panasonic tc-l32c22 Making hum sound and wont power up
  • reelitin
    • Jun 2012
    • 14
    Re: panasonic tc-l32c22 Making hum sound and wont power up
    I get 387 vdc when it is plugged in and turned on. when i unplug it and then plug it back in without turning it on, it starts at about 300 and constantly falls over a very short period time all the way down to less than a volt.
    • hugocarmo
      Panasonic TX-24A1UN CRT Sound and Input problem.
      by hugocarmo
      Hi.
      I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
      It is imaculate inside, almost no dust or debris inside.
      The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
      So I started to look for a service manual, I found one, and started from the beginning.
      Most of the times the caps are the problem so I orderer all the caps for all boards,...
      04-26-2025, 07:45 PM
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • Francesc V.
      Tele-master AS-20 amplifier. No output sound, just noise
      by Francesc V.
      Hi:
      I bought this amplifier from the 70s to try to repair it. So far it has no output sound, just noise. You can volume it up and down.
      I've checked fuses and all are ok.
      I've continued with capacitors:
      • The main black one should have 4700uF, but it has lost half of its capacity during these years.
      • The ones that I've numbered have still a really low ESR and the full capacity after ¿40 years?
      The 4 transitors are perfect. Desoldered and tested individually.
      There are also components which I don't know exactly what they are....
      02-16-2023, 07:55 AM
    • mar1in
      Panasonic TH-55AS670A no picture no sound
      by mar1in
      I've got this Panasonic TV here with the following symptoms:
      * Standby Light is solid RED
      * Turning on using the Button on the TV (long press) would change LED to blinking GREEN
      * After a couple of seconds, LED is solid GREEN and without picture or sound.
      I've tried a couple of things before tearing it apart:
      * Resetting using various combinations of powerbutton and volume buttons pressing down while booting.
      * Activating Self Check according to service manual using IR Blaster (we have no remote unfortunately)...
      09-10-2023, 11:10 PM
    • Christos Tsiligiannis
      Marian Trace Alpha sound card repair help
      by Christos Tsiligiannis
      Hello to the forum.
      My name is Christos, I am new to the forum here and i am posting from Greece.
      So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
      To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
      So i tried asking for a schematic from the company and they would not give me one. Instead they...
      11-18-2024, 05:26 AM
