm
        I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
        Connection as below:
        Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
        If I bypassed AVR then HDTV screen color be good.
        I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
        3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
        I replaced all...
        04-30-2022, 12:21 PM
      • Stunt
        Hp Laptop Stuck on Hp protected by hp sure start screen
        by Stunt
        Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
        I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
        I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
        Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
        screen that's it and stuck there. I left it until the following day and i still...
        09-02-2025, 01:51 PM
      • cstout
        DeLonghi AC Remote only accepts 3V
        by cstout
        Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
        The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
        I can't find any schematics...
        06-03-2024, 03:53 PM
      • japlytic
        Certain DisplayPort-HDMI cables can disable HDMI CEC communication
        by japlytic
        With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
        An examination of the HDMI CEC wiring...
        07-10-2022, 09:48 PM
