TH-46PZ80U 46IN PLASMA no picture, no sound
    Re: TH-46PZ80U 46IN PLASMA no picture, no sound
    Okay, check that the red and brown cable with a lot of wires in it is properly seated on the A board end... you may need to reseat it on the D board side as well.
    Which connectors go to/from the power supply board from the main board?
    • nickmatine
      • Jun 2010
      • 48
      thanks for your help
      when i removed the cable with brown and red the image was white
      • nickmatine
        • Jun 2010
        • 48
        connector to power supply board
        • nickmatine
          • Jun 2010
          • 48
          is this a bad cap?
          • selldoor
            Slow Learner
            • 7870
            In the A board picture middle connector with alternate brown and white wire there is a a small white component - can you check if it is a fuse.
            Cap looks ok is it leaking at all? perhaps a pic more across the end if you think it is buldged
            • selldoor
              Slow Learner
              • 7870
              #26
              On the D board (at least I think that is what this is )I cant see any fuses but there are
              some fusible links which act the same. Can you test them all as you would a fuse. Some are not populated - there may be others I can see. Power off Multimeter on ohms 200
              one probe each end of FL - should be similar to holding the probes together. - Post results.
              By the way you said "when i removed the cable with brown and red the image was white"
              I dont know what you meant exactly but you should probably not plug/unplug connectors while the power is on.
              • nickmatine
                • Jun 2010
                • 48
                if you mean here, no fuse
                • nickmatine
                  • Jun 2010
                  • 48
                  d board fuses, all good (short)
                  • nickmatine
                    • Jun 2010
                    • 48
                    i forgot to plug in the connector and i started the tv without and i have full white screen
                      Okay, full white screen proves both sustain boards, as well as all of the buffers and address drivers are working. I'm 99% sure the problem is in the A or D boards, but I'm not certain which one in particular is at fault. Did you try the input trick I recommended? If you press a button on the remote control, does the power LED blink (I seem to remember Panasonic TVs doing this when you press buttons.)
                      • nickmatine
                        • Jun 2010
                        • 48
                        i tried but nothing more
                        if i press any button on remote does not blink
                        i can't power off, tv power of himself after 20- 30 sec and start again
                        • selldoor
                          Slow Learner
                          • 7870
                          #32
                          This might help- if you have not seen it.
                          http://www.scribd.com/doc/24963802/1...Plasma-Display
                          • DavidOH
                            • May 2012
                            • 105
                            Here's the manual I used for a PZ4280U.
                            http://www.scribd.com/doc/46124232/T...GPH11DU-Chasis
                            I had no blinks that I could tell. So I assumed 1 blink and went from there. Ended up being the A board.
                            • dcc905
                              • 3
                              Do you have a DMM (digital multimeter?) Any blinks from the LED? The screen glows in the dark?
                              I have the same model. the pics posted of the back are the same. Mine blinks twice, no glow at all and will not turn on at all. I do have a meter. I would appreciate any help.
                              • th-46PZ85U
                                • Oct 2013
                                nickmatime,
                                I am having this same problem with my TH-46PZ85U. Did you ever come up with a solution? It seems the thread has died. A reply would be greatly appreciated. Thanks.
                                • snappa
                                  • May 2015
                                  • 3
                                  • usa
                                  #36
                                  Hello all,
                                  I have a Panasonic th-46pz80u that isn't working. I replaced the main power supply which in turn gives me a different problem ontop of the original issue. the original problem was the no picture no sound and 10 blinks. now with the replacement power supply board i just get 3 quick clicks and solid power red light when i plug in the power cord. Still no picture or sound, no fans running. I press the power button and nothing. Anyone have any idea what else could it be? I can't seem to find an answer to this online anywhere.
                                  Thanks,
                                  Carl
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    everything connected correctly? page 33, see what that comes up with. picture of the tv so we can see how it's all connected
                                    • snappa
                                      • May 2015
                                      • 3
                                      • usa
                                      #38
                                      Hey Tw2005, I purchased a new power board from china and plugged it in and get the same issue. All the cabling is seated correctly but all i get is 3 clicks when i plug it in and just a solid red light. no blinks at all. I looked at the tech manual you sent but i'm not so good with checking voltages with a multimeter but i will give it a try.
                                      • KYBOSH
                                        Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                        by KYBOSH
                                        Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                        No picture but you hear the TV static (white noise) playing loud and clear.
                                        The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                        But it seems they didn't get too far and just left it.
                                        When I first took a look I was amazed at how pristine the inside looked.
                                        Its as if the TV had been in a time capsule.
                                        Caps looked like they were just pulled off the self.
                                        Copper coils had no sign of corrosion on...
                                        02-01-2023, 11:10 PM
                                      • TR103
                                        by TR103
                                        - it keeps rebooting
                                        01-22-2025, 04:12 PM
                                      • Mgiffune
                                        by Mgiffune
                                        06-09-2024, 10:28 AM
                                      • Ierwin
                                        by Ierwin
                                        05-13-2025, 03:31 PM
                                      • jchang
                                        Samsung UN70NU6900F no picture and no sound
                                        by jchang
                                        Hi all
                                        I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                        Symptom:
                                        No picture no sound.
                                        When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                        No sound at all.
                                        What I tried:
                                        1. I tried unplugging the left or right ribbon...
                                        01-09-2023, 06:28 PM
